Question about Cst /Berger 57 LM30 Manual Leveling Dual Beam Rotary Laser Level With Case
Looking for instruction manual for Lasermark LM30 manual leveling laser
Need manual for hilti pm 22
HILTI PRA 22 OPERATING INSTRUCTIONS MANUAL Pdf Download.
https://www.manualslib.com > Brands > Hilti Manuals > Laser Level > PRA 22
  1. Cached
View and Download Hilti PRA 22 operating instructions manual online. remote control / laser receiver. ... Laser Level Hilti PM 2-L Operating Instructions Manual.
  1. Cached
Manuals and User Guides for Hilti PRA 22. We have 2 Hilti PRA 22 manuals available for free PDF download: Original Operating Instructions, Operating ...
Dec 17, 2016 | Hilti Drills
Lazermark won't self level
There are 2 leveling systems in the lasermark lasers. The original was belt driven. The belts are rubber O rings, and break down over time. take the bottom off the laser and you can replace broken belts. It's a simply yet elegant system.
The newer ones use leveling cams. A tear drop shaped wheel on a motor, that raises and lowers one end of an axis to tilt the laser. The problem is because they have a hook at one end, they put a magnet in the cam to tell the laser when to stop turning the cam. If however, it reaches the limit, and then gets bumped it'll get the leveling axis stuck in the hook of the cam, and because the magnet is there, it will never relevel. What you have to do is, disassemble the laser, unplug the leveling motors and pull the wires for the magnet sensor out of the stuck axis. then swap the sensor from the other sensor in (as it wont level without reading the sensor) and then turn the unit on. It should be able to level at that point. The put all the wires back where they go, and you're on your way.
Apr 20, 2014 | CST/Lasermark Self-Leveling Rotary Laser...
I just put 3 new battery's in and leaser light will not come on.
Check for green corrosion on contacts and clean them A dab of WD40 on a Q tip will may help clean & improve the connection and provide extended protection.
Aug 25, 2013 | CST/Lasermark Self-Leveling Rotary Laser...
Lasermart LM30 wont spin and all lights blinking
My LM30 worked OK for a while, then the zig-zag chalk line feature stopped working, and finally it would not spin for more than a second for either rotate setting, and got the flashing lights thing. Of course tried replacing batteries to no avail. So the meticulous experimenter in me started on a mission to find out why it stopped working.
If my findings are the only reason this unit gives this error, the company should be ashamed of itself charging so much for such a simple repair.
Check these two things if you get the no spin/flashing lights problem.
Test one: Gently holding the rotating head, lift up a bit. If there is a little up/down movement when you lift on it, go to test two.
Test two: Holding the unit upside down, try running through the functions. If all functions work, the repair is easy and inexpensive/free.
The problem is there needs to be no axial shaft slop for the unit to work, and that slop is removed with a thin wave washer under the spinning head. That washer get's weak over time, and I think there is a sensor on the board that makes sure the drive pulley doesn't drop too far down, which triggers the shutdown.
Tools needed:
Phillips screwdriver
Small phillips screwdriver
1.5mm allen key
Retaining ring pliers
The fix:
1) Remove batteries and the screws from the top of the spinning head, and remove the cover.
2) Remove three screws from the bottom of the LM30 holding the yellow case on.
3) Carefully lift off the case. The control board has a slide pin connection to join it to the rest of the internals. It has a slight resistance to being removed, but if you feel a higher resistance, the control board is probably snagging on the drive motor inside. Squeezing the case sides gives you a little more clearance. Take your time getting it off.
4) Remove a 1.5mm allen head jam screw from the prism head, and carefully slide the prism off the shaft (gently prying up with a screwdriver)
5) With retaining ring pliers, remove the retaining ring.
6) Remove the wave washer. You can find a replacement or simply bend the existing one to make it a bit "wavier". Don't go crazy, just bend it slightly more than it is.
7) Support the shaft with a screwdriver inserted under the drive pulley
8) Replace the wave washer on the shaft.
9) Replace the retaining ring
10) Temporarily remove screwdriver to check that there is no up/down slop in shaft. If there is, you need to bend the washer a little more.
11) Reinsert screwdriver for support.
12) Carefully replace prism and reinstall the allen screw
13) Remove screwdriver providing shaft support
14) Carefully replace yellow cover, assuring slide connectors line up on the control board, and replace three screws
15) Replace prism cap and screws.
16) Replace batteries and test functions.
-Rod Reidnauer (meticulous experimenter)
Jan 09, 2012 | Cst /Berger 57 LM30 Manual Leveling Dual...
I need a manual. Power will not come on. Changed batteries. No power. Also, where does the red attachment that tells you to go up or down hook on? I have power to the unit which hooks to the pole.
Hi Richard.
The manual is available from this webpage.
http://www.cstberger.co.uk/uk/en/
Type lm30 into the text box which says "trade name/tool number" and click "start search"
Click on the thumbnail then to download the pdf.
Check for corrosion on the battery terminals and those in the laser.
From what I can see in the manual, there should be a clamp for the laser receiver that lets you clamp it to a staff.
The target plate (part 24 in the manual) has a reflective coating and there should be a magnetic holder for it.
Nov 24, 2011 | Cst /Berger 57 LM30 Manual Leveling Dual...
My laser turns levels tries to spin but wont. I am told its the motor. can l buy a motor ?
Please contact CST/Berger directly for warranty service or parts inquiries about that laser.
Their website is here. If you click on the self-support knowledge base link and type in warranty service you'll be able to access a list of options for repair of your unit.
(If you have a product(s) that needs to be returned for service, please contact the Customer Support department at 800-435-1859 or click on the LIVEPERSON icon right now to obtain a RMA number before shipping the product(s) back.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 06, 2011 | CST/Lasermark Self-Leveling Rotary Laser...
Cst /Berger 57 LM30 Manual Leveling Dual Beam Rotary Laser Level With Case Logo
754 people viewed this question
Top Cst Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cst Measuring Tool and Sensor Expert? Answer questions, earn points and help others
