Question about E-Machines W6409 (7234) PC Desktop
I have an emachines W6409. I can add one DDR2 PC2-5300 1GB (PNY) to either memory slot along with the original 512MB in the other slot and all is well. Also, one of the DDR2 PC2-5300 1GB (PNY) in either slot alone works fine. As soon as I put both DDR2 PC2-5300 1GB (PNY) in, the computer does not boot, the fan just runs at high speed, and the orange hard drive activity light on the front of the case never illumintaes. Display does not receive a signal. Any ideas?
  • 64 Answers
My guess would be that one of the components can not support 2GB's of RAM. Did you try both sticks of RAM one at a time?
Posted on Mar 15, 2011
EMachine W3507, will not boot after adding 2GB of memory. (2x 1GB; one in each slot). It will boot with one stick, but only if the original 512MG is in slot 1. The 512MB is not recognized.
Where they purchased as a working pair some motherboards will only accept working pairs>?
Make sure RAM modules are of same brand and type try one ram module at a time in the working slot closest the cpu if both work individually they are not a working pair
Sep 06, 2013 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
I can't find the specs, but how much memory will this motherboard support (Emachines T5062 W/ AMD 64 athlon)?
1024MB DDR2 dual-channel memory
(2 × 512MB), 667MHz, (PC2-5300)
Expandable to 2GB
2 DDR2 slots (Total) ' 0 DDR2 slot (Available)
Feb 05, 2011 | Computers & Internet
Will pny pc2-5300 work with a emachines t5082
Ships with
512MB DDR2 (1 × 512MB), 533MHz (PC4200)
Expandable to 2GB
2 DDR2 Slots (Total) | 1 DDR2 Slot (Available)
recommend
512MB PC2-4200 M-533D-512BD10
Aug 24, 2010 | E-Machines T5082 PC Desktop
Just bought 2 1GB PNY dual Chanel memory modules for my Computer Make: HP Pavilion 061 Computer Model: RJ181AA-ABA a1600n Currently has Memory: 4 slots: 512 MB, 512 MB, empty, empty QUESTION: which slots...
Start off by putting the first memory module in DIMM slot 0 this is the slot nearest the processor. DIMM slot 1 is the slost after DIMM 0.
Regards.
Jun 28, 2010 | HP Computers & Internet
Toshiba satellite A100 slot 2 doesn´t work. A
Is memory matched (DDR2 667)
Have you put original mem in slot 2
Download / install CPU-Z with both modules in and run program to see if it shows.
If all above is correct may be damaged mobo.
This is for your laptop from vendors site.
Memory5
• Configured with 512MB DDR2 SDRAM (1 slot occupied and 1 available)
• 512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB or 1024MB PC4200 DDR2 533MHz SDRAM.
Mar 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
I replaced a 512mb memory for the pny 2x1GB ddr2 pc2-5300 to improve my system performance but when i turn it on my system shut down a while after i had log in to my account then i removed the memory card...
You may have a bad memory stick. If the two are not exactly the same spec they may not be compatible.
Haev you checked that your motherboard is capable of handling 2gb of memory? And that it is the correct type of memory(size and speed) and that you are placing it in the correct slots(ddr2 only goes in ddr2 slots and ddr only works in ddr)
The power supply makes no real difference to memory, replacing that is not a solution
Jul 26, 2009 | PNY Optima 2-Pack 1GB PC2-5300 DDR2 DIMM...
Memory Upgrade problem
You have the correct memory, however, did you replace memory in both available slots with same capacity/clockspeed sticks? The below is from the Spec sheet for your computer.
512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB, 1024MB or 2048MB PC4200 DDR2 533MHz SDRAM,
dualchannel support requires two memory modules of same capacity and clockspeed
Mar 22, 2009 | Toshiba Satellite P105-S6227 Notebook
Why won't new PNY DDR memory work in eMachines W4630?
Read your manual, as there website does not offer it just driver downloads.
Also, just because it is the same kind does not mean it will work.
That is why most MFG of motherboards have a quality vendor list
for memory. There are thousands of people who can't get some mfg's memory to work with there systems when the specs are the same.
But I would go with what Ultim said and there might be a slot limit.
Mar 20, 2009 | Computers & Internet
E-Machines W6409 (7234) PC Desktop Logo
169 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
