Question about Maytag Dryers
Heating element works sporadicly, sometimes with change of control dial position
  • 481 Answers
It sounds like it has a loose or burnt contact in the timer. you may need to change the timer.
Posted on Aug 01, 2008
Cwsr ele 2406024 cv50
I'm inclined to think that the problem is in the electronics, in the circuit board, since it's acting so oddly. The timer dial shouldn't allow the heating element to energize when the door is open.
If the thermal fuse is blown, you should NOT get heat.
Aug 13, 2014 | Kenmore Dryers
My Candy DFI Plan shows E3 and stops washing after 10-15 minutes. The problems started because electronics( I swithed with new) than I change the water pump, the heater, the thermostats and when is on,...
E3 - Missing heating of the water.
Could be:
· Clogged filtering plate.
· Defective heating element.
· Defective wiring (open circuit, leads
off place or loose).
· Defective electronic control board.
You have already changed all major electrical components energized during the heating phase. But do not forget that failures sometimes could be mechanical. For example: failure could be in hydraulic circuit of pressure switch, sometimes hydraulic circuit can lost air pressure. Another note would be that your dishwasher have NTC thermistor which every second gives information about temperature to electronic than electronic controlled heating element by a relay.
In order to heating element come under the voltage is necessary to fulfill a couple of requirements. Microswitch on the door in the closed position, the pressure switch in position 11-13 (full position , level of water) and the main switch is turned on.
24881895-svalokc2bmago0zdlfvpjh25-3-2.png Dado
Jul 28, 2014 | Candy DFI Plan Built-In Dishwasher
Fault code f07
The type of dryer would help a lot.... If it is a Maytag you can try resetting the code...
To reset the error code you need to turn the dial to the 6 oclock position.
Press the start button 3 times
Turn the dial 1 position clockwise
Press start button again 3 times
Then turn to off and this should clear the error code.if you still get the F07 error code then the control board may be the problem
If it is a Hot point You have a lower element failure..
Dec 31, 2013 | Dryers
Bosch exxcel washing machine not heating water
Are you sure it's not heating the water? The only time it heats is when it takes the detergent, all rinses are in cold water only. To test the heater, put the dial to the OFF position, press and hold the start button whilst turning the dial one click to left (30 easycare) when the two middle lights come on or 888 in display (if there's a display), take your finger off the start, turn the dial to 90 cotton (the long way, counterclockwise, not thro the OFF) press start, the tub will fill and it will do a stationary heat, you should hear the element/water making a noise like a kettle boiling. Leave the machine like this for a few minutes. Put dial to off until the door lock disengages and touch the water to see if it's warm. Put the machine on drain to clear water. If there is defo no heat repost and I will give you step by step of changing element.
Cheers Roni
Mar 01, 2013 | Bosch Exxcel WFO 2264 Front Load Washer
What is f04 Whirlpool 6th sense?
F04 indicates a fault in the heating circuit.
It can be a main board, wiring, thermostat or heater fault.
You would need to check the heater and thermostats with a multimeter to ensure they are not open circuit.
However, the first thing to try is a reset of the control board.
Turn the dial to off.
Turn the dial clockwise to the 6 o'clock position.
Turn the dial 1 position clockwise.
Press the start button 3 times.
This should erase the code.
Try the machine again.
If the code comes back, you need to check out the heating circuit.
If you change or repair any part, reset the board, then try again.
Jul 09, 2012 | Whirlpool Dryers
Zanussi TC7102W drying problems
not likely the timer but it does control the heat circuit. suspect the fan-air flow is being blocked and the elements are cycling on a safety thermostat instead of the operating thermostat. check for blocked or restricted vent and plenty of air coming out the vent when running. check for a flapper on the vent not opening or only open part way.
Mar 01, 2012 | Zanussi Dryers
Element light staying on
sometimes this is a wireing problem....elements will heat but do they turn orange. if not then the stove may be hooked up like a 110volts..
Nov 04, 2009 | Office Equipment & Supplies
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Dryers Logo
32 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
