Question about Acer Aspire One D255-2670
My acer d255-1625 will not post after adding 2 gb ram upgrade. Thought it was bad stick but tried another manufacturer and getting same result. Upgraded BIOS with no change.
    Master:
  • 525 Answers
You may have a loose ram socket. If you press on the ram and it moves up and down then that means your socket is loose. The ram should be seated flat and secure against the bottom of the board.
Posted on Mar 15, 2011
  • 15 Answers
The Acer Apsire One series only supports up to 1.5gb of RAM. This includes the onboard 512mb, plus a single 1 gig stick. I have this same model, and had the same problem.
  • wheran89 Mar 27, 2011
    so did it work and how did u fix it??
Driver memory stick
Try putting the ram in another computer and see if you have the same problem. If the issue goes away one of the sticks of ram might not have been fully seated. If you get the same result you have a bad stick of ram. Go to the manufactures website and download ram checker and install it (free software). This will help diagnose your problem. If you get an error code write it down so you can give it to the manufacturer which indicates which error problem you have... If it turns out that you have a bad stick of ram contact the manufacturer and they may send you another stick of ram. Some manufacturers have a lifetime warranty on their ram. Hope this helps.
May 11, 2017 | Kingston 4GB Secure Digital High Capacity...
I recently added 2 sticks of 1 Gb Ram to my desktop, to now have a total of 4 1 Gb sticks. This newly added memory is PC2 @ 5300Mhz speed. The older 2 sticks of 1 Gb memory are PC 2 @ 6400 speed,...
It depends on what you would like the end result to be. If you need to multi-task, and have 10 windows running at once, go with the 4GB @ 5300 because while it might take a little longer your computer will still be able to handle all the information. However if you are just using it for light browsing and would prefer speed over bulk (when it comes to data processing) go with the 2 @ 6400. I don't think it would be worth it to get 2 more @ 6400, technology is advancing so fast. If you have 60 bucks you can upgrade to two 4GB @ 10600 (8GB total for $60) 1333MHz PC3. Lookup Corsair XMS3 4GB RAM.
Jul 29, 2011 | ASUS Computers & Internet
I have a motherboard called d102ggc2 with max 2 GB capacity. I recently tried upgrading from 1 GB ram to 2 GB ram by adding another 1 GB stick. The problem is that both the sticks are not working together...
Sounds like the second RAM stick was placed in the wrong slot. I would suggest checking your motherboard manual to determine this. Some motherboard designs have unusual slot arrangements.
Dec 17, 2010 | Intel D102GGC2 Motherboard
Wats the most ram for acer 3680 notebook
The most RAM (Random Access Memory) you can ad to a Acer Aspire 3680 Notebook is 2 GB. There is only 2 slots for RAM so I would get two 1 GB RAM sticks for a total of 50$.
Shouldn't be too hard to replace, just flip it over and unscrew the compartment.
Good luck,
Brandonmxb
Dec 11, 2009 | Acer Computers & Internet
2 rams nt working simultaneously
Are they exactly the same brand and model? Sometimes they dont like to mix and match. Say you have the Left and right ram slot. Does each single stick work alone in the left and the right slot? Sounds like you may have a dead ram slot.. :(
Jun 04, 2009 | Intel D102GGC2 Motherboard
No display after upgrading RAM
Are you saying that there are only 2 slots for ram or 4, if 4 then you may have a dual channel lap top, in which case you need all of the ram to match, they all have to be the same exact ram.you cant mix and match, also is the bios recent, it sounds like you may need a bios flash if the laptop isn't recent.And there may be a limitation on the amount of ram it takes, I just setup a brand new acer and it only two gig max, see if they offer a bios update
Dec 23, 2008 | Gateway M-6866 15.4" Widescreen Laptop...
Upgrade for acer aspire 4315
Hi, best and fastest way to increase your laptop speed is upgrading RAM to 4 Gigs, using 2x2Gb RAM modules like this one (UK seller).
Adding a bigger hard drive won't increase laptop speed, but will give you more space to store your files.
Another way to speed up a computer is using CPU overclocking, but this operation, good on old computers, is not worth on a computer with new CPU like yours.
On you tube also some user posted videos on how to upgrade chips on motherboard of old Acer aspire, but I suggest not trying this, as risk to destroy laptop is very high, and it is generally not worth.
Better to stick with traditional upgrades.
Aug 09, 2008 | Computers & Internet
Two 1 gb ram sticks not working together!
may be frequency is different of RAM,just check it
Mar 05, 2008 | Intel D102GGC2 Motherboard
PC turns on then quickly turns off
Does it boot fine if you remove the memory you just added? If it does then try switching the memory that was in it before with the memory you just added. You want to first determine if the ram you bought is bad or incompatible.
Dec 06, 2007 | Computers & Internet
Acer Aspire One D255-2670 Logo
218 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
