Question about Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera
When I turn on camera it says "memory card error. What do I do?
    Sergeant:
  • 162 Answers
Is your memory card in the camera. If it is there is your camera compatible with the card that you bought. Also do you check to make sure the card is not write protected. There is a small switch on the side of the card.
Posted on Mar 15, 2011
SOURCE: no memory card error on canon powershot a400
Maybe you have to format the card before the camera recognizes it
Posted on Jan 13, 2008
RadarRon
  • 398 Answers
SOURCE: Memory Card Error
Chances are that the contacts in the card slot are either dirty or worn out. First thing I would try would be to try blow out the card slot. I suggest caned air, You could use a straw and Puffs of breath, but keep it dry. If that doesn’t work put a lint free cloth over a piece of cardboard about the same size as a memory stick. Be vary careful that it is not thicker then the memory stick. Dampen the end with Alcohol (Denatured Alcohol is best but standard rubbing alcohol might work in a pinch). I repeat, dampen with alcohol not dripping wet. Remove the battery just to be sure. Insert the swab into the card slot a half of a dozen times when you pull it out look to see if you see any residue on the swab. Hopefully you see dark stripes on the cloth. Let the camera sit with an empty slot (and no battery) for a hour before you try it again.
If all that fails the last chance (short of replacing the card reader) try to put some electrical tape on the memory stick on the side opposite from the gold contacts, be carful not to cover the contacts. Try one piece of type at a time and DON’T force the memory stick into the slot This will slightly increase the pressure on the contacts inside the card reader slot. If you have to resort to this be carful that the tape sticks completely and that it is neatly trimmed, you don’t want the type coming off inside the cameras. If this works you will need to add tape to all memory sticks used in this camera. I would NOT use any “taped” sticks in any other readers without removing the tape first.
Posted on Feb 12, 2008
  • 13 Answers
SOURCE: CAMERA READS -CARD ERROR-AFTER INSERTING A NEW MEMORY CARD
First, make sure that the new memory card does not have the protect tab in the lock position. The new card must be unlocked and formatted before your camera will be able to use it. Also, make sure that the size card that you have purchased has not over shot the ability of your camera. I think that a 2 GB card is as large as you can use. Just because the card fits into the slot does not mean that the camera will address it!
Posted on Apr 23, 2008
alfa104
  • 78 Answers
SOURCE: 16G Memory Gets "Memory card Error Please Check Memory Card"
Iam sorrie but try a other sd card and it will work..
Posted on Jun 19, 2009
  • 11967 Answers
SOURCE: every time the camera is turned on it says memory
Move the slide switch on the side of the card.
Posted on Oct 14, 2009
Testimonial: "thanks tried that did nt work"
No Memory Card error
Check to see the largest capacity card that the camera will accept - if you are trying to use cards larger than this, I would expect this error.
Jul 28, 2017 | Canon PowerShot A70 Digital Camera
Tip
How To Fix You Camera's "Card Error" or "Card Not Initialized" Message
When you recieve a "Card Error" or "Card Not Initialized" message, this indicates that your memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most consumers will use the "delete all" feature and continue to take pictures. By doing this, the file format of the card may become unstable.<br /><br />We recommend formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted, the images will not be recoverable.<br /> <br /> If this doesn't fix the Card Error, try replacing your batteries with a new, fresh pair of batteries. Also, if you haven't tried already, replace the memory card with a known working card and see if this fixes your error.
on Feb 14, 2011 | Cameras
Card error message
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Troubleshooting steps may be found here.
And here's a video summary of these steps:
May 20, 2012 | Casio Exilim Zoom Ex-z35 12.1 Mp Digital...
No memory card error
You need to change the memory card with new one, because memory card got corrupted and needs replacement.
Thanks
Feb 24, 2012 | Canon PowerShot SD1000 Digital Camera
When turned on, says "memory card error! reinsert
Remove the card from the camera and use the card reader on your PC to scan the memory card. It is possible there are errors on the card. If so format after copying all the files from the card. Now if the camera shows an error the fault is with an interface issue with the motherboard. make sure that the card holder tray is clean, blow air to dispel any dirt and also try with another card to confirm the case.
Oct 24, 2011 | JVC GZ-MC500 Memory Card Camcorder
I keep getting "card locked!"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Troubleshooting steps for this problem are listed here.
Aug 24, 2011 | Canon PowerShot SD960 IS Digital Camera
I have Panasonic Lumix FX9 and I have an original 16mb memory sd card that is working but when I put another card the camera says "memory card error please check tha card" and I don`t know what...
Welcome to FixYa.
One possible reason why do you get a "memory card" error is because the memory card is not yet formatted for camera use. Try to format the memory card using the camera itself. Do not use another camera or PC's when formatting the memory card,it may cause another error because it will not recognized by the camera.
Try also to clean the memory slot by using a soft and dry cloth. Then turn on the camera again.
If the message still persist, you neen to contact Panasonic service center.
Please let me know if you have any questions or if this solution was helpful.
Thank you for using FixYa.
Apr 15, 2011 | Panasonic Lumix DMC-FX9 Digital Camera
My name is Madhu. I use the camera Canon EOS 400D / Digital Rebel XTi. When the inbuilt FLASH is on then a message pop up as "busy now", when i tried to click the camera to take a photo then...
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you
Apr 04, 2011 | Canon Rebel XTi / EOS 400D (body only)...
Turn on the camera. "Memory Card Error" displays.
You'd better change a new memory card that doesn't have a problem to check whether it is matter of Canon PowerShot A480,or use another well camera to check if it is error of your memory card.
Feb 17, 2011 | Canon PowerShot A480 Digital Camera
Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera Logo
55 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
