Question about Garden
I need to get a manual for my gas wire welder made by napa
  • 95 Answers
Try going to manualsonline.com they may have one you can download free.They seem to have most anything.
Posted on Mar 15, 2011
Does welder need argon gas when using steal wirer
Hi:
If you are using solid mild steel core wire, yes you need a mix of gas Argon/CO2 75/25.
Only cored shielded wire do not required gas (also called innershield or flux cored).
Adjust your flow rate for the mild steel wire at 20 or 25 scfh, depending if you are welding inside or outside a shop.
Feb 05, 2011 | Clarke Power Products Clarke 130EN...
Have solar 110 2172 mig welder does this mig use gas can i use flux core wire also is owners manual available
Yiu can use both innershiel and solid core wire. All you need to do is inverse the polarity for the innershield wire (gasless wire) connect the gun to the ground and ground cable to positive side.
Dec 26, 2010 | Solar Mig Welder Welding Gun Liner Parts...
I have a century powermate 70 mig welder and using .30 fluxcore wire. the machine says that it is gasless also. the machine will not weld right. is this the right wire or what could be wrong?
Check that your ground clamp connection to the weldment is secure (tight).
you can weld with the shielding gas, or without.
by not welding right, what exactly do you mean?
Jun 29, 2010 | Welding Tools
Pull triger the welder wouln't start and the wire dozn't feed
You could have a couple of things wrong. A bad trigger switch is very common. That is about 99% of the time. Next are connections to the box.Not too common but they can corrode or get loose. Then you can have drive motor issues or something annoying like a pinched or galled liner stopping the wire.
To rule out most things we need to know if the wire feeder is working or trying to. All we need to do is press the trigger and listen for the feeder motor. We want to do this with the top open so we can see it as well. If it doesn't do anything then we need to look at the switch, connections or the motor itself.
If it sounds/looks like it wants to work then we might have something simple like the wire drive or pickup being out of adjustment or worn or the wrong size or type for the wire you are using. If you lay the lines out straight and then try to manually move the wire it should be stiff but smooth. Use pliers at the pistol to pull on the wire, and loosen off the driver wheel tension. If the liner has a kink or was damaged then the wire will not feed or will be very hard to move.
My bet would be on the switch.
Apr 21, 2010 | Clarke Power Products Clarke 130EN...
The Mars 180 MIG Welder Manual neglects to
Hi mate. Not sure on the power settings but the earth clamp is negative for gasless and possitive when useing gas
Mar 20, 2010 | Welding Tools
NAPA welder model 38-328 continuesly feedswire
is there power at the wire all the time. if so the finger switch may be stuck or shorted
Oct 22, 2009 | Welding Tools
What is required to switch from steel to gas on light duty mig welders
if you mean from flux core wire to gas shielded wire you will need a tank and regulators,and feed hose from the welder to the tank
Sep 06, 2009 | Lincoln Electric LE 83180 Century...
Looking for a wire feed roller for Clarke Welder
Google Clarke welder parts to find a supplier. Or alot of auto parts stores sell that brand should be able to get it for you. I have a JET drill press that I needed parts for and found that my local NAPA store could get them and they don't even stock any Jet equipment.
Aug 13, 2009 | Clarke Power Products Welding Tools
Northern tool mig welder,120 volt with gas.The wire feed is not working.When i pull the trigger the wheel that feeds the wire to the gun does not spin,even with no tension on it.The fan works and the...
you are going to need to remove the wires going to the wire feed motor, then take a volt meter and check the wires when you pull the trigger. this will tell you if the motor is bad or another problem
Apr 14, 2009 | Welding Tools
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
