Question about LG Televison & Video
MY COMCAST REMOTE AND BOX DO NOT ADJUST THE TV VOLUME AND WILL NOT TURN THE TV ON AND OFF. THE LG TV IS 42LD450. I HAVE TRIED THE FOLLOWING REMOTE CODES 11265 10178 10700 10856 11178 11758 11993 20741
    President:
  • 1,140 Answers
Hello there,
You've missed several codes for LG televisions:
10030 10056 10442 10823 10829 11325 11423
Please try these then let me know if you need further assistance by clicking on "Add a Comment" below your question. It may be necessary to use the code search feature to get the remote to work with your TV. You should also note that not all Comcast remotes will work with all TVs. If the TV is newer than the remote, there may not be a code for your TV, but as LG is a major brand, there is a very good chance it will work.
Regards,
BElectric
Posted on Mar 16, 2011
  • DILLIGAF
    DILLIGAF Mar 16, 2011
    Please also try:
    11483 11436 10017 11004 11447
Mitsubishi CS-31205 TV Never had a remote for this great TV, but, accidentally pushed a button on my Comcast Cable remote and the TV is now in "Mute" mode. Not the Comcast box 'Mute' . Have...
You are supposed to be able to switch the Comcast Remote to TV mode and switch Mute on that remote to change back to standard volume. If that doesn't work try volume up on the TV. Otherwise if neither of those work then check Remotes.com for a replacement TV Remote.
Mar 09, 2011 | Televison & Video
I have the lg 42ld450 with 03.04.36 firmware. I want to unlock the usb port to play movies. I don't know how to access service menu. I have a dish network remote. Can anyone help?
Hi my nameis Mike Houston of DISH Network and I see you are trying to play movies throughyour LG TV. I will send a link to help program the remote to the LG TV, http://www.dishnetwork.com/SupportSection/power-scan-instructions.If the DISH remote is programmed to the TV and you still can not get into theService Menu you will need to refer to the TV manufacture, I will send the linkto help with that, http://www.lg.com/us/support/index.jsp.
Dec 30, 2010 | LG 42LD450 42 in TV
I have a LG 42LD450, I read and saw videos online showing that you can enable video playback through the USB port. I also read that u need a certain universal remote to access the service menu does anyone...
I used a Magnavox MG500S, some simply use a Comcast Cable remote, some just use a universal from radio shack......all in all....once you get the remote programmed to the TV you have to find its "Magic Button" to open the password screen........then enter code.(0413) for the remote I used. Some were using code 0000. All in all I guess it depends on the remote used.......sorry I cant help anymore than that.........then I can if you find the same remote I used!!!
Dec 04, 2010 | LG 42LD450 42 in TV
Sky remote code for lg 42LD450 42
hi code is 0206 works fine with mine
May 24, 2010 | LG 42LD450 42 in TV
LG LHB953 Theatre system volume control with comcast dvr 3
Try the help menu in the comcast remote. I believe you have to program it again for the LG to work the sound.
Jan 01, 2010 | Televison & Video
Remote doesn't control. batteries are good, but there is no apparent connection between the remote and the TV. It is in use with a Comcast turner-DVR, which works fine, but I have to turn on and adjust...
Are you using Comcast remote to control the TV? When you program the Comcast remote to control your TV, it will do two functions: on/off, and Volume control. The Comcast can also be programmed not to control the volume of the TV (TV volume will have to be set at about mid level manually, then the Comcast box will send out variable sound level to the TV), just on/off ONLY.
Oct 27, 2009 | Olevia 227-S11 27 in. LCD TV
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
Need memorex mt2274 tv code for comcast multi-control remote
I've had the problem this morning. Memorex codes are 10154, 10463, 10150, 10178, 10016, 10179, 10877, 11570, 11911, &11920. These are for the remote that is for the smaller digital box. I tried them all, and 11570 works for my model - the power shuts off, but the comcast remote will not turn the power back on. Volume works ok.
Jim
Oct 14, 2008 | Memorex MT2274 27" TV
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
SAP - I can't get my new TV out of Mono and into stereo.
Are you using a cable box sush as a Comcast cable box? If so then the volume control within the cable box is most likely not high enough for the TV to detect a stereo pilot signal. The Comcast remote (if thats what you have) still is programmed to operate the volume within thier box, the volume display will be at the top of the picture and it will be in white. Turn it up until the word "stereo" appears. then leave it at that setting and use your TV's volume control only.
Feb 13, 2007 | LG MU-42PM12X 42 in. HD-Ready Plasma...
Televison & Video Logo
Computer Repairing
Computer Repairing
