Question about Singer Sewing Machines
I have a SINGER 2263. I've used this machine less than ten hrs. I have a jam, I've cleaned everything. The machine will turn un-restricted in reverse but forward half a cycle. The needle will either jam at the top or the bottom depending on where I start the forward cycle. I have not investigated further than the Bobbin shuttle. Any suggestions will be appreciated. THANKS, Bill
  • William Johns
    William Johns Mar 16, 2011
    I found the solution quite by accident and it wasn't in any of the instruction manuals. My problem was, the bobbin spindle (where you wind the bobbin) was thrown to the right, to the wind position. Being a novice, I did not know this is how the thing works. I'm a little embarrassed but live and learn. Thanks for trying to help. Sincerely, Bill
    Problem Solver:
  • 5 Answers
With the machine unplugged, remove the bobbin case and the shuttle mechanism. Clean and oil it. Check for any fabric or threads in your feed dogs. Change needles in case that one is bent slightly. If the jam was really bad, you may have messed up the timing, unfortunately.
Posted on Mar 16, 2011
I need a repaire manual for a singer simple 2263 sewing machine
This site might have what you need. Repair manuals can be very hard to find. I don't know that all the links on this site are still good but it is one of the only places I've even seen repair manuals for Singer machines listed. Best of luck.
http://sewing-machines.blogspot.ca/2008/08/singer-online-manuals.html
Feb 17, 2015 | Singer 2263 Mechanical Sewing Machine
How to lubricate Singer Sewing Machine Model 2263
Oiling instructions--as well as the user's manual--is available as a free download on the Singer site under "Support and Resources."
Jul 23, 2014 | Singer 2263 Mechanical Sewing Machine
My sewing machine is jammed the needle will not go up or down nor does the wheel
Stop! Get your camera/cell phone or whatever. Take pictures at each of these steps (to refer to later)
Remove the needle and presser foot (use scissors to cut threads if necessary)
Remove the plates under the presser foot that cover the bobbin and needle through area. Clean any thread/lint, etc from under there.
Get magnifying glass and inspect for additional bits of thread or needle ends that have broken off.
If necessary remove the shuttle race and inspect for burrs, cracks, etc.
replace everything and try moving the handwheel. If it works, it's good to go. If it doesn't take it in.
Now... when you begin sewing any seam. ALWAYS grasp both threads as you begin sewing. This will keep jams from happening and it is a good sewing habit.
Oct 28, 2013 | Singer 2263 Mechanical Sewing Machine
Where to oil my singer 2263 ?
The 2263 only needs oil on the hook race (below the bobbin case). The complete cleaning procedure for this area is, with the needle fully up, remove the bobbin case and rotate the arms that hold the hook outwards. Remove the hook cover and the hook. Wipe the area under the hook cover and hook with a soft cloth. Put 1-2 drops of sewing machine oil just to the right of the center of this area. Rotate the hand wheel until the hook race is on the left side of the bobbin area. Then replace the hook and hook cover. Snap the arms back towards the center and insert the bobbin in the bobbin case.
With the bobbin out and the needle up, you should also unscrew the faceplate and wipe the feed dogs with your machine brush. (For best results, clean this before you oil. If you do not do this first, you may brush lint and bits of thread into the hook race and risk jamming this part.)
For pictures, see http://www.singerco.com/uploads/download/1213_oiling-2263.pdf .
I hope this helps.
Dec 09, 2011 | Singer Sewing Machines
Singer 2263 instruction manual does not show where to lubricate or how to adjust the hook which keep jamming
First make sure that the needle is fully up. Then you need to open the hinged front cover and unscrew the needle plate screws. Remove the bobbin. Brush out any lint now. Remove the bobbin case. Then snap the hook retaining arms outwards. Remove the hook cover and hook. Put no more than 2 drops of sewing machine oil on the the case (center right hand side). Then turn the hand wheel until the hook race is in the left position. Replace the hook and then the hook cover. Snap the hook retaining arms back into position. Replace the bobbin case and bobbin. Then replace the stitch plate.
Test the machine on a piece of waste fabric. If the hook keeps jamming, take the machine in for maintenance. The parts that may need to be replaced are the race or the shuttle hook. However without seeing the unit I do not know if there is not another problem. Some parts for the 2263 are available here: http://www.sewingpartsonline.com/singer-2263-sewing-machine-parts.aspx .
Singer has a second manual available with the oiling instructions for the 2263 here: http://www.singerco.com/uploads/download/1213_oiling-2263.pdf . See the diagrams on this page for where things line up. The rest of the instruction manual is also online here: http://www.singerco.com/uploads/download/1180_2263%28eng_spa_fre%29.pdf .
I hope this helps.
Oct 08, 2011 | Singer 2263 Mechanical Sewing Machine
Sewing Machines Logo
106 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
