Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub-Zero 561 The termperature within the refrigerator fluctuates between 45 and 60 F. The lower 1/2 of the back wall of the refrigerator is covered with frost (about 1/16" thick). The freezer works fine.
  • Anonymous Nov 30, 2008
    freezer seems fine, the fridge is warm and ice in the lower left side. We had fixed in the past and was very expensive - and did not last.
  • Sub-Zero Master
  • 5,568 Answers
You are number 3 in the series this AM-
As you probably know, the recommended temperature range is between 35-45 F so if you control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be a problem with your brand; I'd check to see if there is a recall or factory 'fix' for this. They may have gotten a batch of defective sensors or controllers.
Posted on Sep 13, 2008
Sub zero freezer freezing up on outside back panel line causing rust and melting
Is it on the copper tubing coming out the back? Insulate the pipework with foam insulation. If it's on the back of the freezer. the wall insulation has blown (not repairable)
Apr 19, 2014 | Sub-Zero 561 / F
My sub zero model 561 refrigerator side is not working
The fridge side or the freezer side? not cooling, or just no lights? Nothing is cooling or lighting?
Sep 18, 2013 | Sub-Zero 561 / F
1988 sub zero refrigerator's freezer is warm on the top and not making ice
Sounds like you have a fan problem around the evaporator in the freezer, it is possible it has failed and won't move air within the freezer section anymore. Cold air drops and heat rises.
Good Luck
Mar 21, 2013 | Sub-Zero 561 / F
Our sub-zero refrigerator has not been cooling properly and mold builds up near the bottom
My Sub Zero 561 would lose cooling in the main fridge area over time and I would usually turn the thermostat down. This helped but I'd get an ice buildup on the back wall of the fridge, especially if it was packed full of stuff and didn't allow for air movement. I finally removed everything, removed the back panel to the fridge, and discovered that the entire rear area was a solid block of ice. A defrost fixed it but I had to turn up the thermostat to keep it from coming back. Now it works great after driving me crazy for years.
Jun 02, 2012 | Sub-Zero 561 / F
I have a sub zero 561. The freezer works properly but the refrigerator is not cold enough. I turned temperature from 5 to 7 but no change
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Sub-Zero 561 / F
Sub Zero 561 Refrigerator side is not cooling." the freezer side is working perfect.."
pop the top panel and clean your condenser,this is the most common problem,other than that it could be your compressor or refrigerant leak.this model i believe is two separate systems so one will not effect the other/. good luck!
Jan 17, 2010 | Sub-Zero 561 / F
My side by side sub zero fridge has frost building up on the back wall of the refridger ator side it is about 1/2 inch thick
I had the exact same problem. It was the evaporator coil had a leak. The coil is covered under waranty the labor is not! It was $295.00 labor and $48.00 for the gas recharge.total $343.00. Hope this helps! Yes, the price was high but it fixed the problem.
Part # was 4204420
Ed
May 27, 2009 | Sub-Zero 690 Side by Side Refrigerator
My sub zero model 561 dosent't cool when the weather outside is h
I had the same problem with my sub zero. I took off the grill on the top and vacuumed the coil that has the fan in front of it. The problem has not happened since. I'ts worth a try.
Apr 26, 2009 | Sub-Zero 561 / F
NEED ORIGINAL DOORS ON MY 561 SUB ZERO LOOKS LIKE DOORS ON FRONT
Given the model serial number I could get your decorative panels. The door itself is a framed door and designed to take a 1/4" insert. You can have new panels made if you have changed the cabinets, order stainless steel panels or put another material of your choosing. If you would like the more about the panels reply with mod and ser number which is in the freezer door jamb at eye level. Open the door past 90 degrees and look in.
Jan 19, 2009 | Sub-Zero 561 / F
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
197 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
