Question about Ovens
I desperately need a manual for my oven not sure what whirlpool model it is I only have a yellow tag about the automatic end of cooking programmer with the following CODICE;461999751903/A Can you help me
  • 33 Answers
Open the drawer , there is a white sticker with the model number on one of the legs. With the model number I can get you the manual
Posted on Mar 15, 2011
The ovens on my Indesit FIU20I cooker won't heat; the display is flashing and the manual says to reset the clock but I can't... apparently if the automatic cooking function has been selected you canno
Does the "manual" button not do anything in this state?
Have you tried this sequence?:
SETTING THE TIME OF DAY
Step 1 Make sure all oven controls are turned Off.
Step 2 Check the electricity supply to the cooker is turned on.
Step 3 When switched on the display will show 0.00 and the Auto symbol,
flashing intermittently.
Step 4 Press & hold in both the Cook Period & End Time buttons together.
Step 5 With the Cook Period & End Time buttons still held in, press either the "+"
or "-" buttons to set the correct time of day.
Step 6 Release all the buttons simultaneously.
Oct 30, 2014 | Ovens
Smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Apr 10, 2008 | Smeg SE280X Stainless Steel Electric...
MY WHIRLPOOL OVEN KEEPS RESETTING A PROGRAMME BY ITSELF EVEN IN MID COOKING. THE OVEN IS ONLY 18 MONTHS OLD. WHIRLPOOL WONT HELP ONLY AT A COST.
Although the manufacturer only give a 12 month guarantee it is down to the retailer to sort faults. Under statutory rights you have up to 5 years to male a complaint. Get a quote for repairs and issue a claim in the small claims court.
Sep 30, 2014 | Whirlpool Ovens
Oven timer not working
Make sure you're using right programme. There is a countdown timer that does not affect the oven operation. This is the one with a bell on it. If you want to stop start then use other programmes.
Nov 10, 2013 | Zanussi Ovens
I want to use top and bottom ovens but at different temps - how do I do this
To Set a Cook T ime:
1. On double oven models only, press UPPER OVEN or LOWER
OVEN for the one you want to set.
2. Press BAKE or CONVECT UPPER (on some models).
Press the number pads to enter a temperature other than the
one displayed.
3. Press COOK TIME.
4. Press the HR and MIN "up" or "down" arrow pads to enter
the length of time to cook.
5. Press START/ENTER.
The start time and stop time countdown will appear on the
oven display.
On double oven models only, when both upper and lower
ovens are being used at the same time, touch UPPER OVEN
or LOWER OVEN to display the respective cook time.
When the stop time is reached, the oven will shut off
automatically and "End" will appear on the oven display.
If enabled, end-of-cycle tones will sound, then reminder
tones will sound every minute.
Repeat the process by choosing the other option of UPPER or LOWER OVEN
Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
A (automatic cooking)remains in the digital reader which means that the electric oven/grill and fan oven won't work. It will not clear from the box.
What happens when you turn the power off to the whole oven, leave it off for a few mins and then reapply? If the automatic is still set it could be the clock is faulty.
Have you tried resetting the clock as per the handbook?
Dec 01, 2009 | Stoves 720EF Electric Double Oven
My kenmore gas oven won't heat. I turn to dial to temp i want can smell gas building up in oven and can see a glow in bottom of oven but will not ignite. Sometimes if I turn on a cooking eye I can then...
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Oct 22, 2009 | Whirlpool SB160PEE Gas Single Oven
Oven will not relight during cooking cycle
When the bake igniter becomes weak or burns out, your oven would not bake properly. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
Oct 20, 2009 | Whirlpool SB160PEE Gas Single Oven
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
New world 90TCgyro fan oven timer
From the New World Web site: "How do I set my timer/programmer into manual when it is set in auto? (5 & 6 button versions) On your timer there are two buttons, which read "cook time" and "ready time". If your timer is in automatic, you can return it to manual by pressing these two buttons simultaneously. REMEMBER - if your oven is in automatic it will not work until the time you set it to come on or if you return it to manual." Find more info on the link below: http://www.newworldappliances.co.uk/Common-Questions_p18.aspx
Jul 26, 2007 | New World 90TC Electric Double Oven
Ovens Logo
52 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
