Question about Frigidaire FTF530FS Front Load Washer
What should the ohm reading be if testing a door switch. model ftf530fs0 frigidaire
2 Suggested Answers
SOURCE: Frigidaire Laundry Center won't pump out water
The resistance of any mechanical switch is, practically speaking, 0.0 ohms.
If you are checking continuity across the two terminals of the lid switch, just use the continuity setting on the multimeter. If you get the audible signal with the switch closed the switch is good.
But, the lid switch has nothing to do with the drain function. The lid switch just keeps the tub from spinning with the lid up -- (given the picture at the top of your post is the machine in question).
If the mcahine won't pump but otherwise operates normally, first, I would suspect the pump could be malfunctioning.
Charlie
Posted on Aug 18, 2009
The door on my washer wont stay closed and lock
make this steps and fix it. God bless you
First to unlock depending on model. There will be a pull tab either under the lower kick panel, behind the filter cover, or under the top panel. Pull this tab to unlock the door. Now you can remove the clothes and water. Refer to the owners manual for the location of your emergency door pull tab.
Door Switch
You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further.
Oct 01, 2013 | Samsung Washing Machines
Siemens S 16 76 door will not open
Door Switch
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. Replace the main control is easy .
God bless you
Jun 09, 2013 | Washing Machines
Door is not unlocking
see the causes and fix it. God bless you
Door Switch
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Oct 16, 2012 | LG Washing Machines
My maytag front load washer door wont open and wont start either
see this causes and fix it. God bless you
Door Switch
http://www.appliancehelponline.com/washercontrolboard.html
Oct 15, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Unlock
Door Switch
Oct 02, 2012 | General Electric WCVH6800J Front Load...
Washer will reset timer and then unlocks door and water spills out what could this be
Door Switch
Sep 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
The soap socket in my machine wont open and the cover of the socket has removed from its place .. how do i open it ??
Door Switch
Sep 22, 2012 | Washing Machines
My Samsung SHS 1320 door lock display will not light up
see the causes and use the common sense.God bless you
Door Switch
Sep 19, 2012 | Washing Machines
Kenmore H2 Plus door won't open.
see the causes and fix it: God bless you
Door Switch
Jul 18, 2012 | Kenmore Washing Machines
Washer doesn't spin.
Try the motor controller, if you bought the unit before 2006 the part should have a 5 year warranty, check your manual. If not in Warranty the part is 178.99 average. The motor controller is in the back right corner of the machine. If you have a ohm meter check the motor for correct ohm readings, easy to do. The tech sheet inside the machine ( left side behind kick panel in a brown envelope) has the test procedure and ohm readings.
Jul 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
52 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
