Question about Magic Chef Freezers
Chest type freezer has frost on left side at the top of the freezer
    Genius:
  • 1,075 Answers
Leaking seal at that point,feel the seal around that area you will feel it warm.This is caused by warm air getting sucked in at this point,replace seal.adrian?????????
Posted on Mar 15, 2011
Why is there a lot of frost in my woods v15nab freezer?
On a chest freezer, frost always accumulates around the top perimeter first because the warmer moist air comes in contact with that area first once the door is opened. More frequent defrosting may be the answer.
Jun 08, 2014 | GE Freezer  14.8 Cu. Ft. Manual...
There is frost around the top of my Holiday manual defrost chest freezer freezer - does the seal need to be reparced
if the frost is just around the top seal area then YES.but if the frost goes further down then the whole unit needs a full defrost (NO scrapers/hot water/steam/or any other "help")use car de icer...and dry thoroughly.also, if too full, it will frost up around the top.
Aug 22, 2010 | Freezers
Frost build up shortly after defrosting it.
the frost buildup is entirely due to badly fitting seals,its also costing you a fortune to run it.A 5 sided cube is easily adjusted by using a spirit level and spacers under the feet/wheels(if fitted)once adjusted the lid should fit square.otherwise check the hinges for adjustment.
WHEN FITTED/INSTALLED CORRECTLY, THE LID SITS TIGHT ALL ROUND,NO AIR GAPS.....
Jul 10, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Just got a used 5.0 frigidaire chest freezer and noticed that it is starting to frost at the top but water is starting to pool at the bottom. any help would be appreciated
Good day,
The interior walls should frost evenly. If you only get a partial frosting pattern then either you have a refrigerant leak or a restriction in the refrigerant lines.
Either problem would be considered a terminal failure in a chest freezer.
Mar 29, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frosts up at front then food starts to defrost
It would appear to me the system has a leak. Allow me to explain. When a fridge/freezer is "lo" on gas it causes the compressor to run far longer than usual. As a consiquence the motor overload shuts it down, potentially for a very long time, hence the contents thaw. The major clue to this a frost pattern on just one wall. Have a tech visit to confirm, but I suspect you'll be out of luck as far as a repair goes. Chest freezers are not easy to repair "lo side" leaks, which is likely what you have, because the evap. coils are in the walls. sorry, but I hope that helps in some manner. good luck
Sep 28, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 | Freezers
Its freezing roun the top and not the bottom?
is this a chest freezer? Thick frost around top? try defrosting unit. DO NOT scrape the ice. Very important to remove drain plug to remove water or frost will very rapidly redeposit
Jul 13, 2009 | General Electric Chest Freezer FCM5SU
Frost in Chest freezer
Not much you can do except ensure you have a tight seal and not to open it more than you have to.
Oct 23, 2008 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Freezers Logo
101 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
Offbelay
Level 1 Expert
AJMAL KHAN
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
