My Heat Surge was working fine, then it just went out. It is plugged in, but when I tried to start it again, it wouldn't light. HELP!
    Brigadier General:
  • 4,736 Answers
Tirn the Master ON/OFF switch to OFF. Unplug the unit for 12 to 15 minutes. This should allow the unit to reset itself. Plug the unit back in and turn the Master Switch to ON. If it reset itself, it should work normally. If it doesn't test the wall outlet it's plug into to make sure it still has power. Unplug the heater and plug in a lamp to see if it works. If it doesn't the circuit breaker in your homes breaker panel has been tripped and needs to be reset. More than likely, your Heat Surge Heater tripped the breaker, because of a malfunction.
Hope this helps solve your problem.
Posted on Mar 15, 2011
2004 Alero wont start!
sound like theft security problem.when you try ten minutes did you leave ignition switch on position for ten minutes until the security light turn off then turn off ignition switch for 5 seconds then try starting vechicle.when you do 10 minute trick security light has to turn off or disappear when you see security light go off turn off switch 5 seconds then try starting vechicle.
May 22, 2013 | 2004 Oldsmobile Alero
My 98 Sentra does not turn over
Has the battery been load tested? do that first.
Apr 30, 2017 | 1998 Nissan Sentra
Truck broke down no fire.. replaced coil, ing mod,cap rotor.. got fire truck runs... truck down again no fire
I recently had a similar problem. I drive a 94 ram 1500 with the 3.9 6 cylinder. When I replaced the coil it started right up but then cut out and wouldn't start. So I wiggled the wire that plugs into the coil and tried to start it and it fired up again and the next day it wouldn't start. My problem was were the wires connected to the plug came loss. I went to the junk yard found any ram truck from 94 to 01 with either gas engine 3.9-5.2-5.9 and cut the plug off with decent amount of wire and installed it on mine and problem was solved. I also had a catalytic converter problem about 3 months after that was similar but it would start right up and run in neutral fine but when it gear it would bog down and eventually stall. Good luck.
Jul 26, 2011 | 1992 Dodge Dakota
I had to unplug my tv today (actually the TV is plugged into a surge protector, so I unplugged the surge protector.) when I plugged the surge protector back in the TV wouldn't go on (acts as if its...
There should be a surge release button on the surge protector to bring the protector back to normal (should be red in color) Some surge protection devices have this option so just check if your s has it. If that is not the case than I think that you might have blown a fuse in your TV.Might just have to open it up and change the fuse within with the same ratings, but please be careful because do have high voltages so get an experienced technician to do this for you.
Good Luck.
G.
Jun 29, 2011 | Televison & Video
I had a power outage and my computer when I tried to turn it back on after the power was turned back on. All it does is have a green light blink on the back of the tower and a small green light on the...
most likely the surge fried one of your ram chips... this is where i would start first sometimes the ram will work as a surge protection for your motherboard
Nov 18, 2010 | Computers & Internet
D-link WBR-2310 wont set up. A long time ago when we first bought this router, we had it set up and working fine. We kept getting disconnections every now and then so we bought a new Belkin router, which...
The issue I see is that the lights all are lighting up. I'd bet it is caused by some type of short or like a power outage or surge (remember surge protectors basically do nothing at all). If I were to guess, that's it. Other than that, I would flash the firmware back to original if it lets me.
Nov 27, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
The power went out in the house. When the power came back on the oven would not work. The pre-heat red light keeps blinking
turn the oven off and disconnect the power to it for 10 minutes, then re connect it and try it again, see if it resets the system controls, if not the power surge that sometimes occurs when power returns has damaged your range, most utility companies will pay to have this type of electrical appliance fixed due to there power surge, contact them for a claim form in the event the oven doesn't start working after the power is reconnected.
Oct 23, 2009 | Kenmore 94022 / 94024 / 94029 Electric...
Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
