Question about Dell Inspiron 6400 Notebook
I have Dell6400 inspiron .My Cd drive is not recognizing cd. I tried to install turbotax cd but does not recognize. Stating go to control panel and configure?
    Master:
  • 525 Answers
You may have a missing or bad driver for your cd drive. Try reinstalling the driver by going to device manager.
Posted on Mar 15, 2011
  • 902 Answers
Does it recognize any other cd? if not you might have to go to device manager, cd drive right click advance properties and select pio mode.
Dell Inspiron 1420 is not able to read empty cds or DVDS. My I go to properties it shows empty space as 0. When I try to burn a Cd it says " Insert a blank CD"
Stephen buddy, we need to talk. I do NOT understand anything you are trying to describe. Okay, so you installed a FRESH Operating System and now it is NOT recognizing your DVD-rom, right? Okay, restart the computer and let Windows load up fully. Check Control Panel and check your list of Devices. Sometimes, when you re-install and O.S., you may have to update the firmware or drivers for certain devices.
Feb 05, 2014 | Dell DVD-rom DVD Drive
I have a installation CD that will not install on my computer or show up in the control panel under camera and scanners. CD runs but will not install. computer does recognize photo printer but will not...
The CD drive may have failed. If this is not the case, may have to go into the CMOS setup, which comes up when you first boot the computer. Usually you have to press the DELETE key, F2, or something else to enter the setup.
Make sure the CD drive is recognized in the CMOS setup. If not, it may be a poor connection or the CD drive has failed.
Jul 13, 2011 | Kodak EasyShare CX7430 Digital Camera
Blank cd's are not recognized by the Dell Inspiron cd burner
I would first try removing the device in the control panel, system, device manager and then reinstalling the driver. There may be a problem caused by a windows update. In general CD drives rarely go bad. If the CD works say for a music CD then it should work for blank cd. You may also want to check the CD type. If you accidentally used a DVD, that won't work and in some of the older CD drives, they may not handle every type of CD format.
Good Luck
Feb 02, 2010 | Dell Computers & Internet
I have inserted a CD in my Dell Inspiron's CD-rom drive, but it is not recognizing it
Once you have inserted the CD but it will not recognized. Restart the unit press Delete or F2 go to BIOS SETUP you select the CD drive first boot and press F10 to save. Try to see if the drive the drive should be recognized.
Oct 04, 2009 | Dell Computers & Internet
Dell inspiron 1525 cd drive not recognizeing
ok what you do is go to control panel and system and then click ur driver and then install the dvd one
Aug 03, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
CD/DVD drive not recognized by system and not working at all!
in windows xp: go to start then control panel then system then hardware then device manager then remove anythig that even remotely looks lika a DVD drive then: shut down you computer when it restarts xp will look for and, install anything hooked up to it automaticly
Apr 28, 2009 | Dell Inspiron E1505 Notebook
Is it a bad mb ?
If the HDD is not recognized in the BIOS, windows will not be able to install on that drive. Did you move the HDD interposer from the old drive to the new one? (t is a small adapter that plugs on to the pins of the drive.) If you did, reinstall the interposer on the old drive, ensure it still works. If neither drive functions, then you may have a bad motherboard.
0x0000007B normally occurs when you try to install an older version of WIndows XP on a system with a newer HDD controller and the XP CD doesn't have the correct driver for the HDD controller. So if you get an error like this after getting the HDD to be recognized by the bios, then you may need the HDD controller driver too.
Mar 21, 2009 | Dell Inspiron B130 Notebook
Dell Inspiron 6400 Vista CD Drive Does Not Recognize CDs
Try to use dvd cleaner disk to clean the lens, if it doesnot work, i think you have to replace your drive , this happens with Dell alot. but try to clean it, uninstall then install the driver back and check if its work.
Best Regards
Mar 14, 2009 | Dell Inspiron 6400 Notebook
Dell CD/DVD shows up in 'My Computer' but doesn't recognize CD's
the cd player could be bad it doesn't seem to be reading anything. or your windows needs reloading because you have other programs overwriting each other and windows.too much on the drive defrag it
Dec 27, 2008 | Dell Inspiron 2200 Notebook
CD drive casusing problems
Since the CD drive is not being recognized, here are my suggestions:
1-Reseat the CD drive. In other words, remove it from its docking bay and plug it back in.
2-If that doesn't work, reload the driver for the CD drive.
3-If that doesn't work, replace the drive.
4-If that doesn't do it, you probably need a new motherboard.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating.
Thanks you, and have a super day!
Ron-
Nov 12, 2007 | Dell Inspiron 2200 Notebook
Dell Inspiron 6400 Notebook Logo
50 people viewed this question
Alun Cox
