Question about Dometic Rooftop RV Air Conditioner
I have a Dometic rooftop AC, 59516.331, and an Atwood 8531 furnace with an analog Duotherm thermostat. I have recently replaced the thermostat. My heat system will only run with the thermostat maxed out. When the system reaches temp., I get a constant clicking sound (I think in AC unit area), whereas the system starts and stops constantly. Same goes for when i run AC. Problem has gotten progressively worse, that's why I replaced the thermostat. Now the comperessor on AC never shuts off except when I switch off at circut breaker(a recent addition to my probs). Both devices work when they are running (AC sends cold air, Heater sends hot), but temps never correspond to thermostat. Any help would be greatly appreciated.
  • tim_maxers Mar 15, 2011
    I'm going to camper later this week, as I keep it seasonal. I'll be sure to take my meter and test as you suggest. Will let you kno how it works out.
  • 5,370 Answers
The contactor for the compressor may be stuck. Remove the outside shell and locate the contactor to see if this is the case. The contactor may be located in a metal box once you remove the units cover. You may be able to just tap it and get it unstuck but it would probably be best to replace the contactor.Also check the voltage and other parts.Keep updated with details.Thanks.Helpmech.
Posted on Mar 15, 2011
  • Dometic Master
  • 6,674 Answers
Be sure to double check wiring between thermostat and control/relay box at ceiling assembly. For example ( sometimes they will connect a yellow wire from box, to an orange in harness that goes to thermostat.) Make sure they all match your instructions on thermostat to coincide with whats coming out of the control box. If it's yellow from control box, and connected to a brown in harness to thermostat location, then consider that a yellow etc. Make sure you only have approx 7.5 volts DC at far left red as marked and not 12 VDC.
Up at the control box wiring, you should see 2 blue/with white stripe wires. Those are your 2 wires for furnace. I you test voltage at those, you should get min. 12vdc on one wire constantly, then when thermostat moved to higher temperature and calling for heat, you should get 12vdc at both blue/with white stripe. It sounds like control/relay box needs replacing, but if you have a multimeter and are comfortable with it's use, I will get you to check outside at furnace as well, just to confirm my suspicions. A new box is roughly $90-$100.
  • Mike Butler
    Mike Butler Mar 15, 2011
    Be sure to give those wires a good wiggle up at control box as well to make sure all those connections are good .
I have a Dometic DuoTherm ac/furnace unit in an rv. The thermostat got knocked off the wall and now the ac nor the furnace will work. Fan works in manual position only. What could be wrong?
When the thermostat was knocked off it may have damaged the wiring. I would start by checking continuity of all wires from thermostat to unit.
Feb 15, 2015 | Dometic Rooftop RV Air Conditioner
I have a Dometic DuoTherm AC/furnace in my RV. Thermostat got knocked off the wall. Now only thing that will work is the fan in the Manual mode. Heat nor air will come on. What could this be.
If you have properly re-attached all the wires to the old or newly installed thermostat, then I would suspect that one or more of the control wires to the heat pump have either been severed or pulled loose from the heat pump.
How do i bypass the furnace and still use the duotherm 57915.531
Do you have the digital thermostat? You can tell the thermostat you have no furnace. You should be able to disconnect power at the furnace, but the 12v power for the circuit board is provided by the furnace circuit on some systems so make sure you disconnect the wire going to the furnace and leave the wire feeding the circuit board.
Oct 06, 2014 | Coleman Dometic Duotherm Rv Air...
I replaced the control box and thermostat but i have no power to the thermostat
I know this is an old question but almost all rooftop AC units get thermostat power from the Furnace. If you don't have good 12 volts at the furnace your thermostat will not work.
Jul 12, 2014 | Dometic Rooftop RV Air Conditioner
Two air conditioners & two furnaces with one thermostat
use relays to combine the to and isolate from each other or observing polarity's, you should be able to parallel the connections from your thermostat
Jan 28, 2010 | Dometic Rooftop RV Air Conditioner
I have a suburban lp furnace and duotherm air/heat pump roof unit. duothern thermostat. 20 amp breaker kicked ( reset breaker) & furnace quit. NOW furnace fan comes on but does not light, and the front...
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 23, 2010 | Dometic Rooftop RV Air Conditioner
I have a DuoTherm BriskAIr 13.5K BTU. The Dometic thermostat also controls my HydroFlame 8531-IV furnace. This morning, the furnace would not come on. I checked the wiring and there is no voltage at the...
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
Dometic/Duotherm propane furnace won't fire up
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Feb 10, 2009 | Dometic Rooftop RV Air Conditioner
Furnace won't turn on, off, with or without remote
We hotwired the thermostat wires and the furnace started. That told us that the problem was with the thermostat. We took our remote control to another camper like ours and our remote worked their furnace. That told us that the problem was in the ceiling control for the furnace/ac. But the man who owned the other camper told us that he had a problem, too, and was told to unplug all the electric including the battery, wait 2 minutes, and hook up again. This might reprogram the circuitboard, and voila! It worked.
Feb 08, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
269 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
