Question about Ruud Heating & Cooling
My Ruud furnace used to regulate 1 deg +\- the set temp. Now it regulates right at the set temp and the fan cuts off while the burner continues to fire for a minute or so then the fan kicks back on for another few minutes then it kicks off. But now the furnace tends to kick on more often than before when it was regulating +/- 1 deg around the set point. How do I fix this?
    President:
  • 3,433 Answers
It appears to be the fan limiter switch. It comes on at a certain temp when heating up and shuts off on the high end of its setting. Once the burners are shut down, the fan continues for a few minutes to cool down the burners. The limiter switch is adjustable but it sounds to me to be defective and should be replaced. Good luck and stay warm, :-)
Posted on Mar 15, 2011
Ruud furnace lights but blower only works with fan on not auto on therm.
Sounds like the automatic fan control not working not cutting in on temp rise to bring fan on .
Dec 10, 2016 | Heating & Cooling
Vulcan Gas Fryer Overheating
I'm confident that the issue is the thermostat. It's the only thing there to regulate temp and from the sound of it, it's not keeping up. The bulbs can gas out and then they're about as useless as an empty soda can as far as temp regulation goes.
Nov 22, 2007 | Vulcan EF3 Deep Fryer
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
Weber grill three burner. New tank of propane but
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 29, 2010 | Weber Genesis Silver B Grill
Can you tell me the order in which each componet of a gas furnace comes on to start the furance?
Yes there is a sequence:
0:00 Dial for fan/limit switch is at 70 deg position. Furnace is cold. I turn T-stat to 80 deg to start furnace.
1:00 Burner comes on and dial begins to move slowly up.
2:30 Dial at 140 deg and fan motor comes on. Dial never goes above 150 deg.
3:00 Burner turns off. Dial slowly moves back towards 90 deg.
4:45 Burner turns on and dial is at 110 deg.
4:50 Fan turns off with dial still at 110 deg.
5:30 Burner off. Dial at 120 deg.
6:15 Fan on. Dial at 140 deg. Burner is still off.
7:00 Burner on. Dial at 120 deg.
7:40 Burner off. Dial still at 120 deg.
8:30 Fan off with dial at 110 deg., and it quickly snaps back to the 80 deg. position.
8:30 plus, cycle continues.....
Mar 25, 2010 | Heating & Cooling
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
Burners shut down at set temp but fan continues lowering temp
the reason he told you not to cycle the power is because some where there is a flashing light that he can decode and tell him where to start looking for the problem. Call him next it happens and don't touch the power or the stat until he gets to see the unit.
Aug 03, 2009 | Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Blower fan runs to long
ther might be dip swiches on the circuit board you might have to change
Dec 17, 2008 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
