Question about Craftsman Vacuums
I am renting a house with a craftsman .5 horsepower garage door opener. We had a storm that knocked out power for quite awhile. I had to open the door manually (pulled the emergency cord). Now I can't get it back to automatic mode.
    Problem Solver:
  • 5 Answers
Try jerking the emergency cord the oppisite way to put it back in gear and the door must be up all the way open
Posted on Mar 15, 2011
What is 700a shop vac motor size
Craftsman 17765 canister vacuum cleaner is known for its assortment of power tools especially when it comes to cleaning jobs. It is designed to give you an easier, more effective cleaning. This vacuum cleaner delivers a high capacity reservoir, power and the versatility to swap easily between tasks. Craftsman wet/dry vaccums soaks even drosp of water on the floor with one of their 16 gallon wet/dry vacuum. It is also equipped with utility nozzle, extension wands, and dust bag that makes the cleaning process easier. The extension wands can clean the hard to reach areas like cupboards, corners, and bends. It has a large gallon tank that includes convenient drain port for easy emptying when the job is done.
Number of Tools:
Attachment Type:
Brush
Details and Capabilities
Cord Length:
Tank / Bag Capacity:
12 Gallons
Weight:
Hose Reach:
Cleaning Areas:
Car
Electricity
Horsepower:
5 HP
Voltage:
110 - 120 V AC
Power Consumption:
1210 Watts
Jul 09, 2014 | Craftsman 17765 Canister Wet/Dry Vacuum
Unable to open garage door with new craftsman system
Somehow this Garage Door opener problem ended up in with Vacuums!
Try again-- and make sure it gets in with Garage door openers!
Jul 03, 2011 | Vacuums
After a brief power outage my Marantec 4700 garage door opener has problems opening/closing. When opening it stops at the fully open position and the lights blink, when closing it automatically reverses...
This is not a sensor issue, I have a similar problem, sensors work fine, garage door is still fully functional, all operations, including safety sensors work properly, just the overhead lights flash. I suspect there was damage to the power board due to a power surge, going to order a replacement to see if it works, will let you know how it goes.
May 14, 2011 | Vacuums
T.he light on the garage door opener does not come on when the garage door goes up or down. Why?
Either the bulb blown or not wired right when installed. should have one red wire, one black wire and a ground wire, green or copper.
Dec 23, 2010 | Craftsman Vacuums
I have a Chamberlain Liftmaster Professional 1/3 hp garage door opener. I'm unable to find the model number, but it was made in April 2004 and has an orange learn button. It has been working fine since...
Do you mean the numeric keypad is no longer controlling the garage door? If so, have you changed the battery for the keypad? Frequently, if the battery is low, the keypad will stop working when the door is closed but works to close an open door. On most Chamberlain garage door openers, this is a 9V battery. You may need a small Philips screw driver to open the battery compartment at the bottom of the keypad.
After changing the battery, try the learn code procedure again. I've found it easiest to have two people involved when programming the keypad to the garage door opener. One handles the Learn button and the other types in the desired code.
I hope this helps.
May 22, 2017 | Vacuums
I have a Liftmaster garage door opener and the garage door faces south. Normally the opener works great except at certain times on a sunny day.The sunlight is not directly hitting one of the sensors but...
Sounds like a problem with a limit switch or something getting in the way of the electric eye that interrupts for safety reasons. Clean the electric eye transmitter and sensor of debris and cobwebs and make sure the wires are attached properly. Check the operation of the lifting media track or chain. Has it been lubricated recently? If possible, clean the switch in the transmitter in the car, it may be shorting out.
Aug 28, 2010 | Vacuums
I have a raynor flight star garage opener. Had a lighting strike 4 days ago. All power is good. The opener even has a little green light on the switch that is attached to it. However the opener is not...
You could always try unplugging the unit and plugging it back in. If that doesn't work the logic board is probably fried and unfortunately there is no replacement available for it any longer. You would need to buy a new opener. I'd recommend Liftmaster.
Jun 10, 2010 | Vacuums
I have an older craftsman garage door opener and replacing the keypad. do i have to do anything special
no they all work the same once the password is entered it allows the voltage to pass.just install it and program the password that's it.
Feb 02, 2010 | Vacuums
Vacuums Logo
43 people viewed this question
Top Craftsman Vacuums Experts
Tim Doolittle
Tim Doolittle
 steve
steve
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
