SOURCE: remote instructions
Try this:
http://www.hapm.hitachi-asia.com/index/techsupp/operationmanual/RAS_RAC-32CNH2(EN).pdf
It's a different model than mine, but the remote and the commands appear to be similar.
SOURCE: screen too big for mitsubishi black diamond tv
It was actually a problem with the satellite feed, not the TV. Dish Network was zoomed in, hitting the asterisk button on the dish remote fixed the problem.
SOURCE: PSU or inverter problem?
I would recomend replacing the 11 caps on the inverter as 90% of the time its failed capacitors on the inverter. If you shine a bright light into the screen can you see the pic? Thats usually one of the first things I do when I suspect bad caps on the inverter.
SOURCE: I have a used Delonghi Air conditioner model PAC u30
See if you can search for the website of the manufacturer. Most have manuals for their units that you can download and print. You will need to find the model number of the equipment before you begin. Should be a tag on it with the model and serial number.
