Question about Dishwashers
While washing a load of dishes our dishwasher stopped, although I don't know in which part of the Miser cycle. There is water in the bottom of the tub, and no lights on the electric control panel work. I'm thinking I will call the repair man in the morning unless you can recommend any actions to take. Thanks!
  • 5 more comments
  • mblistein Mar 15, 2011
    Will take a look at the hose, thanks. But I'm curious - would the drain stoppage cause the control panel to stop working?
  • mblistein Mar 17, 2011
    I was unable to try your ideas with the hoses (too difficult for my old self) so I asked a repairman to come the next day. He quickly found that the control panel (microcomputer) was completely burned out - cause unknown (he showed me the damage - it was obvious). Today he called back and said the cost to replace the control board and a blown fuse would be $470 dollars, less the $70 I paid for his visit. Can you tell me if that sounds reasonable? If you don't address such questions of cost that's fine. Thanks for your help. (BTW, the dishwasher is a Kenmore Ultra Quiet, about 7-8 years old; model 15958)
    Thanks -
    Sears Kenmore Ultra Wash: 665 15958 790
    (user guide part number is #3378927)
    Thanks Daniel - great resources.
    When the repairman showed me the control board there was a burned out area (blackened) area about the size of a thumbprint on one corner of the board (sorry, I couldn't tell you which corner as I'd never seen a board before). Could this have been caused by the fuse going bad, or would it indicate a control board problem, or is it impossible to know until I replace the thermal fuse?
    Also, I am by no means an electronics-experienced person but I have no problem taking on projects that have adequate diagrams and instructions. How do you think I would do, taking on this project myself?
  • mblistein Mar 18, 2011
    Thanks for all the info Daniel. I am not that familiar with electric parts but I'm also not afraid to try something new and am handy with screwdrivers etc. Do you think this is something I can do myself? Also one corner of the control board definitely had a "burned out" look to it, about the size of a thumbprint; could that be a result of just the fuse issue?
    Sorry for the repeat - I couldn't find your reply and video - had to click "more comments" but just didn't see it. Thanks for everything.
  • mblistein Mar 19, 2011
    Daniel's help was great - like having a friend with lots of experience to explain what's gone wrong, where to get replacement parts, what the real cost is (and what the repairman really pays) and who even shows you how to fix it yourself by providing a video. A very good service, and it seems completely reasonable to spend $12 to have a conversation with someone knowledgeable and with experience, to make a good decision about how to proceed.
  • 4,323 Answers
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further assistance.
Dan
Posted on Mar 15, 2011
  • 4 more comments
  • Daniel Scott
    Daniel Scott Mar 15, 2011
    Hi
    Drain pump or drain hose blockage can cause the dishwasher to become non-responsive. Try and clear the clog & lint. After clearing the blockage turn off the power to the dishwasher for 15-20 minutes and check. Hope this helps...
    Daniel
  • Daniel Scott
    Daniel Scott Mar 17, 2011
    If it is the control board then yes it can be around that cost however, post back with the complete model no so that I can tell you how much the part will cost as you know they will charge you for home visit etc
  • Daniel Scott
    The part is $166...you can buy it from this link , also check this http://c.searspartsdirect.com/lis_png/PL..." target="_blank" rel="nofollow" >diagram before replacing the control board, as part#18 in the diagram is thermal fuse, if that is bad then it should be replaced not the board.
  • Daniel Scott
    I don't think you will do too bad with this repair :) though you can test the thermal fuse with a voltmeter, if there is no continuity it is bad but I believe that the control board is bad as it was burnt from one side. Check this video for control board replacement (just an example though):
  • Daniel Scott
    Daniel Scott Mar 18, 2011
    Yeah...I told you that could be a control board issue and yes if you want to try it yourself you can check the video that I have sent earlier
  • Daniel Scott
    Thats Fine :) post back for further assistance
Kenmore ultra wash dishwasher gets stuck at 42 on the control panel
Be aware that all (well, almost all) dishwashers have a "thermal hold" period in their cycles. This is the point in the main wash cycle where the heater is turned on to heat the water to the optimum wash temperature (about 150 to 160 deg F), and during this time, the timer will stop advancing. Once the water has reached the desired temperature, the cycle will continue. IF it does not, then you have a water heating problem. This could be caused by a bad heating element, a bad controller, a bad thermostat or temperature sensor.
Mar 20, 2015 | Kenmore Dishwashers
Bf72 not doing the wash cycle correctly
If you are using hot water connection then check the temperature of incoming water is hot enough. If cold water inlet only is used then most likely the heater element or thermostat in the dishwasher is faulty and the water is not heating enough.
Nov 04, 2012 | Hotpoint 24 in. BF72 Built-in Dishwasher
Our dishes are cloudy. It seems that the filter is dirty but I don't know how to remove it.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Jun 18, 2011 | GE Monogram® ZBD6880NSS Stainless Steel...
Dishwasher stops during various cycles and does not clean dishes
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 30, 2010 | Jenn-Air JDB3610 Built-in Dishwasher
Food particles remaining on dishes after cycle is complete.
Hi
While putting dishes in the washer and obstructing the spray ams which causes food particles to stay on dishes. After loading dishwasher and pushing in baskets ,be sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
However the other causes for this problem are…
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 14, 2010 | Maytag 24 in. MDB8600AW Jetclean II...
After wash cycle and rinsed cycle there were suds
Make certain you do not use dish soap when rinsing the dishes. Make sure you only use DISHWASHER soap when running the DW.
In fact,there is no need to rinse dishes. Remove visible scraps and put them in the DW. If it is a quality DW it will clean your dishes. Do not crowd the dishes in the DW. Most JennAir DW's are quality. Make sure the top rack can get washing action from the bottom spray arm. No pots or other water stopping utensils on the bottom rack.
Oct 06, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
I have soap build up in the dishwasher. The dishes aren't getting completly clean. Ran load today twice and they didn't look any better.
Most likely causes are:
Hope this help. Good luck.
Sep 11, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Water pools in bottom of dishwasher and dishes come out dirty
Pump is stopped up, or bad, can you here the pump run, if so drain and make sure there is nothing in the intake of the pump.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Jan 15, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
125 people viewed this question
Top Dishwashers Experts
Owen Barnes
