Question about General Electric 100Amp 2-pole bolt-on circuit breaker
The breaker has a burn mark on it and it keeps bowing, is this a dis continued product?
    Scholar:
  • 99 Answers
No you should be able to get one at Lowe's or Home Depot. Call them and give them the the part number before you go to get one.
You should get a electrician to check it out before you change it. If it has a burn mark and it keeps tripping you must have some type of dead short. Changing it may not fix your problem.
Posted on Mar 15, 2011
Keeps tripping the breaker
You have an opencircuit possibly at the wall outlet. Shut off breeaker, pull off outlet cover and take out plug unit. Check to see all wires are secure and no indication of burning or melting. Any black marks indicate an arc of electricity has occured. If suspicious, replace plug with new one.
Apr 21, 2013 | Heating & Cooling
The trip breaker in my home for the electrical outlet keep tripping off what do i do. the breaker in my electircal box for my electrical socket keep tripping off
go to the qualified electricians on your place... but there is some helpful tips that can help you.. (1) for continued protection before starting. turn off the main circuit breaker. (2) unplug all the appliances or equipment installed... (3) check all the wall socket outlet... look for any damages on the wall socket... if the wall socket outlet have no signs of burned or wet marked, try to turn on the circuit breaker. check if the problem is solved.. (4) if the wall socket outlet have a signs of burned or wet marked.. just replace that w/ the same type of socket... check also the appliances that may caused the problem... the easiest way to know is to look at the socket plug itself... ty
Jun 21, 2011 | Microwave Ovens
Dryer has lost heat.
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Dec 11, 2010 | Kenmore 700 6972 Dryer
Stopped heating
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Dec 11, 2010 | Kenmore Dryers
I have a sears kenmore gas dryer model 87592820 it keeps blowing the breaker. It was running about 1 min. then a spark flew out and it tripped the breaker. When I reset the breaker it continues to trip it....
This sounds like you have a wire that rubbed through and is shorting out...
open up the back or where you saw the sparks come from and you will easily see the burnt mark...then you can fix it...
Do not keep trying the breaker... it is tripping to protect you and keep you safe.
heatman101
Sep 28, 2010 | Dryers
Kenmore 80 series dryer does not hest
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 25, 2010 | Kenmore Dryers
No heat
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 24, 2010 | Maytag MDE2400A Electric Dryer
Dryer will not start
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 19, 2010 | Dryers
Hi dear. i have my printer canon mp 210,but i lot the dis for install,how can i do with out the dis?
No you cannot install printer without its driver. But yes you can get the driver online.Which you can install and downloaD. click on the link below:- http://software.canon-europe.com/products/0010485.asp --------- You have to select the required options in the link and continue. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 02, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Adding a larger plane to my yamaha motor to keep the bow down
I do not recommend changing the original design; you may face issues when you speed up and the bow start hitting the water for been too low… However, you can do as you please by adding more weight in form of Ice chest or you can find a plastic devices that you can fill with water up to the level you like…again it may be too danger.
Please do not forget to rate the service for the site to continue helping everyone and improve on it.
Sep 16, 2009 | Tools & Hardware - Others
General Electric 100Amp 2-pole bolt-on circuit breaker Logo
Top General Electric Electrical Supplies Experts
hpgwva
Rob Bridges
Level 1 Expert
ken skalski
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
