Question about Danby DDW497W Portable Dishwasher
Danby DDW497W Portable Dishwasher water level switch problems my dishwasher overfills, and i get the E4 error on screen is there an easy fix, or somewhere i can buy the part from?
  • 209 Answers
SOURCE: dishwasher time E4
check for open circuit electrically with the heater element
Posted on Oct 15, 2007
SOURCE: E4 error on new conia dishwasher
Had the same problem. First you will need to tilt dishwasher back 45 degrees and tip out all excess water. A couple of towels on the floor are a good idea.
Second check that the little nozzle on the elbow under your sink where your overflow attaches is drilled out.
This fixed my problem after fussing around for a day and I was starting to disconnect everything to take it back.
Posted on Dec 22, 2007
  • 351 Answers
SOURCE: how to adjust the float
you need to clean the sump remove all the filters etc and clean them this is a common fault and may not be a quick fix.
Posted on Apr 09, 2008
SOURCE: I have a Delonghi dishwasher
After a bit more perserverance we managed to solve this problem ourselves. The machine had been drained of all possible water but on moving the machine to try and find the float device ourselves a further load of water ran out from underneath it. After this water had dislodged itself the machine started to run correctly.
Posted on Jul 27, 2008
meBNme
  • 334 Answers
SOURCE: Danby portable dishwasher 1805W hose
Lowes.
You can buy a brass nipple that will fit into the end of the hose, put a clamp on it. Put the now hose on, put a clamp on it.
You may also consider just replacing the entire hose from its original connection with a longer hose.
Lowes, HD should have whatever type of hoseing you need.
Posted on Dec 04, 2008
My danby countertop dishwasher ddw497w turns on, drains the water in the tub, refills and right before it usually fires up. click and nothing. just sits there with no fault code. any ideas before i sm
Hey Derrick,
According to the manual:
http://www.danby.com/cms/documents/pdfs/en/DDW497W_EFSOM.pdf
The most likely cause is the appliance not being leveled properly. Apart from that, I have found no useful information.
If you have a smart phone, try using one of the various, 'Surface Level' apps which will allow you to set your phone on the top of the appliance and then adjust the level until the bubble is centered in the crosshairs.
Hope this helps.
Oct 03, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
Danby dishwasher faucet adapter
Yes, I have a new portable dishwasher and no adapter, not sure what size to get. model DDW1899WP-1
Jun 25, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
Water not drains,Danby Portable Dishwasher
I had the same problem and found the drain blocked at the outlet as it goes into the sink.
Dec 27, 2013 | Danby DDW1899WP Portable Dishwasher
I turned on my Danby countertop dishwasher without water! and now it does not work at all. Someone help me please, how can i fix it!!!
unless it ran for quite a while there should be no damage. plug it into the water, add a few cups of water to the water to fill the sump and prime the pump and turn it on it should work then.
Our danby at home shuts itself off when there is no water so I'm assuming thats what you are seeing.
Aug 23, 2010 | Danby DDW497W 22 in. Countertop Dishwasher
I get an E4 error message when I turn on the machine.
The first thing I would check is to see if you turned the water valve on under the sink.
Jul 22, 2009 | Danby DDW497W 22 in. Countertop Dishwasher
Plexi glass on the inside of danby dishwasher is broken
Try calling the number below - we managed to get parts for our portable dishwasher (after a considerable wait). Dan by Products Inc. 1-800-263-2629 Ext. 212 1-419-425-8627 Fax: 1-419-425-1244
Feb 04, 2009 | Danby DDW497W 22 in. Countertop Dishwasher
E4 fault code
Hi, when a dishwasher goes into overfill mode it usually means that the bottom tray has water in it that operates a float connected to a microswitch. Open the bottom panel and soak up all water then check to make sure the float is down completely.then restart dishwasher. Why it has overfilled is another problem. It could be a faulty pressure switch,pressure switch hose may have a hole in it, water valve may be faulty. Too much soap or wrong soap can cause too many suds and hence overfill.Also if rinse aid is spilt when filling. Or seals leaking. etc.
Feb 02, 2009 | Dishwashers
Error 4 displayed on a danby ddw1806bsl dishwasher
E4 is overfilled condition.
There is a tank with an overflow sensor on the right side of the dishwasher. The tank needs to be drained of water to reset the sensor. If necessary remove the insulation on the lower front corner of the machine and drain into a cup or container by removing the black rubber plug at the bottom of the plastic tank.
Consult the manual for detailed procedure.
The error can occur from excessive foaming.
May 10, 2008 | Danby DDW1806BSL Stainless Steel Built-in...
Danby DDW497W Portable Dishwasher Logo
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
