Was replacing color cartrige door got closed and carrage went to the right how do i get it to come back to the left so i can put a new cartrige in?
  • Bob Headrick May 11, 2010
    Which printer model? There are thousands of different types of printers with different methods of changing the cartridges.
    - Bob
    Genius:
  • 1,011 Answers
Sir once we finish this chat you will be asked to rate the chat. that time please dont forget to give a
good rating
and review. because many customers dont rate the chat and we experts are left with no credits for
providing a
solution.
Posted on Aug 01, 2008
My friend had a problem of his printer, cause the printer didnt recognize the ink... it has 6 colors epson ink. we dont know how to fix it... all the cartrige shows x
Is your friend use CISS. If so
Move Ink cartrige holder to cartrige change station.
Put off cartrige ( genuin or CISS) from carrage
Take a soft erager try to remove dry in or dust or waste everything smothly
reassemble the cartrige again
push top of the cartrige gentaly sothat it struck acurately.
Turn on printer.
I think you will get rid from your pprinter problem.
Thank you
Aug 21, 2011 | Office Equipment & Supplies
On my samsung fax sf5100 machine there has been a new ink cartridge installe dand the machine is still asking to insatll new cartridge , do i need to tell the machine new cartridge installed if so how
you will see there is a fuse on the cartridge. replace it with a new one. it can be biger becouse you will remove it again.
put the cartrige back with other fuse and close door for 3 secons. take cartridge out and remove the fuse.
put cartrige back with out the fuse. it sould work.
the other way is to push setup and then # 1934.
push setup again check for new cartrige or egnore cartrige.
swich m/c off and on.
Aug 10, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Hp officejet j3500- refer to device documentation to troubleshoot
problem with any one of your cartrides. open the carridge door and renove color cartridge and close it.if it says insert left cartridge then it could be the problem with color cartrige.or the same error come then put the color cartridge and remove the block cartrige.if display says insert right cartridge then it could br the problem with black cartridge.try clesn the cartridge contacts & ink nozzles and put it back (use a soft cloth to clean the cotact)
Aug 04, 2011 | HP Office Equipment & Supplies
I would like to replace ink holder belt in epson stylus r220 printer
It's very easy.
uncover the printer. Then look left and right site of the printer. There you find 2 lock in left and 1 lock in right side. In right side there is a spring tidely back side of the printer. then open all the parts from left side and right side. put of the plastic sensor that are sruck right to left in the back side of the printer. Then put off iron rod into the ink cartrige carrier. Then try to put off cartrige carrier from the printer ( where the carrier is parked). Then look the belt in the back of the cartrige carrier. Then replace it .
Thank you
Jun 27, 2011 | Office Equipment & Supplies
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
How do you place cartrige in printer
Step eight: Install the cartridges
  1. Raise the top cover of the product. Figure 5: Raise the cover c00830210.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tapec00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  3. Slide the new cartridge forward into the empty slot. Then gently push the upper part of the cartridge forward until it clicks into place.
    • Slide the tri-color cartridge into the left slot.
    • Slide the black or photo cartridge into the right slot.
    Figure 7: Insert the cartridgec00830211.jpg
  4. Close the cartridge door. Figure 8: Close the cartridge doorc00830212.jpg
Aug 08, 2010 | HP Officejet 5780 Printer
Hi Can you help... we have the hp 450c and the media will not load, the cartridge, data, and media light stays on and then when you hit cancel the align media light stays on. Thanks Jill
This is an old posting so you probably have come right already (or thrown the plotter away) This fault is one of two things, firstly it's probably the carrage is likley sticking, clean the bar (silver bar( that runs from left to right with turpentine or spirits, you then need to lubricate it with sewing machine oil or similar. Spread the oil evenly across the bar by moving the carrage by hand left and right, use no more than two drops of oil. Also chack the condition of the belt and make sure it is in good condition. Secondally it could simply be a faulty black cartrige, try and replace and see what happens.
Regards
Dave
Feb 18, 2010 | HP DesignJet 450c InkJet Printer
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
How to change toners
Open front door, check on the color facing you, close door, press the color cartridge to advance the carousel to the color you need to replace, pull out the cartridge and replace with new one.
Jan 13, 2009 | HP Color LaserJet 2550n printer + HP Color...
Replacing black toner cartrige
if you have a status monitor installed, then you can choose from there replace bk toner and printer will turn the right toner in right place if not, then open front door remove waste toner box, locate about 1 cm usually crey ring knob, in left upper position, use screwdriver or something to push it then you can easily rotate the toner rack to the left, and pick a needed color.
Jun 23, 2008 | Konica Minolta magicolor 2300DL Laser...
jasbo
jasbo
