How do i get 'dig 1' off the screen, it stays on the upper right hand corner constantly. it didnt always do this. after we have been on dig 2 for dvd's or games and we switch back to dig 1 (digital 1) it stays on there-use to go off. how do i get it off?
  • 902 Answers
2 ways. 1 unplug tv for about 10 minutes to drain any capacitor battery that should reboot the tv. also check settings some tv's have a setting that will keep the input displayed on screen. hope this helps let me know!
Posted on Mar 15, 2011
  • bevy2000 Mar 15, 2011
    i did look on the menu and of course could not find the settings. thank you so much tho for
    your response!
  • brian shevack Mar 15, 2011
    your welcome did you try the unplug the tv for awhile? sorry i couldnt help i tried. really hard. oh well coulda used a good review lol trying to get up to premium stratus good luck tho
To close window on right hand of yahoo so i can view full screen
1.If you right click on the blue header of the page you will see Restore, move, minimize, maximize, etc.
2. Click maximize to see if the screen enlarges or increases in size.
3. Then click the X in the upper right hand corner of the screen and this will close the window.
Mar 13, 2010 | Dell Dimension E521 AMD Athlon 64 X2...
When i turned on the leapfrog and asked me to log in my name it doesn't let me go in when i press it with the leapfrog pen
the screen needs to be re-calibrated. Do this: while powering on the Leapster, hold down the ? key. If it's been worn off, it's the round key on the left hand side above the t-arrow keys and it's the middle button. A new screen will come up that lists Base Info Cart 1 Info, Cart 2 Info, Cart 3 Info. In the right hand corner is a "A" that you can touch with pen beside it, it says "Touch Calib" Touch on that.It will say starting...then in the upper left hand corner there is a +. touch it with pen. it will move to bottom left hand corner. Touch it with pen. It will move to right bottom corner. touch with pen. It will move to upper right hand corner. Touch with pen. It will move to the center of the screen. Touch with pen. Repeat until you come back to the Base Info screen. You're DONE! Power off and on again and you should be all set! Good luck!!
Feb 28, 2010 | LeapFrog Leapster 2 Learning System
The volume of sony wega kv-sw29m61 set always to maximum when it turned on
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Jan 16, 2010 | Televison & Video
Conon powershot a470 i cant find in the manual where the battery life is displayed? is it on the screen? do u have 2 change setting 2 find it? or does this model not display it on the screen?
Your a470 has a "low battery" flashing icon that will appear in the upper right hand corner of your lcd display when the battery is getting low. It doesn't appear to have a constant battery display. The manual recommends when you see the flashing icon... change the battery as soon as possible.
May 15, 2009 | Canon PowerShot A470 Digital Camera
LCD Screen says ''2 missed calls''
The "[1]" (or other number) in the upper right is the number of the extension. If you have more than one extension, they will each have their own number. Unfortunately, I can't anwer your other question as I have the same problem myself.
Feb 16, 2009 | Panasonic KX-TGA101S Cordless Handset
Number 2 in upper right hand corner of screen
Had this problem also when I rebooted my Time Warner Cable box. Unplug everything from the wall including power strip and wait 60 seconds then plug back in and turn everything back on. Worked for me and havent had a problem since. Time Warner does not know what causes this yet.
Jan 28, 2009 | Samsung LN46A530 46 in. LCD HDTV
There is a 2 in the upper right hand corner of the screen.
We had the same issue. Contacted Time Warner, and were instructed to reset the digital receiver by unplugging the power supply from the back of the receiver for at least 30 seconds. This will force the receiver to reset.
Fixed it for us. Big sigh of relief!
Nov 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Looks like a crack in the display
such issues have occured in the Past, Please Check if the Crack appears in the BIOS mode.Safemode also Try another Monitor to find out if it is not the wall paper because if it is then the Crack will appear in the other Displa too...
Jul 17, 2008 | Computers & Internet
Can not remove the number of the tv channel from the screen
How to remove the green number three from the right corner of the tv screen without having the original remote as the cable company suggested.
Dec 12, 2007 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
