Question about Microwave Ovens
The heating element on the bottom does not get hot
  • Microwave Ovens Master
  • 43,501 Answers
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Mar 15, 2011
Tappan Oven 316246653. Preheating the Oven does not work. Bottom Heating Coil (if thats what its called) is not working. The Broiler Coil at the Top does work. Is it the bottom coil that needs replaced...
Usually when the element fails to heat up, It means its usually broke, cracked, or where they plug in gets brittle and breaks. Your best bet is to replace the bottom element.
May 23, 2011 | Microwave Ovens
Our American ADW1100n15BB dishwwasher does not have any hot water.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
May 05, 2011 | Microwave Ovens
My lower oven is not heating properly, the bottom heating element is not getting hot.
You will have to test the element to be sure it is the problem. Turn power off to oven and then remove element. You will have to check with ohm meter. Remove wires before checking. If you don't have one, most appliance parts stores will check it for you. If element is burnt in two or has any rough, bubbled up places on it, then it needs to be replaced.
Jan 18, 2011 | Microwave Ovens
Does the dishwasher model GDB742RJS0 have a heating element or does it require a cold and hot water hook up thanks
Yes, your dishwasher has a heating element. You only need a hot water hook up. attached is a picture of some of the parts in your dishwasher. The heating element is #1. It is located at the bottom.
Hope this clear things up.
Please vote and add any comments you wish.
Mr Tin Man
Dec 21, 2010 | Westinghouse Microwave Ovens
Electrolux esl 6115 dosent seem to be getting hot, filling with water but not cleaning the dishes, cleaned the filters.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
Asker
Sep 30, 2010 | Microwave Ovens
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Dryer is over heating, all thermo have been replaced along with motor and belt. Turn on and still shuts down and smells like its burning. Dryer is hot to touch.
dryer element is fused to metal housing thereby heating all the time as the element is grounded all the time making a closed circuit
Apr 17, 2009 | Maytag MMV4205 Microwave Oven
I am not getting power to the heating elements.
Maybe you should first by checking the fuse to the unit.Look around where the power cord come into the unit.The fuse may be blown.
Mar 15, 2009 | KitchenAid KHHS179LSS Convection /...
Microwave Ovens Logo
37 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
