Question about Whirlpool Washing Machines
Whirlpool/kirkland washer spin cycle has stopped. any suggestions?
SOURCE: Kirkland Signature by Whirlpool Washer
There could be 2 possible issues, one, the simplest is the switch activated by the lid, look for a plastic "prong" sticking out from the lid, see where it goes and find a switch, use sometime of similar size and see if you can activate it. If that is eliminated then it is a plastic coupling broken, quite involve, need to remove the back lower section and inspect for this, Had both these issues myself.
Posted on Apr 01, 2008
ginko
  • 19396 Answers
SOURCE: Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Posted on Nov 20, 2008
    robocop
    • 90 Answers
    SOURCE: whirlpool washer wont spin during high spin cycle
    Try www.Repairclinic.com.
    Posted on Jan 19, 2009
    • 54 Answers
    SOURCE: whirlpool washer LSQ9549LW1- loud thunks at end of spin cycle
    you can goto sears.com and goto parts, put in your model # and they have a parts and diagram that you can look at.. sound like your basket block (which holds your basket on the gear shaft) is loose.. or 3 bolts on bottom of washer the holds gearbox to frame is loose.. good luck
    Posted on Jan 21, 2009
    maddogsteve1
    • 18 Answers
    SOURCE: My Kirkland Signature Whirlpool Washer will not agitate or spin
    broken coupler. device between motor and gearcase, look under washer behind the motor for small plastic and rubber coupler. may be worn or broken. cheap part/fairly simple fix. parts house will run ou through the process or i can provide details when you are ready.
    Posted on May 25, 2009
    Whirlpool front load washer (W-WFC7500VW1) was ran through the clean cycle. After this was preformed, the washer will not spin the clothes the dry. The washer will spin but never reaches the 'higher' spin...
    I suggest going on the Whirlpool manufacturers website and check their forums for a similar problem. It could very well be something very easy to fix.
    Jan 08, 2015 | Whirlpool Washing Machines
    Will not agitate or spin
    On Whirlpool brand made machines the drive coupler between the motor and the transmission is probably stripped out or broken and needs to be replaced.
    Keep in mind that Whirlpool also manufactures: Estate, Roper, Kitchen Aid, some Kirkland and some Kenmore washers. All have the same coupler that gets stressed and breaks. A cause for this often times is overloading the machine.
    After inspecting and finding the problem, make sure you have the model number and call your local appliance parts store or repair center and they probably have your part in stock.
    Repairing a stripped out coupler is pretty easy for the doit yourselfer.
    I suggest watching this video before attempting the repair:
    http://www.youtube.com/watch?v=WLPGs2UMUJc
    Apr 10, 2010 | Kenmore 24032\24036 Top Load Washer
    Whirlpool type 111 model LSQ9200LQ3 washer not
    I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
    Jan 30, 2010 | Whirlpool Washing Machines
    Whirlpool washer agitates, but won't drain water
    HI, any resistance when turning the impeller in this case will confirm pump failure. these motor should have very slight resistance when manually rotated. the unit will not initiate a full cycle if the pump is defective. replace the pump asap.
    Jul 24, 2009 | Whirlpool AWM5145/2 Front Load Washer
    My Kirkland Signature Whirlpool Washer will not agitate or spin and the motor makes a load noise (like something rattling) when the tub should be moving. but it does drain water.
    May 24, 2009 | Washing Machines
    Bad smell from washing machine
    does it smell like nappies or electric burning?
    May 07, 2009 | Washing Machines
    Whirlpool Duet stuck on spin cycle
    Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
    Feb 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
    After spin cycle washer stops abrubtly causing it to shift.
    You have dragging brake shoes. This will cause the motor to draw excessive current. Nedd to take apart and pull down spin tube to access the brake shoes
    May 31, 2007 | Whirlpool LSQ9600L Top Load Washer
    Washing Machines Logo
    53 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
