Question about Jenn-Air 30 in. Pro-Style Electric Single Wall Oven with Multi-Mode Convection
I had to pull my oven out of the wall and ever since I did that, I get a message that says "Feature Not Available" on any button I hit. Is there a reset button or something?
  • 33 Answers
It's an error code that will not go away until a technician resets it. Quote straight from the manual :
"The oven may detect a fault during programming or during operation. If a fault is
detected, the message "Fault detected - press power to clear" or "Fault detected -
press enter to try again" may appear. Follow directions in the display. If the fault
reappears or does not clear, call an authorized servicer or the toll-free number in the
display.
If the same operation is attempted before having the wall oven repaired, the message
"Feature not available" will appear. The feature will remain inoperable until service
is obtained":
Posted on Mar 15, 2011
Accidentally hit clean button on a Frigidaire Gallery Oven. Hit Cancel button. Oven door won't open.
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
Nov 20, 2014 | Frigidaire 30 in. Electric Gallery Series...
The power went off, when it came back on the oven time displayed. when we tried to turn on the oven the message feature not available came on
First try this: In your Household Circuit Panel, Turn the Circuit Breaker to the off position. Wait 30 Seconds and then turn it back on. Try to turn the oven on if it comes on you are in luck, if not look in your manual for first time set up instructions like setting the clock date and time, and go through the settings. Then try the oven again. If it comes on you are in luck.
Oct 15, 2014 | Whirlpool 24" Double Electric Built-In...
When I select bake, broil, etc, I get the message-feature not available
If is 6 months old call for warranty repair, turn off circuit breaker for a minute then repower this may clear it if not again call for warranty service
Jan 30, 2014 | Whirlpool RBD305PD Electric Double Oven
Oven not heating properly
most common problems:
1. calrod unit not working(heating element) easy replacement
2. breaker tripped.(sometimes a double breaker will only trip one of the circuit breakers so you end up with half power)
good luck
Jul 19, 2013 | Whirlpool Ovens
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
I own a wall oven/microwave combo, GE JKP76 and JKP77. I recently turned on the Autoclean function however, once completed the door remains locked and there is an error message flashing "F2" and...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Mar 05, 2011 | GE JKP15 Electric Single Oven
Whirlpool oven ''feature not available''
That happened to my fairly new Whirlpool double oven. But I remembeedr the power in the neighborhood had flickered earlier in the day. So I went to the circuit breaker and shutoff power to the oven for about 30 seconds and turned back on. Everything normal now. I just assumed the slight flicker in the power affected to programming.
Jan 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Our baking element went out so we replaced it, now the bake feature is on automatically even though we didn't hit the bake oven button to turn that element on
did u unplug the unit before u replaced the coil/element? if not, unplug it and wait 3min and replug see if thats it. ps: always unplug from wall or receptical before opening any unit or device for repair. please keep USA beautiful.
Aug 20, 2009 | Ovens
JJW9830DDS
THE SOLUTION WAS TO CALL FOR SERVICE. IF YOU CONTINUE TO USE THE UPPER OVEN , THEN THERE IS A POSSIBILTY IT CAN CAUSE A FIRE IF THE BLOWER IS NOT WORKING. THE COST OF THE REPAIR FOR REPLACING THE BLOWER WAS ABOUT $390.00. THEY NEED TO REMOVE THE OVEN FROM THE WALL CAVITY TO PERFORM THE REPAIR.
Mar 21, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air 30 in. Pro-Style Electric Single Wall Oven with Multi-Mode Convection Logo
323 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
