Question about XO Vision Car Audio & Video
I can't get my amp to play - XO Vision Car Audio & Video
    Sergeant:
  • 162 Answers
Try looking over your fuse to make sure it's not blown.
Posted on Mar 15, 2011
Technics amp to tape deck connections.
Red for Right channel (play). White for Left Channel (play). Yellow for right (Record) Black left (record). The leads should run from tape (out) play to amp in play. Same for the left channel.
Record from tape (in) to Amp (out).
Jan 29, 2014 | Audio Players & Recorders
Cd player dosen't play with amp
hmmm...what cd player are you using?..
May 03, 2008 | Kenwood KDC-MP828 CD Player
My Xbox 360 fell over and now the disc has a ring around it will not play!! I've tried everything and the disc just won't play.
You will probably have to get a new copy of your disk, but there is one other option that is worth a try. If you can find a "CD Repair Kit", try running your disk through that and then see if it will play. A CD Repair kit uses a clear resin to fill in scratches on the surface of a disk, removing the reason that the disk will not play. It does not always work, but a CD repair kit is much cheaper than re-buying a game you have already spent money on. try this one:
http://www.google.com/products/catalog?hl=en&sugexp=ldymls&xhr=t&q=cd+repair+kit&cp=10&qe=Q0QgUmVwYWlyIA&qesig=xwNELoNXZWL51NsEp4qaDQ&pkc=AFgZ2tmN04my0ZH7YSJ8Bm2TbmKLmrTNSO4UralGK__lMqTX9gVtI2mRc3n9Qafuq5pUbu-BnQewzPJ-QN9PQ14ScYAY8N9Lhg&bav=on.2,or.r_gc.r_pw.&biw=1024&bih=650&um=1&ie=UTF-8&tbm=shop&cid=16739641775731144756&sa=X&ei=6wHfTc_VNIi_gQfCyczPCg&sqi=2&ved=0CDAQ8wIwAA
This should be able to help you repair your disk. The best part of buying this is that you can use it on any disks that you have that skip or do not play. It will not ALWAYS work, but it is worth a shot -- especially if you spent $50 or more on the disk in the first place.
May 27, 2011 | Microsoft Xbox 360 Console
2003 gran prix- front pasenger tire has play. what can i do to fix it?
Jack up car with jack under the lower control arm, enough to get tire off the ground. With tire on, grab tire outside edges at 3 oclock & 9 oclock, push in & pull out respectively on each hand. Look for play in bearing between bearing & cv shaft. You can also see play in outer & inner tirods if any. Now move hands to 12 oclock & 6 oclock, push in & pull out & check for play in upper & lower balljoints. You should be able to verify whatever component is loose.
Oct 03, 2010 | Pontiac Grand Prix Cars & Trucks
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
Speakers have played intermintintly for several
you need to find out if your vech has an amp or not call your dealer and give them the vin# adn they can ck to see if the truck was built with or with out an amp.If the truck has an amp the radio sends low level signals to the amp then the amp amplifies them and sends the signals to the speakers. so if the amp is bad and you replace the radio it still will not sent the signals to the speakers.
Feb 25, 2010 | 2001 Chevrolet Suburban
I dont have my manual with me .Could you please tell me how I view the 'photo that I have just taken on my Samsung S630
■ If the memory card is inserted in the camera, all the camera functions apply only
to the memory card.
■ If the memory card is not inserted in the camera, all the camera functions apply
only to the internal memory.
■ If you have turned on the camera by pressing the POWER button, you can press
to Recording mode.
■ You can turn the power on with the play mode button. The camera is turned on in
■ You can set up the PLAY mode function by using the camera buttons and LCD
monitor.
● Playing back a still image
play mode button ( ).
100-0007
3. Select an image that you want to play back
by pressing the LEFT / RIGHT button.
※ Press and hold the Left or Right button to
fast forward the images played.
AND here is the manual in free downloadable form
http://www.fixyourownprinter.com/forums/inkjet/24191
Oct 09, 2009 | Samsung Digimax S630 Digital Camera
Blu ray wont play
That machne does not have a bluray drive & that is the simple reason why you can not play a blu ray disc. This is what your drive supports.
Plays Standard or multiregion DVD's & Audio CD's. Records DVDs 8x & CDs 24x & Dual Layer Super Multi. No Bluray or HD DVD,
If you were sold the machine as a bluray laptop then take it back & demand your refund.
Aug 02, 2009 | Acer Computers & Internet
Amp shuts off when trying to play cd
it sounds like you have the amp hooked up to the power antenna lead instead of the amp remote lead. should be two blue wires.
Jul 29, 2009 | Car Audio & Video
Car Audio & Video Logo
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
