Question about Jacuzzi T632000 SteamPro 120 Instant Steam Generator
I have just installed a Jacuzzi Tub in my new Bathroom . I am thinking of adding Jacuzzi T632-000 Steampro 120 Instant Steam Generator as well . How do I go about it without tearing tiles and other installations in my new 100 % remodeled bathroom .
  • Rashid Karim Mar 19, 2011
    My Jacuzzi is a Espree 6032 with an opening on left for Jacuzzi Motor & Heater . I would think
    there is enough space to install and connect SteamPro T632000 .
  • 8,197 Answers
I am sorry to do this install you will need to remove the tiles or lift the tub out to install the unit. There is no other way of doing it. I am a general contractor and have instilled many of these unites. You need to put it next to the pump to work right.
Posted on Mar 16, 2011
  • Jyackle5
    Jyackle5 Mar 19, 2011
    Most access openings on the are 1.5 ft. by 1.5ft. That does not give you the room to install and plumb to the jacuzzi. If yours is bigger you might have the room to install the unit.
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Where do you install a jacuzzi whirlpool tub indoors or out?
This unit has to go inside preferably a bathroom setting. The wall fixtures on the rear of the unit are proof enough of that. A plumber will need to install the unit as some bathroom plumbing will be required.
Apr 28, 2014 | Jacuzzi Home
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
Feb 22, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
My jacuzzi bathtub plastics pipes underneath are leaking due to being chewed by rats. So if i fill up the tub to the jacuzzi line holes, water leakes through the chewed pipes on to the wood floor...
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
Feb 23, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
Need electrical schematic for Ariel 701 steam show/jacuzzi tub
What I recommend to you is to contact a supplier that handles these units. They might be able to contact the vendor for the product to try and get more info for you. To be honest, I think your electrician is being a little unreasonable. I would consider finding another electrician. I realize he doesn't want to miswire something and then have to replace it but it would take a complete knuckle head to mess up the wiring on a motor. My opinion though!
Apr 08, 2009 | Dmm WMK-A06 Pearl Steam Shower Unit,...
Need a users manual
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Nov 11, 2008 | Balboa Instruments Garden
Jacuzzi T632000 SteamPro 120 Instant Steam Generator Logo
53 people viewed this question
Top Jacuzzi Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Jacuzzi Electrical Supply Expert? Answer questions, earn points and help others
