Question about Refrigerators
I have an fisher and Paykel Active Smart 517 litre fridge-freezer. The thermostat control panel alarms with a continuous green flash. Pressing reset will mute the alarm but the green flash continues. Green flash when set on fridge compartment and green flash when set on freezer compartment. The cabinet and freezer evaporator fans are working okay and the reed switches for the doors are functioning. Switching main power to the fridge and the alarm sounds about 24 hours after. Placing a temperature logger into the freezer (-22 to - 19 C) and fridge cabinet (2 to 5 C) indicates correct temperature control with defrost operating correctly for temperature and frequency. The compressor discharge line is hot, suction line cool, the hidden condenser warm with an expected temperature gradient. Questions. 1. I suspect a false alarm but how do I repair/correct? 2. What is the green flashing alarm code indicating as the fault?
  • mark_coll120 Mar 16, 2011
    Hi Kel1guy, Unfortunately the instructions didn't match the Diagnostic Mode from your previous email. The Fisher and Paykel Active Smart fridge was purchased eight years ago. The model number has been cleaned off the sticker but corresponds to the downloaded instructions for E521T and E522B models.
    There is no LCD or Menu button as described in the email. "The Control panel has a "food and freezer compartment indicator" the symbol resembling the cabinet doors. A "Temperature indicator" resembling a mercury thermometer. A "Compartment select button" and "Increase" and "Decrease" temperature buttons.
    Pressing the Compartment button and increase temp button for 4 seconds gives a beep. Green LED lights randomly run up and down the thermometer and the LED lights on the food and freezer door symbol blink. Press the up button again and the compressor switches on. Up again and the cabinet fan works, press up again the freezer fan operates. Each time the lights change on the thermometer symbol until "Sabbath mode" is reached.
    When the fridge alarms as previously described, the green LED in the fridge door symbol blinks. Pressing the increase temperature button and the green LED on the freezer door blinks. I think the green light on the cabinet symbol is the alarm code needed to undertake the repair.
    Your assistance would be much appreciated.
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
You should enter the diagnostic mode to determin your fault:
Diagnostic Mode
To enter diagnostic modes, press and hold the MENU button
- then press the UP button for 4 seconds. The PC temperature
will be displayed on the LCD. The actual temperature of the PC is
shown. Note Temperatures are shown in Degrees Centigrade.
PC Sensor Temperature ____
- By pressing the Up button once more, this
will indicate the FC sensor temperature. Note: The "min" indicates minus 12°C
FC Sensor Temperature
- By pressing the Up button once more, this will indicate the Defrost sensor temperature.
Defrost Sensor Temperature
- By pressing the Up button once more, this will indicate the input/Output Status.
Input/Output Status
- Press UP one and two more time, both LCDs display 87.5 but should be ignored
Spare/ Blanks
- Press UP one more time and fault history will be shown.
Fault History
To exit diagnostic mode press MENU button
FAULT CODES:
A wrench symbol and LCD fault code will appear automatically if there is a fault in the
temperature measuring system, defrost system, fans or low ambient heater.
When the PC door is opened an alarm will sound, the number of beeps also indicates
the fault code. Pressing any of the control buttons can deactivate these alarms
Fault Code 1
Reason: On last power up, the power module failed self test.
Primary Action: Replace power module
Fault Code 2
Reason: The previous 2 defrosts were aborted after 30 minutes
Primary Action: Check defrost element
Fault Code 3
Reason: The resistance of all the temperature sensors is outside the normal range
(>45K Ohms)
Primary Action: Check 6 -way Rast connector at power module
Fault Code 4
Fault Code 5
Reason: The resistance of the FC sensors is outside the normal range (>45K Ohms)
Primary Action: Check sensor connector at power module
Fault Code 6
Fault Code 7
Reason: The resistance of the Defrost sensor is outside the normal range (>45K Ohms)
Fault Code 8
Fault Code 9
Reason: The resistance of the PC sensors is outside the normal range (>45K Ohms)
Fault Code 10
Fault Code 11
Reason: The current for the LAH, PC &FC Fan is lower than expected
Primary Action: Check the 6 way fan/LAH, connector at module.
Fault Code 12
Reason: The current for the LAH, PC &FC Fan is higher than expected
Fault Code 13
Reason: LAH is drawing less current than expected.
Primary Action: LAH open circuit
Fault Code 14
Reason: LAH is drawing higher current than expected.
Primary Action: Check wiring connection
Fault Code 15
Reason: PC fan is drawing less current than expected.
Primary Action: PC fan open circuit
Fault Code 16
Reason: PC fan is drawing higher than expected current
Primary Action: Check fan wiring or connections
Fault Code 17
Reason: FC fan is drawing less current than expected.
Primary Action: FC fan open circuit
Fault Code 18
Reason: FC fan is drawing higher current than expected.
Primary Action: Check FC fan & wiring circuit
There are also Ice maker faults that are NOT included above. This should get you started and if everything passes above diagnosis the problem is most likely in your ice maker circuit. The reason I did not include ice maker faults is because they do not cause alarms.
Thanks for choosing FixYa,
Kelly
Posted on Mar 15, 2011
Fisher Paykel RF175WDRX1. Why does the fridge beep when I open it?
check the thermostat setting for the compartment
it may not be set low enough so the alarm goes off when the compartment temperature reaches or exceeds that setting
some fridges have a system whereby if the door is open too long then it notifies the user to close the door
May 21, 2015 | Fisher Paykel RF175WDRX1 Fisher & Paykel...
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
Our upside down fridge/freezer started to beep. Upon opening the fridge the thermostat lights on the back was flashing red then green then red again anyone help?
This is a connection issue between one of the temperature sensors and the electronics, the plugs on the sensors need to be removed and cleaned with contact cleaner and you need to make sure that the contact are pushing firmly against the circuit boards, there are 2 control units, one behind the fridge beside the compressor and one in the back of the fridge which you get to by simply pulling the middle rear panel out after removing the shelves, just be careful as you can damage the plastic.
Mar 05, 2012 | Fisher and Paykel Active Smart E522B...
Ice building up back of freezer and fridge not cooling this is a fisher and paykel active smart fridge frezzzer
I dont work on that brand, however you describe a typical defrost problem, could be the heater t-stat or defrost control.
Oct 05, 2010 | Fisher and Paykel Active Smart E522B...
F&P Active Smart E521TRE Removing freezer back panel
My fridge (E440T but I believe the E522B is similar) had a broken fan wire and i had to pull off the rear panel and re-solder a wire. I created a document for others to follow that shows the rear panel removal if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
Nov 06, 2008 | Fisher and Paykel Active Smart® E522BR...
Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
Jun 07, 2008 | Fisher and Paykel Active Smart® E522BR...
I have a Fisher and Pykel Fridge / freezer Active Smart
on reading the user manuals, it suggests actually calling the F&P customer service numbers and telling them the pattern of the lights flashing.
They can ?diagnose the fault from the light sequence and can then tell you what u need to have fixed.
Dec 21, 2007 | Fisher and Paykel Active Smart E522B...
Fisher Paykel fridge stopped working
youre meant to if moved, let it sit for atleast an hour before turning on because moving it disrupts the gas inside. Did you do that?
Nov 28, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
477 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
