Question about Sylvania CL772B 17" Flat Panel LCD Monitor
When I've been away from my computer for awhile, the screen goes black and no amount of clicking with the mouse or hitting the enter key can get it to come back on. I have to turn off my computer and restart to get the screen back. How can I fix this?
  • 3 Answers
Check your settings for hibernation/power saving. Adjust those settings according to your personal preference.
Control Pannel > Power options
Posted on Mar 15, 2011
When i power up my Acer M3400, everything loads then after the 'welcome' windows part the screen goes black and i can only see the mouse cursor? I tried to restart but nothing happens. It keep
Not sure, but try loading Safe Mode by pressing F8 during boot and lowering screen resolution. In Safe Mode you can even run System Restore. It load to a previous date that you choose.
Jan 11, 2013 | Acer Aspire M3400 PC Desktop
Y compaq pressario v2000 goes from black screen to intermittent normal screen. The black screen is on the computer 80% of the time and then the pics fade in and out
The screen on your laptop goes black after every few seconds.
It resumes after a mouse-click or after a key-press.
Solution
Click on Start --> In search bar, type power options and press Enter.
"Select a power plan" window will be opened.
Click on "Change plan settings" next to "Balanced (recommended)".
In "Turn off the display", select "Never" from the drop-down menu under both the options "On battery" and "Plugged in".
Now click on "Save changes" button.
hope this helps
Nov 20, 2012 | Computers & Internet
How do you reposition text in a document screen
Highlight the text with the mouse by clicking the left mouse button and dragging. When you've highlighted what you want to move then hit the <ctrl> and "C" keys at the same time. Move the pointer to where you want the text to go and click the on spot. Then hit the <ctrl> and "V" keys at the same time. Voila... it's moved. ..Now just highlight the original text again and delete it.
Jun 29, 2012 | Toshiba Satellite9 Laptop Computer With...
My acer laptop screen goes black after i pass the log in screen
What you can try to do is hit "Ctrl" + "Alt" + "Delete" which should open task manager once you've reached the black screen. Click "File" from the menu bar and then "New Process". Type "explorer" in the box, and, Voila!, you should be able to see things again.
Sadly, this is indicative of a virus or corruption of the operating system. I'd recommend backing up all your stuff and then tapping "F8" while you're computer is turning on, hitting "Enter" on "Repair my Computer", clicking through the dialog box, and then select the "Acer Recovery" option. This will wipe everything back to factory defaults.
Aug 24, 2011 | Computers & Internet
Model is Satellite A135-S4727. Boots up in safe mode, but black screen when I try to do anything from there. I removed the battery and went to ac. Screen when booting works and I see the that it is...
when it goes to the black screen give it a few seconds after the mouse shows up. Ctrl+Alt+Del and select task manager, then select the process tab. click on explorer, then right click on it and select end process from the pop up menu. once it has disappeared go back to the first tab programs. click new task, type explorer and hit enter. see where it gets you from there. if that doesnt help please recover your computer per manufacture instructions.
Mar 20, 2011 | Toshiba Satellite A135-S4727 Notebook
If sitting idol for awhile, the screen will no longer come up
Your computer is going into sleep or hibernation mode, have you tryed double clicking with the mouse while in this state. Or if your keyboard has a wake button then press this. Also try using the esc key located on the top right hand side on the screen. Hitting the Enter key can also bring it back to life.
damnor01
Nov 14, 2010 | E-Machines eMachines Desktop PC
My Imac crashes. 10.6.4, 2 GB ram, 2 GHz core duo. I've started with a clean install and disabled (one by one) all start up apps. Out of the clear blue, the screen will go black & I have to turn it...
When you say "screen goes black," does the computer power down, or is it still operating? Does the sleep light come on? Does it respond to the keyboard and mouse? (Example: press the power button momentarily, wait a few seconds for the "Do you really want to shut down" message to appear, even though you can't see it, then hit the return key to answer "OK," and see if it shuts down.) Does the screen go black or come out of black if you tap the computer?
While your computer is working, go to System Preferences / Desktop & Screen Saver, the Screen Saver tab, click Hot Corners, and set a corner of your screen to Put Display to Sleep. Then next time your screen goes black, mouse your way into that corner, pause a few seconds, then mouse back out and see if your screen returns.
Jul 10, 2010 | Apple iMac 17" Desktop
I HAVE A DELL 4300 i CLEARED IT ALL OUT AND FOR SOME REASON WHEN IT STARTS UP IT GOES TO A BLANK SCREEN WHICH SAYS ENTER PASSWORD OR HIT CTRL ENTER TO DELETE PASSWORD. THE PROBLEM IS WHEN i TRY TO TYPE THE...
Open the case up and remove the CMOS battery - it's probably a CR2032 or some sort - about the size of a quarter. It should clear the CMOS password and allow your computer to boot up correctly.
Nov 19, 2009 | Dell Dimension 4300 PC Desktop
Black screen on my Acer Aspire 3680
when you start the pc tap on the f8 key and choose safe mode from the menu then hit enter twicw, if your pc will start up in safe mode, then you can click start, then type MSCONFIG in the search box and hit enter ( or click start,all programs,accessories,Run, then type msconfig and hit enter) if you click on the startup tab, you can see everything thats checked is starting with windows, you ca uncheck all of these, and by repeating the steps above, check them back one or two a time, until you find the offending program. Google pacs-portal.com for an excellent site that will tell you what all the startup entries are and if you need them
Mar 30, 2009 | Acer Aspire 3680 Laptop
Sylvania CL772B 17" Flat Panel LCD Monitor Logo
76 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
