Need remote control codes for my Dish Nnetwork remote to control my Sharper Image MC502 Bookcase DVD System
IrishDruid
  • 2712 Answers
SOURCE: SHARPER IMAGE 8 IN 1 TO TOSHIBA HD DVD PROGRAM CODE NEEDED
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • 4 Answers
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
SOURCE: the sharper image jumbo touch
The instructions that came with my remote were COMPLETELY incorrect. I made note in pen in my jumbo remote manual. After hours of searching the web and piecing together various blogs, I wrote these easy-to-use instructions:
  1. Place the jumbo remote and your old remote on a flat surface, head to head, with a 1" to 2" space in between (the remotes should be aiming at eachother).
  2. Press and HOLD the device button on the jumbo remote (eg. TV) until the jumbo remote's small indicator light turns solid red.
  3. Press the LEARN button once on the jumbo remote. The light will blink rapidly.
  4. On the jumbo remote, press the button that you want to perform the learned action (eg. If you want the jumbo remote to turn your TV on and off, press the POWER button on the jumbo remote).
  5. Press the same button on your old remote (eg. POWER button on my old tv remote control). When the jumbo remote's light changes from rapid flashing to slower flashing, press ENTER on the jumbo remote.
  6. You're done! Try the jumbo remote out (eg. Aim the jumbo remote at your TV, press the jumbo remote's TV button, then press the jumbo remote's POWER button). Your television should turn on or off with your jumbo remote.
You can program any jumbo remote button this way (eg. MENU, EXIT, MUTE). Just make sure you press the same button on each remote in steps 4 and 5 (eg. MENU on jumbo remote, MENU or LIST on old remote).
Posted on Feb 18, 2009
SOURCE: sharper image jumbo sized universal remote control
Hey,
I know how annoying it is to have sth with its instructions. Thus, here you have the manual (I scanned it myself for you :))
http://rapidshare.com/files/202369180/SharperImage-JumboRemoteControl.pdf.html
Regards,
Mario
Posted on Feb 25, 2009
  • 10 Answers
SOURCE: NEED MANUAL FOR SHARPER IMAGE JUMBO UNIVERSAL REMOTE 1613086
The manufacturer of that remote is Emerson.  Here is the manual.
http://mscustomercare.com/forms/JumboRemoteEM_InstructionManual.pdf
Posted on Mar 27, 2009
Sharper image jumbo remote to work with dish network
I can help you with your Sharper Image Jumbo remote control.
There are two Sharper Image Jumbo Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual. Click the above links to download these remote manuals. The included code lists will give you the correct codes you require.
The Jumbo Touch also has a learn function, while the standard jumbo does not.
I hope that helps.
Apr 04, 2010 | One For All URC-9910 LCD Remote Control
Need instructions and codes to program Sharper Image Jumbo Remote
I can help you with your Sharper Image remote control.
There are two Sharper Image Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual. Click the above links to download these remote manuals.
I hope that helps.
Mar 22, 2010 | Sharper Image TI150 Iron
I need instructions for programing my sharper image jumbo remote control
Go to the link below, scroll down until you see the Sharper Image Jumbo Universal Remote Control, click on it and you will notice the words "Instruction Manual......Download" appear below it. Just click on it and you can open the zipped file and have the manual downloaded on your computer.
Hope this you out when it does please leave a thumbs up
cheers Little Dish Fitter
Oct 06, 2009 | Televison & Video
I have a sony tv and lost manual for my sharper image jumbo remote can you help me with what to do
I have the manual and codes in a pdf. If you would like a copy just email me at 585@snet.net and I will send it to you. All I ask is that you leave great feedback on this site.
Regards
AL
Jun 13, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Programming
i need codes to jumbo sharper image universal remote
Jan 27, 2009 | One For All URC-9910 LCD Remote Control
Dec 27, 2008 | Televison & Video
I Am trying to program the sharper image jumbo sized universal tv remote.I can;t get the Samsung dvd/vcr combo to except any code listed in the instruction manual
The Jumbo Touch remote does have a learn function which may be helpful in controlling your Samsung DVD/VCR combo.
I hope that helps.
Sep 12, 2008 | Sharper Image Professional Plus Ionic...
Need remote code for rca dvd/vcr combo using a sharper image univeral remote
Use code search on your Sharper Image remote control to find something that works. If a search through all codes stored in the remote control fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Jul 24, 2017 | Televison & Video
Jumbo Universal TV Remote (Sharper Image-Innovage)
sharper image jumbo remote can't get it to program my philips/magnavox tv.
Dec 25, 2007 | One For All URC-9910 LCD Remote Control
Lost remote
You should buy. Each remote come with instractions how to program it. Also you can ask on the store.
Feb 12, 2007 | Sharper Image MC502 System
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
