Question about Linksys WRTP54G Wireless-G Broadband Router with 2 Phone Ports. (NETVOIPWLSWRTP54)
Trying to secure my wireless - Linksys WRTP54G Wireless-G Broadband Router with 2 Phone Ports. (NETVOIPWLSWRTP54)
    Master:
  • 451 Answers
You can follow this guide
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696
to secure your wireless router.
Posted on Mar 15, 2011
Have a Linksys Wireless router Model WRT160N Security is set at WPA2 Personal i can not get my new iPAD to connect when i diasable Security it connects I am looking for a suggestion I also need...
@joea1956
Try the following:
1. If you want WPA2 encryption on your router, (which also have higher security and compatibility issues with wireless cards), you could try WPA2-TKIP (which is standard encryption and made compatible for all wireless cards) or WPA2-AES (for specific wireless cards that are unable to connect to TKIP encryption)
2. If Step 1 won't work, try to lower your security encryption to WPA-PSK (either TKIP or AES) and try again. If this works, your IPAD2's wireless card doesn't support WPA2 encryption yet.
If all of the above fails, I do not recommend WEP since it's easily cracked (for advanced users) but you could try it as a last resort.
Good luck.
Sep 08, 2011 | Linksys WRT160N Wireless Router
Router password
>If you're trying to put password for the Router, then type "http://192.168.0.1" into the address bar, then hit "Enter."
>Use "Admin" as the username and leave the password blank when the login screen appears.
>Please click on Administrator settings and change the User Name and Password.
If you're trying to put a password/secure the Wireless network, then follow the steps:
>In the Router setup page, click on Wireless Settings.
>Under Wireless Security Mode, select Security Mode: WEP/WPA/WPA2.
>Enter the Security Key manually or enter the Phrase to generate the Security key automatically (only in WPA/WPA2) and save the settings.
>Please note the Security Key to connect to the Wireless Networ.
>The Wireless is secured now.
Good Luck!!!!
Jul 02, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Brought a new laptop with wireless installed have a philips SNB5600 but have lost the security key how can i get the code
go to the wireless access point admin settings (not on your wireless adapter on your laptop). then check wireless security settings. if you see something there such as security key, that is the security key that you need to set up on your laptop. if security key is not visible, try to see if there is an option there which says unmask to show the security key, then copy it to your laptop. if all else fails, change the security key in the wireless access point and change all the wireless adapters that connect to it accordingly to the new security key you set it up.
Nov 07, 2009 | Computers & Internet
Don't know my password , trying to connect with my new MAC
If you are looking for your wireless security code, you can verify it by accessing the router's interface.
Open a browser and go to 192.168.1.1 by default the password is admin. Go to Wireless and then Wireless Security just copy your wireless security settings and enter in on your MAC's wireless settings.
Jun 30, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Feb 11, 2009 | NetGear WGR614 Router
WPA for linksys
I would guess you are entering something incorrect with your security. If the wireless adapter on your XBOX wants a WPA then the wireless it is picking up has security on it however, it may be incorrectly set using WEP or WPA radius. Here is what *I* would do. Log in to your wireless router and remove all security. Go back to your XBOX and look for the signal for your wireless network. Now try to connect. Wireless connections can be a pain to configure sometimes but start first with no security and work yourself up. IF you can't get it working with security, make up a goofy SSID with NO security but don't broadcast it then you can connect the manual way through your XBOX specifying the SSID (not broadcasted) and no security that should do it. (Just a side note for my XBOX I bought a cheap Belkin 4 port router made it an access point for my existing wireless network and hardwired my XBOX to it. Works fine.)
Jan 23, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
No network
The Wireless Security of the router doesn't match your laptop's wireless settings. Make sure you configure the wireless security password correctly on the laptop. If you don't know your wireless password, try these steps:
-Connect your laptop hard wired to the router.
-Open Internet Explorer and on the Address Bard type http://192.168.1.1 press enter.
-It will prompt you for username and password. By default, there's no username and on the password type admin and hit OK. If admin didn't work, type your own password for the router.
-When you get to the Setup page, click on Wireless Tab, then click the sub-tab Wireless Security.
-Look for Security Mode. If Security Mode is WPA-Personal, the Passphrase is the wireless security key that you need to enter on the laptop's wireless settings. If the Security Mode is WEP, the WEP Key 1 is your wireless security key. Connect to the wireless network and type it in. That should solve your wireless connection problem.
Sep 06, 2008 | Linksys Wireless-N WRT150N Router
Security code
if you are using a siemens 4100 modem alone.. siemens 4100 modem has no wireless capabilty unless there is a wireless router plugged in..
if you already have a wireless router.. the SECURITY CODE shud be provided by your wireless provider
REMEMBER: SIEMENS SPEEDSTREAM is not wireless capable
Jun 26, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Losing wireless connection when I enable wireless security on 2350
Have you tried your laptop on a different wireless network?
Apr 27, 2008 | Dell Wireless 2350 Router
Security
Go to the router's web interface (192.168.1.1), in the wireless section go to Wireless Security. Enable WEP, you will create a WEP key for your wireless network, then that key will be asked to any wireless device that tries to use your wireless network.
Nov 29, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
27 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
