Question about Toshiba Satellite Pro 4600 Notebook
Problem upgrading RAM on a Sate Pro 4600
I am trying to upgrade the momery from 2x 128M RAM to 2x 256M RAM on my wife's old Sate Pro 4600, but the laptop does not want to take it. It makes a beep sound, then shows the message "remove the incompatible memory in slot 1 (or 2)".
I do not understand... I double checked the 256M RAMs are PC100, SODIM. Exactly the same as the two 128M in the slots.
I tried adding one RAM and both at the same time, same problem. I checked and know the max. memory is 512M.
Kindly help!
  • scottho8882 Aug 01, 2008
    Hi Pyrhyc,
    Thanks for your response...
    Yes, I tried 256 chip individually, actually three different 256 chips. And I tried two at the same time. Same problem...
    I am running XP Pro and no I have not done any drive, utilities and bios updates.
    Thank you!
    Thanks, I will try and get back to you. Have a good weekend.
Hi Pyrhyc,
I tried the files in the link you provided, it did not help. Is there specific ones I shall use?
I took the most latest for the DMI,Special, Bios and utilities.
Kindly help again.
Posted on Aug 02, 2008
    Genius:
  • 2,028 Answers
Just a few questions first, get back to me (before rating me), and I'll see if I can get you through this. You have tried each 256 chip individually in each slot with the same error, correct? Are the 256 chip the same make? What operating system are you running? And finally, at least for now, have you done any drive, utilities, or bios firmware updates lately?
Posted on Aug 01, 2008
I bought 2 x 1 GB 128M x 72 333MHz PC2700 DDR SDRAM cards to upgrade my HP Compaq dx 6100 MT Pentium 4 Desktop - Upgraded the BIOS as prescribed...BUT if i insert these memory cards in any order in the...
wrong parts, its not support by chipset
Memory
One of the following
2-GB DDR Synch Dram PC3200 (400-MHz) Non ECC (2x 1GB)
Memory Speed Supported DDR Synch DRAM PC3200 (400MHz) non-ECC
Product documentation
Dec 20, 2014 | HP Computers & Internet
Will Mercury 810e motherboard support 1.0 GB (512 MBX2) SD RAM?
I cannot directly answer that question because you did not supply the motherboard model number. You will have to look this up yourself, here is the url for Mercury support
http://www.mercury-pc.com/downloads.php
The model number is usually printed on the motherboard, find it and you can download the manual, specs and drivers.
Mar 06, 2017 | Q-Lity 810E-T (P3810E-T) Motherboard
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
Hi i have compaq presario 5000, detailed description would be P5700/P.4-1.6G/128M/40G/D16/M. i wanted to know which mother board is inside this PC and i wanted to upgrade my ram from 128 to 1 Gb. is it...
768 meg is the most you can put in the 5000 ..your system only has 128 meg so 768 would be a considerable improvment .... "crucial.com" is a great company to get reliable memory and information ... here is their page on your computer
http://www.crucial.com/store/listparts.aspx?model=Presario%205000%20Series%20Model%205000US
Oct 06, 2009 | Compaq Presario 5000 PC Desktop
Im trying to fix up my wife's Dell Inspiron B130 instead of buying a new computer. what is the best processor, and video card upgrade i can do?
You don't want to upgrade the cpu. As for the video card it can't be changed as its build into the laptop motherboard.
I would highly recommend that you instead upgrade the ram memory on the laptop since it will give you a bigger performance increase than a new cpu or video card.
The machine only has 256MB of ram, get atleast 512MB or 1024 /1gb of ram and it will work much better.
Jul 09, 2009 | Dell Inspiron B130 Notebook
Upgrading memory
hi If you go to www.crucial.com they will scan your pc & tell you what rams youhave & what you need. then buy from wherever. hope this helps blue51
Apr 14, 2009 | Dell Dimension 4600 PC Desktop
Can i put 512M memory cards in if so which type
1st: is it still under warrentee? if so, it needs to be done by a certified technician otherwise you may void the warrentee.
