Question about Fisher and Paykel DS605I Built-in Dishwasher
The top drawer on our dishdrawers makes a clicking kind of noise for about the first 2 - 5 mins of being on. Then goes fine with the occassional clicking noise during the cycle. It is slightly noisier than the bottom drawer. When the cycle is finished there is a couple of inches of water left in the bottom, so the dishes don't dry properly. The bottom drawer works really well with no problems at all. What do you suggest?
  • 27 Answers
SOURCE: Fisher and Paykell DD601 V2 Top Drawer Overflowing
I suggest pressing the keylock and power button together, hold for 5 secs, the display will change orange, the display should read HP if it says LP, press the start button to make display read HP.Then press power button to store. You will need to manually removed the water from the machine before restarting
Posted on Jul 15, 2008
SOURCE: u3 code on fisher paykel dishdrawer how to reset?
This site tells you how to reset:
http://applianceguru.com/forum1/163.html
I have the same issue and will try this tonight to see if it helps.
Posted on Feb 18, 2009
RescueTech
  • 145 Answers
SOURCE: F&P Dishdrawer turns on and off, on and off by itself
Hi Aaron...
You wrote "I had a F1 problem that I cured by blow drying the control board"
I see techs on other sites telling people to "blow dry" the mains filter board (which has the flood sensor and controls lid motor operation) and it always makes me wince.
F1 is a flood condition. All you do by drying out the board is stop the machine from trying to tell you something is wrong with it. There is a reason why the board got wet in the first place. You won't cure anything by simply drying it out if there is an underlying condition causing a leak.
On your dishwasher, as you may or may not be aware, the lid is controlled by two motors that pull the lid down onto the top of the drawer in order to provide a seal. If, for some reason, the lid either does not come down on one or both sides or something is interfering with the lid's mechanical operation, the machine will leak, and the flood sensor will trip. The machine will appear to "go on by itself" and run the drain pump constantly.
The cure is to determine what happened.
Some possibilities:
1. Improper loading:
When someone places a tall dish, utensil, etc in the wrong position, it will "prop" the lid ajar when the lid comes down. A gap of even 1/4" can cause a leak. It is in cases such as this that drying out the mains filter board (yes it is called mains plural) will restore machine operation, as it was a temporary issue that caused the leak (More on this later).
2. Broken hose link support strap:
On older model 603's, there is a nylon strap that guides the hoses and wiring harness as you open and close the drawer. Over time, this strap can break right in the middle. What happens next, is when the drawer is closed, the strap gets caught between the lid and the drawer's edge, causing a leak. This is easy to see if you dis-engage the tub clips on the drawer rails and slide the drawer forward enough to see the strap behind the drawer. In a case such as this you can blow-dry that board all you want; it's not going to do much good, as the machine will leak again as soon as that strap gets caught in the lid. The fix is to replace the broken link support with the updated kit from Fisher Paykel, which is a part number 528437. You can purchase them here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=242&category_id=58
On double-drawer machines, I always replace both straps, even if only one is broken.
3. Worn or inoperative lid actuator/motor:
As mentioned, the lid is motorized. There are two motors, one on each side of the drawer. They can become worn mechanically, or they can fail electrically or fail to operate because that mains filter board is not sending the signal to one or both motors. The machine's main control board (the one where you select cycles) can also cause a problem.
There should be a detailed tech sheet behind the drawer (lower drawer on double units) that has instructions on how to put the machine in diagnostic mode and you can run the lid motors with the drawer open and check if one is not coming down. And again on older 603, the lid motors can stop working correctly. If they are tan in color, replace them with the new style, which are black in color and have rubber boots over the arms to keep water from running down the shafts and into the motor. Part numbers are 528112 and 528113 and are always changed as a pair. Lid motors can be obtained here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=240&category_id=58
Bad or damaged Mains Filter Board:
This needs to be read over carefully.
On older 603's there will be a GREY colored plastic cover over that board. This is a tipoff that you have the early model. The underside of that board in the area of the flood sensor is uncoated and the solid-state components are exposed to moisture. Over time, calcified deposits build up around the edge of the board on the side where the flood sensor protrudes. These deposits can cause a "phantom F1' condition where the machine thinks there is a leak but there isn't one. Whenever I speak to a customer on the techline who says "I am sure there is no leak but the F1 is activated" I tell them to examine the underside of the Mains board for these deposits. The other thing to be aware of with regard to "blow drying" the board, is that it will warp and sag in the center and this can break the tiny solder joints and cause all kinds of problems for you. The most recent version of this part has a nice, thick almost rubberized coating over the bottom of the board and it's much more durable that the first versions. it also comes with a WHITE colored plastic cover and this is how you can tell if you have newest version of the board. You always should replace the grey cover with the white one. You can get the updated part here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=248&category_id=58
I hope this info is useful to you.
