Question about Sport & Outdoor - Others
I can't find the charger for my coleman pmj8161a jumpstart system - can you purchase one individually?
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
I own a Vector Industrial Series 900 to jumpstart system and power. When we recently moved the cord was lost and now I am in need of buying the new cord. Is this availale?
I advise caution when using a standard battery charger to charge a jumpstarter via the main leads. Firstly if there is polarity protection it probably won't work and secondly the heart of the jumpstarter is a sealed lead acid battery which does not usually tolerate high charge currents without shortening the life of the battery.
This type of battery needs either the low charge current supplied by the original charger or similar or a sophisticated regulated charger.
If using a standard charger avoid using a high performance type and use only the type that provides a trickle charge.
Apr 07, 2014 | JUMP START SYSTEM
Battery and charger
You can get aftermarket 18V rechargeable batteries that may interchange with your Coleman battery and may even use the same 18V charger
May 11, 2013 | Coleman Cable Coleman 18 Volt Combo Drill...
Will a ryobi 18 volt charger replace a coleman powermate battery charger?What's your problem?
They look different in their shape where the battery goes so I would say no. To be safe always use the charger from the same manufacturer. There are a few different types of batteries too so it is always best to use the model number of your original charger to search for the replacement.
Aug 08, 2012 | Coleman Cable Coleman 18 Volt Combo Drill...
I just changed my oil and Now the car won't start.
Your battery needs to be around 12.6 volts to start. Try jumpstarting your vehicle, or purchase a cheap battery charger for around 20$, and let it charge for a couple hours.
Jun 26, 2011 | 2006 Cadillac CTS
Does the coleman charger 1 spotlight model # 5347a718 need a battery
Yes it does.
See the product details at the following links:
http://www.amazon.co.uk/Coleman-Charger-One-Chargeable-Sportlight/dp/B0002JSZVU
http://www.coleman.com/coleman/parts/ProductImage2.asp?product_id=5347A718
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Good luck.
Apr 15, 2011 | Coleman Camping, Backpacking & Hiking
Looking for charger for cordless 19.2v drill
I couldn't find one, looking everywhere. The newer Coleman chargers are a different size. The red charging light would not come on. Using a meter, I figured out it wasn't the charger, but the power adapter. I found one online that fixed my problem and now I can charge my batteries for my Coleman impact drill. From Digikey.com
http://search.digikey.com/scripts/DkSearch/dksus.dll?x=0&y=0&lang=en&site=us&KeyWords=454-1403-nd
Nov 20, 2009 | Drills
IBM thinkpad t42 new Battery "On line, critical"
The only way is to continue using it that way till it will not go off when you unplug.
The charger might have gone bad too.
Try the first method then replace charger.
Mar 18, 2009 | IBM ThinkPad T42 Notebook
Will not jumpstart
To recharge this unit at home use the AC charging adapter. Plug one end of the adapter into the AC/DC charger input port. Which is marked as number 7 on the image below. Then plug the other end of the adapter into a standard wall outlet. The charging port is located on the front of your power center and looks like the image below. If you did not get an AC charging adapter with your power center check the manual to see exactly what type you need. You will need to know the Voltage and AMPs of the adapter. Go to Radio Shack or an electronics store and purchase an adapter. It is very important that you make sure you get the right one. Your manual should tell you how many hours it takes to completely charge your power center.
Mar 13, 2009 | Power Center Jumpstart 11-411
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
