It wont charge my netbook - Computers & Internet
    Scholar:
  • 115 Answers
Is your ac adapter or charger detected?
If YES, and it doesn't charge the battery, but it turns ON the laptop it means that the battery is the one not holding a charge.
If NO. Try to change the power cord that goes to the wall (that part is detachable) with good known power cord. If it does the same then definitely there's a problem with the ac adapter.
If the computer powers ON, both ac adapter and battery are detected but no display, then the problem is the system board.
Hope it works.
Posted on Mar 15, 2011
Advent troubleshooting
Hello there Sarah
It sounds like your battery is dead and it requires to be charged, so plug in the adapter and plug it into your Netbook and allow it to charge.
Aug 31, 2014 | Computers & Internet
Battery wont charge
Please check the battery charger. Otherwise, I had one of this HP Mini 1000 replaced by HP with the same problem, the Mini gone complete dead, no charging or turn on.
Apr 07, 2012 | HP Mini 1000 Netbook
My netbook charger wont chanrge properly. I have to play around with it too charge. At some places like if i putit down it might charge but then again if it is moved abit then it wont charge. I have to...
This is caused by a faulty DC jack on your motherboard. The solder holding the pins from the jack to the motherboard break and when you wiggle it just right the solder is contacting the board.
Most repair shops will charge you at least $100 to fix this.
Repair options are A. Re-solder the DC jack on, this requires dis-assembly of the netbook B. DC jack has broken pins and it is generally possible to replace the jack unless it is epoxied to the motherboard then it's on to C. C. Replace the motherboard.
A is obviously cheaper.
Aug 05, 2011 | Advent Netbook
The battery wont charge to 100%.. plus, the battery capacity decreases day by day.. i dont understand cause ive charged it for 3nights wont stop.. but it not reach 100%.. the indicatior also wont change...
The battery could be faulty or the charging circuit is faulty. I suggest you return it to the supplier for repair or replacement as this netbook would still be under warranty.
If you try to repair it yourself you may void your warranty.
Jul 03, 2011 | Acer Aspire One AO532H-2527 Netbook
I bought a new battery for my advent 4490 net book .the battery worked fine on the initial charged tht it already had but now whn the battery is now left with the 9% charge in it , i plug in my charger and...
I I have the same issue and i took my netbook to more than 4 electronic engineers, all of them said that doesnt seem there is a problem in my netbook though.
Mar 31, 2011 | Advent Netbook
Asus 1005HA pc not charging.. The blue light on the charger is on but it wont charge the laptop..
I have a total of 5, yes 5 netbooks and a laptop. My experience has taught me that sometimes, it is the charger not the actual netbook/notebook that is the problem. My barely used compaq laptop sat quiet for 2 years.... wouldn't charge..... I assumed it needed repairs more than I could afford. Meanwhile, with 2 of the netbooks, they stopped taking a charge even with the lil led light on. I ordered new chargers for netbooks- PRESTO-- they took a charge. And eventually got a new charger for the expensive paperweight I had too. Now they are all working again. Not an expert by any means, but have had a lot of experience with them. I would rather pay 15 bucks and be wrong, than assume it's something else- have them fix for 80.
Mar 16, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
NETBOOK WONT TURN ON WITH OR WITHOUT BEING PLUGGED IJ WHEN THE NETBOOK WAS PLUGGED IN AND CHARGING, THE BATTERY HAD 100%. STARTED TO USE THE NETBOOK AND THE BATTERY LEVEL WENT TO ZERO %. NOW EVEN WHEN...
  1. Remove the battery for 15 seconds, and make sure the contacts are clean and free from dirt, dust, etc.
  2. Reinstall the battery and try to turn the netbook on.
  3. If it still doesn't work, replace the defective battery.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
My six month old, LT gateway netbook wont charge...50% percent HELP!!!!!!!!!!!!
sounds like you'll need to get in touch with gateway for warranty repairs/replacement, though, you may try to remove and reconnect the battery, check for BIOS updates from gateway that may include fixes on battery charging , and test if the battery will have same issue when connected to another system, if available. Try to also leave the netbook connected to the adapter/charger for a few hours while switched off as it can help the battery to charge faster.
Sep 04, 2010 | Gateway LT2021u Netbook
Lenovo netbook wont turn on. It is brand new, and ...
hi! just a tip if its a brand new one try to isolate the problem check if it can actually run by removing the battery just by the ac adapter if still doesnt work then probably you have to charge the battery first if it still doesnt charge then probably there is somethin wrong with the power board. i suggest you call your lenovo tech support for further assistance. hope this would help goodluck!
May 20, 2010 | Lenovo IdeaPad S10e Netbook
Battery will not charge on netbook
Sounds like it may be an internal problem with the charge system on the laptop, if you can run the laptop with the AC cord but it will not charge, I suspect the charge module is bad.
May have to return it for repair.
Sep 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