Posted on Mar 14, 2009
  • 10865 Answers
SOURCE: leaking dish drawer
It sounds like your door seal is giving you a problem. Before you replace the seal try running the dishwasher on the highest heat cycle to help the seal conform to the door.
Posted on May 20, 2009
  • 677 Answers
SOURCE: Fisher Paykel Dishdrawer - White residue buildup inside
www.dishwasherfilter.com makes a filter that will filter the hard water before it enters your dishwasher. your dishes will be sparkling after the first load. it is very affordable and guaranteed to work. you will love it.
Posted on Aug 04, 2009
Fisher paykel dishdrawer bottom drawer washes fine leaves water in top drawer
At some point the two drawers individual drain hoses are joined using a "Y' type connector. Check this, and everything beyond this point for restrictions or blockage. It sounds like the bottom drawer is pumping its drain water out normally, but some of that water is backing up to the upper drawer. This is an installation or plumbing problem that is external of the dishdrawers.
Jul 25, 2016 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do I reset the f1 flood button . Dd603ss
Not sure if you have managed to fix the F1 problem with your dishdrawer. This is a common problem and occurs mainly due to water leaking into the base of the dishdrawer under the bottom drawer.
But if it is occuring only in one drawer then the power filter at the base of dishdrawer is faulty and needs replacement.
Otherwise make sure the mains power to dishdrawer is turned off. Pull out the bottom drawer and stack in some towels behind it if you can to remove the moisture sitting on the base. The flood switch is located there. Then take a hair dryer and run it down behind the drawer to dry things. Push drawer back and turn power back on. Now if you cannot reach the back of the drawer then you will have to pull the drawer out from its rail. Refer the installation manual for this. See link page 7.
You need to find the source of the lead, Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jul 05, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Top dishdrawer won't open no power
The most logical explanation is the controller in top drawer has packed up or the power board located at the base of dishwasher housing (under bottom drawer) has partially packed up and stopped supplying power to the top drawer controller. But another explanation is that the thermal relay in the top drawer (located inside the heater element assembly has cut off. This stops power to the controller. This is the most expensive to fix as the entire heater element assembly has to be replaced as the thermal relay is not separately accessible. How you want to isolate the problem and fix it depends on how comfortable you are with fixing electrical and electronic systems. This is a very sofisticated dishwasher and a small mistake is irreversible. By the way you can open the drawer by forcing it open but keep in mind not to try to shut it firmly again until you restore the controller power. Otherwise the lid seal or actuator motors will be damaged. Whatever you do, make sure the mains power is turned off if you work on the dishwasher circuits.
Feb 16, 2014 | Dishwashers
The time on now shows 107 instead of 127 min. drawer Fisher & Pakel double
your dishdrawer is in ECO mode. Press the ECO button on the program panel on top of drawer lid. This should restore the Heavy wash time to 127min.
Mar 29, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishdrawer cannot open
the power board at the base of the dishwasher under bottom drawer appears to have blown up. Take the bottom drawer out carefully to access the power board. Make sure the mains power is turned off.
The reason the bottom drawer is not getting back in is that lid seal actuators are stuck as the motors are in close position. Will reset to normal position once the power is restored. So don't try to push the drawer in as the lid seal will be damaged.
Feb 15, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Faulty top drawer on fp dishdraw can I disconnect powet to top unit to disable it
Unfortunately the power is distributed from the inside to the two drawers.
You will have to address the cause of the problem in the top drawer.
If you are good at electric repairs you could disconnect the power from the dishwasher power board itself, but this is not for the faint hearted (no offence). Might be helpful if you can provide a little details about the problem with top drawer. Generally if you are getting F1 message on the panel on bottom drawer and top drawer display is blank (ie no power), then the power board at the base of dishwasher is blown and needs to be replaced. Please clarify model number as the one you provided is for single drawer unit. Make sure the mains power is turned off when you work inside the diswasher.
Feb 05, 2013 | Fisher and Paykel DishDrawer DS605FDSM...
My model number is DD603 The top dishdrawer is draining into the bottom dishdrawer. What is the code to reset the drawers?
the check valve in the bottom drawer may be clogged or defective. the two drain hoses are probly connected to become one.
Jan 20, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel DD605SS
I can talk you through finding the fault on live chat. cheers
Mar 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
DD603HSS
there is only one power supply or input so you need to find out where the power stops from the bottom to the top drawer
Aug 18, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel DS605I Built-in Dishwasher Logo
75 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
