Question about Fantom Computers & Internet
Ever since I purchased my 1TB Fantom Drives external HD, the power light has always glowed the usual bright blue for a little bit, but then it suddenly dims and i lose all transfer speed. Sometimes Windows Explorer even locks up. There's also a suspicious clicking noise.
  • 53 Answers
If the drive is clicking its usually the sign of a failing drive. If it still has warranty try and return it for a new drive.
Posted on Mar 15, 2011
Testimonial: "Thanks, That's kind of what I was thinking but I wasn't sure because it arrived like that, and it still mounts alright. "
  • hoocli
    hoocli Mar 15, 2011
    ya, unfortunately even brand new drives can't be guaranteed to work. It really sucks when you get broken stuff that is brand new.
I have a Fantom Titanium II 500 GB external hard drive. It is not being recognized on any of my Windows 7 computers (64 bit Gateway and 32 bit Lenovo). The light on the drive is a constant blue. I tried...
1. if you don't eject the eternal drive properly it could cause the controller board inside the case to fail.
.2. USB drives are to be eject by the windows feature never disconnect while drive is in the port without using the ejection feature.
3. check the drive in another port to see if it can be seen in the computer list.
if not you may a defective usb controller in the case. the drive can be remove and installed into a new case. The drive may not have been damaged.
4. A new case can be purchased at the local computer store.
Apr 24, 2011 | Fantom Titanium Hard Drive
I seem to have some problem with the power. Its not turning on, blue light indicator not on in the WD 1TB external powered device. assuming the data is intact, but the power is the only issue. How can this...
Purchase an "empty" enclosure, for about $30, and "transplant" the disk-drive from inside your enclosure into the new enclosure (and new power-supply). All your files will be accessible.
Dec 16, 2010 | Western Digital My Book Essential 1TB...
When i turn on my fantom green drive the green light keeps flashing
If the light turns on (mine was blue) but the drive is not recognized on your computer desktop that most likely means the drive does not have enough power. This happened to me too, and I took it to a computer expert and he said the drive was not even spinning. So it was either the external power source that broke or the internal power source, the power panel that broke. I took it to a batter plus and tested the wattage for the external power source and it was okay so then i took the entire drive apart and disconnected the naked hard drive from the power panel. Then I purchased "SATA to USB" cables (runs around 10-20 bucks) and connected the naked hard drive that way to the computer and it worked. So the problem is basically that the internal power panel is not working, and i had 2 fantom drives that both had this problem and they both worked after i did what i just said.. so I think your drive has the same problem since the light comes on but the drive is not spinning. Take it apart, buy some SATA to USB cables and it should work.
Sep 30, 2010 | Fantom Drives 120 GB Hard Drive
How do I replace power switch on fantom gforce 1tb external hard drive?
I have the same problem. These guys are clueless. I removed the warrenty sticker, undid the screws, and slid the hard drive bracket out easily with a little push. Unpleg the wire connecting the power switch to the board. Push the switch out from the inside, applying presure to the top and bottom. You've removed the faulty switch. Replacing it is my new problem.
Aug 19, 2010 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
Ext 500G Fantom HD turns on but won't boot up.
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Hard Drive to be detected automatically.
Kindly keep me posted about the problem
Hope this helps you out.
Nov 19, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
Fantom 1TB external USB drive failure, only half seen by MAC
the operating system may be corrupting format the hard disk drive the notice its behaviour
May 21, 2008 | Computers & Internet
Fantom Titanium Hard Drive - 500GB
You can remove the drive from the casing and connect it inside your pc, using IDE cables if its an IDE or a SATA cable, if it comes with one
Dec 26, 2007 | Fantom Titanium Hard Drive
Computers & Internet Logo
170 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
