I had external speakers plugged into my laptop. the tip broke off the plug inside the port. How do I get it out?
  • 53 Answers
How much of the tip? you could try a toothpick. You just need to place it in there and angle it and pull out. If thats to big you could try a pin but I would advise turning your laptop off.
Posted on Mar 15, 2011
How do I get volume on my Dell 2414H Monitor?
I believe this monitor does not have a built-in speaker. If you have the optional hang-on speaker, it must connect to the laptop's speaker/headphone port (speaker's green connector cable/plug). You cannot use the external speaker and the headphone at the same time unless you are using a Y connector cable.
This monitor has a VGA and a DVI-D ports for video input. Neither supports sound.
I hope this helps. Dell 24 Monitor P2414H
Oct 29, 2015 | Dell Computers & Internet
Speakers external
Look on the side of the laptop for the headset port. Plug your external speakers in there. Then you will have full control of volume and such through the OS system control.
Semper Fi,
Z
Nov 05, 2013 | Acer Aspire 7741z
Audio will play on internal speakers only
Are you plugging the external speakers into the right port? Try plugging them into the Headphone port if there is no external speaker port. Make sure you have the external speakers turned on and the volume turned up. Also make sure you have the software in the computer to have the volume turned up and not muted. Check the audio sound properties and make sure the volume is turned up and not on mute.
Click Start/Control Panel then look for Audio or Sound and check the volume.
You can also click the megaphone at the bottom right near the time to adjust the volume and check for mute.
May 12, 2012 | Dell Inspiron Mini 10 Notebook
After i plugged external speakers into my laptop, the laptops speakers stopped working. I've tried driver updates rollbacks re installs and pretty much everything else i can think of, being a mildly
The laptop speakers should only be cut out when the externals are plugged in. This is done by a little switch inside the jack. If it will not switch back and the external speakers still work fine then I would say that is definitely the problem. There is not much you can do if that is stuck. All the switch really looks like is a strip of metal that is like a spring. When you push the plug in it pushes this to the side and disconnects the internal speakers. The jack is mounted on the main board so you would have to locate the proper one and solder it on or replace the main board. Short of going that far I would see if inserting a jack a few times will get it to spring back. If there has been any spills on the laptop or it is gummed up inside you can use proper electronics connector cleaner. This is risky as it can damage the plastics but doesn't take much at all to work. I would look inside the plug and see if you can see debris or gunk. I'd also try knocking it. This is literally knocking around the switch like you are knocking on a door. You don't want to hit it really hard but just a few short sharp knocks will loosen things up with out causing damage. If you knock like the landlord looking for rent money then it might ;-]
Nov 22, 2011 | Sony Computers & Internet
External speakers not working for Alienware laptop using windows vista
first, make sure the speakers actually work before you mess with your laptop. plug into tv, transister radio or iPod or whatever. Once you have verified, make sure it is plugged into the right port. Usually the headphones port is the one you want. To verify port, use headphones. If still not working, click on the speaker icon in the windows tray on the status line, click mixer, verify speakers is not muted or turned down.
Jun 13, 2011 | Computers & Internet
I have just recieved external speakers for compaq 6720s but not sure where to attatch it,please help.
You would normally connect external speakers to a laptop using the laptop's headphone port. The cable coming from the speakers would normally have a green connector on the end and would plug directly in.
If you have a bigger, more complex speaker system then you would need to determine what connections are possible to the speakers and what outputs are provided on your laptop. The most common audio out ports (for PC's, not so much laptops) are SP-DIF Coaxial and Optical. These would provide full digital surround sound signals from your computer but are not found commonly on laptops.
My best guess would be the above green connector to headphone port setup. The rest is a bit optimistic for an everyday laptop.
Apr 02, 2011 | HP Compaq 6720s Notebook
Have windows 7 on my new acer aspire 5517; trying to get external speakers (2 different kinds) to work. my generic usb speakers install and it shows they're working properly, but errors when trying to play...
what happens when you plug the speakers in the green port? You might want to try the other audio ports because on a few new computers i have seen the speakers have to be plugged in a different hole. also make sure the speakers are plugged up to the electric plug.
Dec 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
Built in speakers not working
Are you using external speakers? or internal?
EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
Good Luck.
Sep 08, 2009 | HP Compaq nx6115 Notebook
Dell Inspiron 6000 PC Audio Ports Damaged
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
Jul 01, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
