Question about Philips Pocket Memo 9360 Handheld Digital Transcriber / Recorder
I have a Philips Digital Pocket Memo 9360 Portable Audio device. Works fine on Windows but Mac can't recognise it. Using Panther and Snow Leopard (on different macs). Is there a suitable driver I can download or am I stuffed? Thanks in anticipation. John
4 Suggested Answers
  • 61 Answers
SOURCE: Philips Pocket Memo 398 dictation machine - spindles not turning
Most likely cause here is a broken drive belt. This machine is at least ten years old. The belts for the latest model (381) will fit, but it's a tricky job to fit.
Posted on May 17, 2010
javer821
  • 207 Answers
SOURCE: Our 9500 series Philips digital
Hello You need to Use Philips SpeechExec software for automatic
download, conversion and routing of files
recorded with a Pocket Memo dictation
recorder. How and which files are downloaded after a
recorder is connected can be configured in
the settings menu of SpeechExec or with the Configuration Wizard
Configure the download process
from the Pocket Memo
Pocket Memo is connected can be configured in
the settings menu or the Configuration Wizard.
1 Connect the Digital Pocket Memo to the PC
using the USB cable.
2 Click Settings > General Settings on the
menu bar, select DPM/DT Configuration >
DPM Settings from the list on the left side.
3 Click the Start... button. The DPM configuration
dialog is displayed in a new window.
4 Select Download in the left pane.
5 Select which files will be downloaded
(download file type):
• All files
• EOL (recordings marked as finished/endof-
letter)
• File selection (SpeechExec prompts the
selection of specific files to be downloaded)
• File with keyword 1 (specify a keyword)
6 The download settings also allow the user
to specify if files will be deleted on the
Pocket Memo after they are downloaded.
7 Click OK to save the settings and confirm
the transfer of the new settings to the
Pocket Memo.
Posted on Apr 15, 2011
  • 145 Answers
SOURCE: cannot run philips LFH9398 pocket
the philips models are not MAC compatible. However, they normally show up as a folder and you can copy files.
Posted on May 06, 2011
Philips pocket memo LFH 9730
Hello I don't recognize that model may be you try to say Philips Digital Pocket Memo LFH9370.
Your unit charges two ways via power supply direct on the portable or via docking station, make sure you have the proper rechargeable batteries you must have the LFH9154 if you don't have this batteries you can buy them on the next link http://www.tvps.com/Products/Philips-LFH9154-AAA-NiMH-Rechargeable-Batteries---New-9154__PH-LFH9154.aspx
May 06, 2014 | Philips Audio Players & Recorders
Function locked
You may have a SD card with a lock switch in the lock position. If not, the internal sensor that detects the position of that switch may be bad. It could also be corrupted memory so try reformatting the memory from the menu. Scroll thru the menu until you see the memory icon.
Dec 18, 2013 | Philips Pocket Memo 9360 Handheld Digital...
Cannot run philips LFH9398 pocket memo on my mac
Apr 29, 2011 | Philips Pocket Memo 9360 Handheld Digital...
No printer driver for HP LaserJet 4ML on Mac running Snow Leopard
The drivers should be packaged into snow leopard. This printer is listed as a supported printer for Snow Leopard.
this link will walk you through the process
Hp.com
Al
Eliteprintersolutions@gmail.com
Jul 10, 2010 | HP LaserJet 4ML Printer
How do I reset to factory defaults
You can download the manual for this machine at www.dictation.philips.com in the support section.
Feb 22, 2010 | Philips Pocket Memo 9360 Handheld Digital...
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
Feb 09, 2010 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Canon PIXMA MX870 Wireless Printer works with Snow Leopard OS?
The MX870 is compatible with Mac OS X, all versions. I think the CD that comes with the unit will have the Mac Snow Leopard drivers on it, but if not you will be able to download them here.
Feb 05, 2010 | Canon Office Equipment & Supplies
Philips Pocket Memo 9360 Handheld Digital Transcriber / Recorder Logo
126 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
