Question about Toshiba 50HM67 50" HDTV
I have a tosiba 50hm67. I got this tv from a friend and he said that the bulb shattered. I got a new bulb online and still no picture. The blue light stays solid and the yellow light blinks 10 or twelve times 8 times. According to the manual this is a problem with the light. After some research I decided that the ballast must be bad. I ordered one and replaced it... still no picture just the same lights.
  • mirowskimark Mar 15, 2011
    I have checked the switch. It is operating correctly and the door is activating it. The troubleshooting guide for the tv has a different code for this problem.
    do you have any other ideas of what it may be?
  • Toshiba Master
  • 2,098 Answers
Hi mirowshimark,
Check the housing of the bulb, some unit has a reset switch in the housing of the bulb. If the bulb is not fitted right this switch is disable and make the unit gone to blinking error.
Jdvillanueva
Posted on Mar 15, 2011
  • Jdvillanueva
    Jdvillanueva Mar 15, 2011
    to avoid wasting your money and time you may download the service manual http://service-manuals-schematics.com/pu.... Listed here the error code and parts you are going to check. I've check my file but I haven't a copy of this yet. I've also check a free download but none is available.
  • Jdvillanueva
    most of the error code I've encountered is related in the output of the power supply. It has a main regulator IC and multiple regulator output feeding to main board, ballast board, tuner, etc... You have to checked the output voltages of each regulator. If there's a missing voltages there it will trigger the error code (blinks depend on the model and brand). Check also for bulged capacitor in that area, burnt fusible resistor. You must have a multimeter to do this job...
Broken glass piece where dlp bulb goes I shattered! help
Please take a digital photo of the broken piece and of the area it came from, Jill, and post that photo here so we can tell what you're talking about.
Aug 11, 2014 | Televison & Video
My toshiba 50hm67 has no sound
If you still have picture, and the sound was working before this--you may have lost the audio amp chip. I hope you are not running a bunch of external speakers on the tv here--this WILL kill that chip !!
Apr 08, 2014 | Toshiba 50HM67 50" HDTV
I had to change my bulb about 6 months ago and now i'm having the same problem. i checked the bulb to make sure it was still intact and indeed it was. i'm wondering if there is some kind of switch to...
Ur tv probally also have the board call the Ballast board is also dead beside the projection lamp was replaced before.This board call the Ballast board job is to help to ignite the projection lamp.About an hour before the Super Bowl.Unplug,replug the tv back about an hour later for the tv for the Ballast board might have some juice left to ignite to light up for projection lamp for the last time to have tv picture to the to watch the Super Bowl.Must replaced the Ballast board.
Feb 05, 2011 | Toshiba 50HM67 50" HDTV
The picture won't come on and when I push the power button it says lamp is not working
The tv "LAMP" LED light indication flashes or stay on.Ur tv the projection lamp life are over.Ur tv require a new projection lamp.
Jan 19, 2011 | Toshiba 50HM67 50" HDTV
Blue light remains lit but lose picture. no other indicator lights flash. if i unplug the tv it will restart but lose picture again after half hour
I have a toshiba 50hm67 tv and with mine the blue light would come on and I would hear sound first and then the picture would finally come on... this happend for about a month.... next the yellow and blue light would come on but the pic still wouldn't come on until it clicked off and on by itself for about 10 min this went on for about a week. All of a sudden last night the red lights by the power light started blinking. No tv now and when the tv shut off it said lamp not working.
Sep 17, 2010 | Toshiba 56HM66 56" Projection HDTV
I no longer have the manual for my toshiba 50HM67 and it needs a new bulb. Is it something I can do myself ie is is it simple or difficult?
They make these sets for the consumer to be able to change the lamps all you need is a flat head screwdriver.
Dec 05, 2009 | Toshiba 50HM67 50" HDTV
I recently replaced the lamp bulb...it worked for a day and now I have sound and no picture and when you turn the tv on I get red flashing lights...and the after they are done flashing the light is blue.
You could have gotten a defective lamp. Try another lamp. Since you have a Toshiba youll be using it even if you don't need it now. Toshibas have short lamp life. If lamp does not fix then the light engine will have to be removed and sent to Toshiba to be rebuilt. They are no longer available.
Nov 18, 2009 | Toshiba 50HM67 50" HDTV
I nees a cooling fan for a Toshiba 50HM67 50 inch
trucker I found this website....http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1089868%2DTOSHIBA&Show=ExtInfo hope it helps
Jun 21, 2009 | Toshiba 50HM67 50" HDTV
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Toshiba 50HM67 50" HDTV Logo
263 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
