Question about Canon Office Equipment & Supplies
I use Canon MP 280,but I can not scan any document,the machine warming that cannot communicate with scanner,code 2155.50,I check the cable,no problem,because i can print any file,ink pot is also full,what s it? How can I slove it ? please,help me
  • vivhoang172 Mar 18, 2011
    Thanks for your help..but I couldn't connect to the link..Could you share another link for me..Thank so much..
  • Mary Harmacinski Apr 26, 2013
    I had the same problem till iswitched the stock usb cable with a usb full duplex cord. Now it scans like a dream:)
5 Suggested Answers
SOURCE: canon pixma mp830 will not scan
I am experiencing the same problem, from the equipment id does not scan
Posted on Jun 09, 2008
SOURCE: Canon Mp 210 Scanner printer
go into administrative tools click on services and make sure windows image acquisition (WIA) is on manual
Posted on Feb 27, 2009
SOURCE: Canon pixma mp 190 won't scan / copy and printing works!
I also have a newly purchased MP 190 that prints but will not scan at all have also tried reinstalling software.
anyone help me?? :(
Posted on Oct 04, 2009
old marine
  • 2016 Answers
SOURCE: I have a cannon MP 160 printer/scanner. It does not work on a Mac
Uninstall all your drivers (and delete the preferences) and download the Mac drivers from this link. The drivers that came with your printer were developed before Snow Leopard came out.
Posted on Jan 21, 2010
Testimonial: "thanks, this worked really well. I can now scan and print OK. Thanks Job well done."
In canon ir 2016 there is no scanner movement & also the laser lamp is not glowing & the machine is indicating check document
In canon IR 2016j, if you get error " check document", its a communication error. so you check the flat cables in control board ( is a board in the scanning section)
* Change cable from scanning lamp
* change 2 cables from ip board.
Jun 12, 2012 | Office Equipment & Supplies
I have a canon MG5220 printer and unable to scan properly the messages I receive are saying Scanner turned off, disconnected from LAN, code 2,145,50. Printing pictures and all other printing jobs work...
Regarding the Cannon scanner error 2145,50. I note you have tried to fix this, but failed. The actual problem is that the scanner will not communicate with the computer correctly if it is connected through a USB hub. A direct connection to the computer cures it.
I know, I had that problem. I am a retired elctronics design engineer.
Mar 07, 2011 | Canon Pixma MG5220 InkJet Printer
How do I scan a document?
Do you have the full software installed or just the basic driver from Canon? What OS are you using? http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#DriversAndSoftware has the software and drivers. If you installed the OS driver, you should uninstall that, disconnect the data cable and then install the driver from Canon. The generic OS driver usually only runs the printer.
Place the document face down on the scanner glass or face up if you have an ADF. Check that the all-in-one and the computer have good bi-directional communication. (Direct USB connection (if you are using that), replace cables if the printer works but not the scanner and the Canon software is installed.)
If you are using the Canon software, you need to set up the destinations for the buttons and have the monitoring software running. Thus start scanning from the computer at first. Launch MP Navigator and then click on the type of document you want to scan. Find the resolution and contrast that works for you. Use these in setting the button defaults (see the manual from Canon). Then click Scan.
Alternately, with Windows XP, Vista and Win7, you can scan with software that came with the OS. Paint is available on all of these OS versions (File > Import from camera scanner > from scanner). Vista includes PhotoGallery which works like Paint (this can be downloaded for XP and Win7). Vista and Win7 also can scan with Windows Fax and Scan (New Scan).
When you have the MP Navigator properly set up, you will be able to launch a scan from the printer. Press the Scan button and the software will launch.
I hope this helps.
Mar 04, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I want to scan documents with my Pixma MP 150
Scanning using the Operation Panel 1. Place the document face-down on the platen glass.
2. Press the [Scan] button on the machine.
MP Navigator starts on the connected computer. You can scan in documents placed on the platen glass using MP Navigator.
Oct 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
anyone help me?? :(
Jun 06, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma Cannot communicate with scanner
Hello do You have a program CD Record, then pu it in Your computer and then trhy to download a scaners software.
Mar 12, 2017 | Canon Pixma MP500 All-In-One InkJet...
Cannot scan to pc
my MP 160 cannot scan to pc, but can print and photocopy well. it says it cannot communicate with scanner..cable might be disconnected or scanner might be off..tried uninstalling and reinstalling..still doesn't work
May 21, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP 470 Not Scannin
I have the printer. You need to scan through your image software on your desktop. The button on the scanner does not function.
With your image software, there should be an "Import from Camera" and "Import from Scanner." Pick the latter, and it will prompt you through the process.
Took quite awhile to figure that out.
Toby
Mar 21, 2008 | Canon PIXMA MP470 All-in-One Printer
Scanner connection to the PC
i solved mine by replacing the usb cable with one that is 2.00 high speed and inti noise shelded benton-r
Nov 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
630 people viewed this question
old marine
old marine