If not, look at the manual and see what RAM/Memory the Motherboard will support.
Mastersage
Feb 19, 2009 | E-Machines T1100 PC Desktop
RAM Memory upgrade
K8V SE Deluxe DDR400 Memory Qualified Vender List
The following table lists the memory modules that have been tested
and qualified for use with this motherboard.
Size Module Vendor Model Chip Brand
SS/
DS
Chip
256M Micron MT8VDDT3264AG-40BC4 Micron SS MT46V32M8TG-5BC
512M Micron MT16VDDT6464AG-40BC4 Micron DS MT46V32M8TG-5BC
128M Infineon HYS64D16301GU-5-B Infineon SS HYB25D256160BT-5B
256M Infineon HYS64D32300GU-5-B Infineon SS HY25D256160BT-5B
512M Infineon HYS64D32300GU-5-B Infineon DS HY25D256800BT-5B
256M Infineon HYS64D3230HU-5-C Infineon SS HYB25D256800CE-5
512M Infineon HYS64D6320HU-5-C Infineon DS HYB25D256800CE-5
512M Samsung M368L6432ETM-CCC Samsung DS K4H560838E-TCCC
256M ATP AG32L64T8SQC4S Samsung SS K4H560838D-TCC4
256M Brain Power B6U808-256M-SAM-400 Samsung SS K4H560838D-TCC4
512M Brain Power B6U808-512M-SAM-400 Samsung DS K4H560838D-TCC4
512M Apacer 77.10736.464 Samsung DS K4H560838D-TCC4
256M ADATA MDOSS6F3G31YK1EZZ Samsung SS K4H560838D-TCC4
128M NANYA NT128D64SH4B1G-5T NANYA SS NT5DS16M16BT-5T
512M NANYA N512D64S8HB1G-5T NANYA DS NT5DS32M8BT-5T
256M Hynix HYMD232646B8J-D43 AA Hynix SS HY5DU56822BT-D43
256M Kingston KVR400X64C3A/256 Hynix SS HY5DV56822BT-D43
512M Kingston KVR400X64C3A/512 Hynix DS HY5DV56822BT-D43
512M Winbond W9451GCDB-5 Winbond DS W942508CH-5
256M Kingston KVR400X64C25/256 Winbond SS W942508BH-5
256M ADATA MDOWBFF3G31JB1EAE Winbond SS W942508BH-5
512M TwinMOS M2G9J16AGATT9F081AA4T TwinMOS DS TMD7608F8E50D
256M TwinMOS M2S9I08AFAPS9F0811A-T PSC SS A2S56D30ATP
256M KINGMAX MPXB62D-38KT3R KINGMAX SS KDL388P4EA-50
512M KINGMAX MPXC22D-38KT3R KINGMAX DS KDL388P4EA-50A
256M CORSAIR CMX256A-4000 XMS4000V1.1 CORSAIR SS
ive found the best prices at tigerdirect.com and they ship it right to your door. make sure the tiger ppl have the exact match and dont replace your order with more expensive replacements as some of these substitutions require voltages that your motherboard CAN NOT produce and will not work.. you also want to make sure to buy low density ram, it performs better, is a few bucks more than high density, but worth EVERY penny. E-bay is notorious for selling cheap high density ram on thier site.
If you stick to the list above, you shouldnt have any issues.
This should fixya up! please rate...
Oct 28, 2008 | Computers & Internet
Need to know what type of RAM my MD 1921 has so I can upgrade.
Hi KF27,
Your system has and supports PC SODIMM DDR RAM with a MAX support of 1GB. You currently have 512MB of RAM (2x 256MB), so your only option is 2x 512MB of RAM..
I hope this helps you out!
Sep 03, 2008 | Medion Computers & Internet
Toshiba Satellite Pro 4600 Notebook Logo
131 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
