Question about GE Profile Harmony DPGT750EC Electric Dryer
My GE Electric Dryer (Model DX4500EG3WW) will not start. The light in the drum still comes ON when the door is open. I have checked the power to both the breaker and outlet, and they check out O.K. What may I check next?
  • GE Master
  • 8,220 Answers
Intermittent heat problems with GE dryer. Drum light associated with problem. Light goes out with door open when centrifugal switch disengages. No heat when this occurs.
this problem is related to the thermal hi-limit cutout and its sister thermal fuse. The two can be bought as a repair kit from repairclinic.com or any appliance repair dealer. Enter your model number and the kit will come up high on the hit list of commonly ordered parts.
25361439-xipalmoknr3fbjmp51kycajc-3-0.jpg These two are in series with each other, and can be jumped out temporarily to verify operation. The silver one will look very much like the picture, the black and white one may be round instead of rectangular (depending on model). They should be swapped as a set. You can ohm them out just like regular fuses to check them.
Jan 09, 2015 | GE DWSR405EBWW Electric Dryer
Control Panel turns off
HI,
The PCB unit ie the control panel circuit board has gone bad. The probable cause of the same is moisture on the board.
Thanks
proton
Oct 21, 2008 | GE DCVH515EFWW Electric Dryer
If the dryer inside light comes on can the thermal fuse ok
No relations at all......
Light comes on means there is power and your door is open.
Thermal fuse failure means there is no heat. No current going through your heating circuit. Most models and brands will still turn the drum without heat. But there are some models thermal fuse will completely shut the power to heating circuit and drum motor. Like KENMORE certain dryers made by Whirlpool corporation
Jul 22, 2014 | GE GTDP180EDWW Electric Dryers
I have a GE dryer model # DPGT750EC1PL When I press the power button it does not come on, but when I open the door the light comes on. what part do I need to replace?
check the thermal fuse located on the element housing below and to the right of the drum assy. also you can tie all 3 leads of the door switch together to test this another problem is there the electronic control boards as there is a start relay on the line voltage side of this board and is controlled by the low voltage interface which is what you use to select your preferences to dry clothes from,normally theres a fuse located on this board or possibly the interface keypad could have one or more keypads stuck rendering the dryer dead
Jul 27, 2012 | GE Profile Harmony DPGT750EC Electric...
GE model DQSR483EE1WW. This is what I know so far: the switch on the door works so it shouldnt be that safety, it is getting power because the light work and the timer at least buzzes like its working,...
Try looking for a broken belt. (electrical interlock prevents starting with broken belt) Disconnect power, open door, remove two phillips screws which go from top of door opening into dryer top. Swing top up and back. If belt not present going around drum, that's your problem. Remove one screw from side panel to front panel on each side (near top) and lift front panel forward and off the bottom pegs. Set the front panel to the side (leaving door switch wires attached) so you can slip new belt around drum. Reach under drum to put belt WE12M29 around drive pulley and around tensioning pulley. (grooved side of belt touches drum) Put front back on dryer and manually rotate drum a couple revolutions to make sure belt does not come off before closing up top and reconnecting power.
Dec 24, 2009 | Dryers
GE ELECTRIC DRYER - WILL NOT COME ON.
Very often the problem is the resetable thermostat, if you open the top you'll find it on the back inside, you can test with an ohm meter or just bypass it to test it.
Mar 01, 2009 | GE WSXH208A Front Load Washer
Front felt drum seal on ge came off---hard to repair?
Open the dryer door. At the top of the door opening, there should be two screws holding the top of the dryer down. Remove those screws and the top will rotate up, giving you access to the drum.
Nov 19, 2008 | GE DBXR463GB Gas Dryer
Kenmore HE4 no power to control, no sound, but the drum light bulb on when door opened
Another post reported replacing the power cord. I am trying to determine if this is a factory defect. Check the power at the power cord connections inside the dryer. You could have lost power on one leg and the other 120 volt leg is letting the light work. Let me know what the model and serial number is.
InMrFixIt
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer will not turn on
IT COULD BE THE DOOR SWITCH. PRESS THE BUTTON IN WITH YOUR FINGER AND SEE IF THE LIGHT GOES OUT.
DOES THE SWITCH HAVE A POSITIVE CLICK? NO. REPLACE SWITCH. YES, THERE IS PROBABLY A THERMAL FUSE LOCATED SOMEWHERE NEAR THE EXHAUST. IT MIGHT HAVE FAILED. IF SO, THERE MAY BE A PROBLEM WITH OVERHEATING. THE MOTOR COULD ALSO HAVE FAILED. THE PUSH TO START BUTTON COULD ALSO BE DEFECTIVE.
Apr 07, 2008 | GE DPSB650EC Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
160 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
