Question about Lamps Plus iHome Desk Lamp with Surround Sound Speakers and iPodmp3 Dock White (IHL31 WHT) Docking Station Speaker System
My iHome iHL31 ipod dock desk lamp light stopped working.. iPod works but when I turn on the light the bulb goes on for a second, the iPod shuts off then the light goes out and the iPod comes back on.. I'm thinking power supply..?? Thanks.. Arthur
Remote wont work with the ipod
Make sure the ipod dock connector is clear of any debris both the on the dock and on the ipod. Use a can of air to clean these and try reconnecting it.
Try updating your software on your ipod. Plug it into itunes and update.
http://repair-scratched-ipods.blogspot.com
www.huskyipodrepair.com
Jul 26, 2009 | Dual Electronics ihome iH9BR iH9 Alarm...
Doesn't play on ihome says "not compatable"
It's a new ipod, right? And your docking station must of been made before the new nano toke the stores. You need to get a new docking station.
May 26, 2009 | SDI iHome iH5 Docking Station, FM...
Ihome won't play ipod, even after resetting ipod I have de same problem. I got an itouch 2nd generation and docked it on a speaker that supports it. It worked fine for two or three hours, but suddenly it...
Welcome to the wonderful world of the iHome frying the Ipod.
Your iHome, has most likely fried the mainboard on your ipod.
to check plug a usb into the ipod and connect to the computer.
if it comes up disconnect the usb and try a headphones in the jack.
if it doesn;t play sound its fried and you will need a new mainboard.
if it does play through the headphone jack, your lucky and keep it off the dock.
I have fixed at least 30 ipods taken out by ihome docks and other docks.
they are terrible for the ipod. Even Apple sells the docks on their website
that shows how much they care about the product.
If this helps leave a vote on fixya
May 11, 2009 | Apple iPod touch
Remote won't control my 4th generation ipod nano
Hey I figured it out. When you bought the 4th generation ipod nano it came with it's own dock insert. It fits perfectly and fixes everything, including the remote issues. Now my only problem is I have a black ihome and a white insert :( Good luck!
Dec 26, 2008 | Dual Electronics ihome iH9BR iH9 Alarm...
Problem with ihome and ipod nano.
yes, unfortunately the ihome iH9 is not compatible with previous models of the ipod nano.
if you want a similar device, there are many other docking stations for the ipod that are ip0 that ARE compatible with the ipod nano 2G
iH85B is another ihome dock which is compatible with all ipods after the ipod mini (including the ipod nano 2G)
http://www.ihomeaudio.com/products.asp?product_id=10186
Dec 25, 2008 | Apple iPod nano
IHome lamp has a humming noise
Hi, I would suggest you exchange it for a new one under the 6month warrranty it has.
I have several iHome Lamps and I dont have a humming noise from any. I know its annoying but its an electrical item and sometimes they go wrong.
Dec 09, 2008 | Blue iHome Desk Lamp with iPod/mp3 Dock,...
IPod 8 GB silver will not turn on
I went to the Apple site and found these instructions. They worked for me.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Dec 04, 2008 | Apple iPod nano
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
Jun 30, 2008 | Audio Players & Recorders
Lamps Plus iHome Desk Lamp with Surround Sound Speakers and iPodmp3 Dock White (IHL31 WHT) Docking Station Speaker System Logo
273 people viewed this question
Top Lamps Plus Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Lamps Plus Audio Player and Recorder Expert? Answer questions, earn points and help others
