Question about Toshiba Satellite P105-S6104 Notebook
Very thin vertical lines on display that won't go away
I have an issue with some photos I tried to send to my daughter about a month ago. My system go stuck and Microsofl had to un-stick it. Right after then when closing down some file got stuck when logging off and the
result was four very thin lines up and down the entire screen and the first two are very close together and the other two are spread apart. They are very annoying and interfere with my other programs etc
  • 4 Answers
This might be a software issue with your video driver (follow Microsoft's built-in Help to test that, and look for an updated driver for your particular hardware) but it is fairly unlikely to be a driver issue. The thin lines running through your screen are usually due to screen failure -- hope you have your warranty, because this is a hardware issue and usually pretty expensive if you're out of pocket.
Posted on Aug 01, 2008
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Sony wega kde-61xbr950
Can be a problem with a misplaced connection, more likely the Ysus card to be replaced.
Aug 30, 2008 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
Thin black/transparent vertical lines across the screen
If the lines aren't appear at least in one input or in smart apps then theres no posibility that the time-control is malfunctioning.the more logical is mainboard is isn't working right . could you provide me with more info and maybe a photo i'm sure I can get you a better and more advanced answer to that
Jun 23, 2014 | LG 55LM6200 55 1080p 120Hz 3D WiFi LED...
Thin white lines on photos
Are the white lines horizontal or vertical?
Try to clean the contacts.
Horizontal lines = print carriage issue
Vertical = rollers
Feb 13, 2011 | HP Office Equipment & Supplies
I have a thin vertical line about 9"from left side runs top to b
either a bad buffer pcb or display panel, 12 month warranty call panasonic quick
Aug 08, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Vertical thin linings on lcd monitor
pull out your memory sticks and reboot with one of the two. if you nonly have one barrow one from some one else
Dec 30, 2007 | HP Pavilion dv4000 Notebook
Fine lines running vertically in screen
First, which model of Toshiba notebook do you have? Check it's bottom label- it will say "Toshiba" and have the model on it.
Then, try to update the display drivers. You can download them at www.toshibadirect.com/support. If that doesn't work, you may have an issue with the BIOS or the display itself.
Dec 10, 2007 | Compaq Presario M2000 Notebook
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Toshiba Satellite P105-S6104 Notebook Logo
71 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
