Question about Dewalt DW821 heavy - duty 5"small angle grinder
On my DW821 the spindle does not engage the pinion gear and therefore does not spin
    Sergeant:
  • 259 Answers
It sounds like either the shaft or the gear is worn. Also when it is apart try to wiggle the gear or spindle shaft to check for worn bushings which would caus that problem.
Posted on Mar 15, 2011
I got a 1995 250 4x4 Suzuki quadrunner starter spin but engine want rotate
pull the starter
there is either a problem with the solenoid connecting the terminals inside before engaging the pinion gear (plunger disconnected from lever that moves the pinion gear forward
OR
the over run clutch of the pinion gear has failed and is not locking the gear in the drive position
Mar 05, 2016 | Suzuki Motorcycles
1990 zx10 starter just spins does not engage the motor to turn over how do I fix it I've already replace with a new starter...same issues...
the solenoid is not moving the pinion gear forward to engage in the flywheel so check that you have connected the wire from the starter switch correctly. Next point to check --if this is an auto matic vehicle ,check that the flex plate has not broken away and not in the position for the pinion gear to engage ti.
Jan 01, 2015 | Cars & Trucks
Pinion gear dosnt spin with the shaft
Hi Anonymous, if you are talking about the starter drive gear the insides have some type of components that centrifugal forces them to grab or lock into permanently fixed counterparts. Never had one apart but the gear only spins one way and locks the other way. If you have one that spins both ways it has failed and needs to be replaced. Good luck
Jan 17, 2014 | Harley Davidson Motorcycles
The pinion gear dosnt spin the shaft does
Starting problems
I am guessing that you have a problem properly engaging the starter pinion into the ring gear to start the engine Check the starter pinion for correct adjustment and check pinion teeth for wear. Check the ring gear for wear from where the pinion fails to engage properly before spinning.
Sep 23, 2013 | Honda Civic Cars & Trucks
I have a 1999 Gilera Runner 180FXR, New bat 12V 9 amps. Starter turns and spins pinion gear but won't engage starter ring. If it does it turns ver slow or won't turn engine over. In manual it
Yep, not enough amps to engage the starter clutch, and when ti does engage, not enough amps to turn the engine. You need a 12 amp battery.
Nov 17, 2012 | Motorcycles
When pushing the electric start button, the starter spins but does not engage to turn the motor
Starter motor spins, but does not engage
  1. Check the starter motor for a seized or binding pinion gear.
  2. Remove the flywheel inspection plate and check for a damaged ring gear.
Apr 30, 2011 | 2006 Yamaha V Star 1100 Silverado
Starter motor spins but the solonoid does not engage, after the car just shut down on the highway
Jan 23, 2011 | 2005 Chevrolet Aveo
Dewalt DW821 heavy - duty 5"small angle grinder Logo
83 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
