Question about HP W2338H Monitor
Just moved & set up my computer with HP w2338h monitor with built-in speakers, it does not play sound. I've restored factory settings, checked volume & mute, turned off/on, double checked all cables, and still does not work. It worked fine before we moved.
    Scholar:
  • 82 Answers
Try the following:
  • Right click the speaker icon in your icon tray > click playback devices, see if you can see your monitor there as an option, and if so, right click it and click "Set as default device"
Hopefully that helps!
Posted on Mar 15, 2011
HOW DO I GET SOUND OUT OF MY DELL SE198WPFV MONITOR?
sad to tell you but they are not made to have sound OUT .
Apr 30, 2015 | Dell Computers & Internet
Sound doesn't work
First thing first, check cable and sound card with another speakeer system. most of the time even if the sound card show in the device manager it can be faulty. then begin work from there.
if you found that the previous step work and the monitor does not work, you may require to change the sound card in it. at this point I would use external speaker set.
Jan 03, 2014 | HP W2338H Monitor
Speakers will not work and everything is plugged in
See pages A1 7 A2 of manual http://www.manualslib.com/manual/263845/Sylvania-6842pe-M.html
Nov 26, 2013 | HP W2338H 23-Inch Widescreen Monitor
My HP w2338h has a series of different colore bands on the right side of the screen. What is the cause and can I repair it myself
Is the picture still visible? If it is yes you just need to factory reset the monitor. If not, check your inverter.
Mar 09, 2011 | HP W2338H Monitor
I HAVE COLORED LINES ON THE RIGHTSIDE OF MY MONITOR THAT WON'T GO AWAY AND ARE BECOMING WIDER AND MORE OF THEM, ITS ONLY A YEAR OLD. IT'S A HP w2338h MONITOR.
mcdevito75 here, Double check all connections at your monitor and computer. On the monitor press the AUTO button, this will re-set the factory settings. If this fails, I would bring the monitor to a Staples, Radio shack, Best Buy for testing, Monitor could be going bad even at a year old, also check any warrantees on the monitor.
Jul 22, 2010 | HP W2338H Monitor
I have the HP w2338h monitor. when i listen to
Hi there , Go to your PC settings , and Try turn Screen saver off , aswell as Sleep off... it is in your PC settings.
Good luck
May 22, 2010 | HP W2338H Monitor
No volume from hp w2338h monitor...only sound comes from headphones pluggedinto computer
check if the monitor speakers are the default speakers for ur computer.. to do so.. click Start.. then under start search type.. Sound.. and hit enter on this screen u shall be able to see various devices as speakers.. the one with Green check is the default speaker.. select Monitor and select Default below and thts it.. ur done.. for more info.. go to the following link from HP http://tinyurl.com/2fvjh7l
let me know if this was helpful to u.. regards, guru
Apr 18, 2010 | HP W2338H Monitor
Only get very faint sound out of my speakers, even though the sound bar in the lower right hand corner is at max
And what about volume adjustment in the monitor itself? Is it also adjusted to a higher level?
Dec 23, 2009 | HP W2338H Monitor
NO SOUND!
Hi
Pls check if the audio cable from the monitor is connected to the tower. Make sure it is connected to the green port at the back.
Also check the volume button on the side of the monitor and set it to maximum.
If this doesnt work, then try with another pair of external speakers and check.
Jan 22, 2008 | HP vs17
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
HP W2338H Monitor Logo
123 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
