Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Tromm wm2277hw won't spin. getting LE code letters
  • 33 Answers
The LE code is because there is a problem with the water intake . Verify that your taps are open all the way, that there is no kink in the hoses. If that doesn't solve the problem disconnect the hoses and verify there is no debris in the little filter where the hoses connect in. If none of that solve it , it might be a pressure problem in the house.
Posted on Mar 15, 2011
  • askmartin Mar 18, 2011
    I just had the same "won't spin" issue. The first LG technician wanted to charge me $400 to replace the control board. I bought the part for $60 and replaced it myself. It was not the problem. I had a second LG technician in and he correctly identified the problem as the sensor assemble (part k351 on the diagram) and it cost me $208 to repair. Then I discovered I could have bought the part for !18 at Sears...oh well. It's fixed.
  • moiramunro Mar 28, 2011
    my tech. guy came out said it was the large barring, 400.00$ labour, 200.00$ for the part and hat was an estimate. so far i have done nothing, cant afford 600 plus bout a used one temporaraly from kijiji. i want my old machine to work.
My lg tromm model number wm2277hw/01 has the error code le show 2 seconds into the cycle even if nothing is in the washer what is going on
Hall sensor needs replacing (motor position sensor). Pretty easy and under$20. Check out appliancepartsproscom, repairclinic.com or YouTube for how to videos.
Jan 22, 2017 | LG Washing Machines
Annoying LG Tromm wm2277hw "LE error" won't go away.
Might be "tE" error code. Thermistor error. A $6 parts and pretty common and causes the symptoms you described.
Mar 02, 2017 | LG 4775er2002a Door Hinges for Wm2277hb...
LG Tromm WM2277HW will not spin both directions, LE error.
clean filter check that its drained all the water out any blockage and the machine will not spin
Nov 28, 2011 | Washing Machines
LG Tromm WM2277HW will not spin, LE error
the pressure switch is jammed on meaning the water has not empty le reading the is excessive water in the machine
Nov 28, 2011 | LG WM-2277HW Front Load Washer
"LG Tromm WM2277HW will not
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
GETTING AN ERROR CODE - LE ON MY WM2277HW
A common reason for an LE code is choosing a high spin speed on a bulky/ very heavy load. Try a cycle with a lower spin speed. If you still get the LE code, especially if it does not even do the wash tumbling, then replace the Hall sensor on the motor.
Feb 01, 2011 | LG WM-2277HW Front Load Washer
My Tromm washer model WM2277HW won't spin and flashes ''LE'' Help!
try to open the back of your machine wher you can have an access to the motors, see if it is running or the belt is in right place, you can turn it on while looking at it , just don't get closser, a few feet away woul be enough for you to see it
Nov 06, 2009 | LG Washing Machines
LE DISPLAYING
le light on lg tromm wm2277hw
Jan 28, 2009 | Washing Machines
LE error
try using a-fresh its should help you out.
Oct 12, 2008 | LG WM2688HWM TROMM SteamWasher
Turned on my washer a TROMM LG wm2277hw and at every cycle turn it beeps LE
LE means a faulty motor. The motor is called the "stator" in this machine. Located behind the back panel. Pretty easy to replace in this machine. Replace the stator and it will work like new!
Apr 07, 2008 | Washing Machines
Washing Machines Logo
655 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
