Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Spa will not stsrt it just buzzes and trips off
  • 40 Answers
Pump moror is seized or something is stuck in the impeller
Posted on Mar 29, 2011
Power trips out when jets are switched on
I'm going on somewhat limited information here not knowing if the tub is newly installed or if this is a spa that has been working in the past and just started doing this. It would be helpful to know if this is a recently installed pump as well. That said here are a few things to check.
If it's a new install: Your electrician has more than likely wired the spa incorrectly. Be sure that the spa pack has 220V going into the pack and that the GFCI is wired correctly.
If it's an old spa with a new problem: A lot of times a bad heater element can cause a spa to trip the breaker. If you have a bad element the spa will operate normally for about a minute when you turn the power on, then trip the breaker as soon as the heater kicks in.
If it only trips the breaker when the pump is turned on to high speed, more than likely there is a problem with the wiring of the pump or the relay on the pump itself.
May 04, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Why is the gfci tripping on my hot tub after being on for 30 min. After resetting the breaker after the 30 min. run, it trips immediately!!!
You will want to make sure that all of your spa equipment is functioning properly. It is best for a spa technician or electrician to determine this issue.
It is likely that a particular piece of equipment is turning on around the 30 min time frame and causing the breaker to trip. Pump, ozonator or similar. Also check the heater element, a pin sized hole in the element will cause it to fail. Lastly your spas breaker itself could be bad.
Nov 20, 2012 | Pool & Spa
When i turn the switch on the pump buzzes and wont start , then trips the breaker . Help .
Either the pump is seized or the motor start capacitor is open or blown. If you can spin the impeller with your finger it is most likely a start capacitor problem.
Aug 20, 2011 | Sta Rite 1 HP StaRite Pump 15" inout...
Pump makes buzzing noise but does not run. shortly thereafter it trips circuit breaker.
The first thing to check is if the pump is siezed up and stopping the motor or if the motor is bad....
Take the motor off of the pump and check to see if the pump will spin... then check if the motor will run without the pump onit...
This will tell you if you have a bad motor or a bad pump...
heatman101
Feb 21, 2011 | AO Smith Centurion 1081 2 Hp Standard...
Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
May 08, 2010 | Pool & Spa
Spa keeps tripping breaker shows pr
two main reasons breaker trips is the pump motor jammed [not turning]or the heater shorted out --disconnect power open access panel disconnect the lines to the heater turn on power if breaker trips than motor /pump problem if doesnt trip than heater problem can order heater replacement online or pool spa store--if motor pump check pump for debris and motor for lube if u can turn shaft or impeller oil motor and work it into bearings if still not turning possible need to replace motor unit
Apr 26, 2010 | Heritage Pool & Spa
USQ1102 pump gets power, buzzes, trips breaker
The motor-start capacitor is bad. This is a very common problem. It can be easily and cheaply fixed by replacing the capacitor. Replacements are usually less than $10.
See http://www.youtube.com/watch?v=ZEIv5ClLqXg for a step=by=step guide.
When you have the capacitor in hand, check the model# which is printed on it. Alternatively, you can Google the motor brand & model to find the parts list which will identify the right one. Then Google the part number, to find a seller.
Jun 27, 2009 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
99 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
