My GA 8SIMLNF motherboard keeps shutting down the PS. I'm convinced heat is NOT the issue. I tried a new good PS from my other PC and exactly the same problem, so it's not voltages either. I'm convinced it is a faulty sensing circuit on the GA 8SIMLNF motherboard. I could try shorting the PS_ON pin to ground, to force a permanent ON state, but want your thoughts on this first. I think though, that there is a failing transistor somewhere. Additional info . . I even reinstalled to factory, AND then a clean XP install, which never completed (on 3 attempts) due to exactly the same problem. What do you reckon? Thanks
  • tshanasy Mar 17, 2011
    I've tried tying PS_ON to ground, and the PS stays ON, but software crashes still, so no advantage here. Looks like sensing circuit is doing its job, so a deeper cause, no doubt.
    Curtains to this motherboard.
    Master:
  • 525 Answers
This definately sounds like a bad motherboard. I had a bad psu that was shutting down my system one time. I took it back and got a refund and got another one. Installed and never had the problem again. you said you already checked the psu so yeah thats what it sounds like.
Posted on Mar 15, 2011
GA-8SIMLNF rev 1.1 driver
http://www.gigabyte.com/products/product-page.aspx?pid=1335#dl
Jul 11, 2014 | Gigabyte GA-8SIML Motherboard
Shutting down for no reason
Try testing with other power supply and see if it gives you the same results.
Jun 07, 2013 | Gigabyte GA-G41M-Combo Motherboard
Gigabyte GA-8SIMLNF Rev 1 motherboard specs + help
The following power supply unit (PSU) should work just right, however, it will not fit in a company branded case such as HP, Compaq, Gateway, Dell, etc. sine they all use proprietary parts and cases:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817339019
Jun 27, 2009 | Computers & Internet
What is the correct connections for Packard Bell GA-8SIMLNF motherboard Front Pannel.As I can't read the markings on the board
Hi willow422,
I understand that you need the pin configuration for your front panel. This link will help guide you setup your front panel.
Link:
http://support.packardbell.com/uk/item/index.php?i=spec_columbia6&ppn=P862000601
Jun 16, 2009 | HP Computers & Internet
Hp pc m7640n won't turn on and power supply light is out
OK, this can be a hard thing to fix. Most of the time, the power supply is the first thing to go on a PC. However, when you stated that the motherboards LED came on after you unpluged the PS from the motherboard, it leads me to believe that the motherboard is the issue but the power supply might be outputting higher voltages and the motherboard might be shutting down. Since the power supply is cheaper then most motherboards, I would recommend getting a new one. Check ebay for a new power supply. It should be about $20 with shipping. If the same thing happens, then you need a new motherboard...
May 30, 2009 | HP Pavilion m7640n PC Desktop
After purchasing a new Motherboard, my computer jsut seems to power down after about 20 mins playing games on it. Other than that it is ok.
It definately sounds like a heat issue.
Did you use the thermal paste to heat sink? Make sure your fans are all running. Make sure the heat sink is snapped tight to the processor.
I would suggest a system monitor to detect heat and speed of fans.
May 23, 2009 | Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G...
Drivers
at first you need to identify what is the motherboard model. then go to the intel website, give mother board model. download it. and set up it.
Jan 20, 2009 | Intel Computers & Internet
Ga 8simlnf ram upgrade
There is no motherboard with this model number. Can you recheck this by looking on the board itself. Its right in the middle of the board.
In general though, you can usually put 4GBs of Ram in the G8 series but only Vista and later Linux versions will actually report above 3GBs.
Please reply using the comment box below. Thanks.
Regards,
Worldvet
Aug 17, 2008 | Intel Motherboard
Troubleshooting
How long have you had the system in that configuration? It doesn't seem to be a heat issue running around 45 degrees unless that is the idle temp. I need you to try something, when it shuts down, immediately restart the system in bios and look at the temp for the processor again. I solved my issue by taking a side off of my case and putting a small desk fan blowing directly into it. My idle temp went from 45 down to 27 degrees celcius. In a perfect world, the cooler a CPU runs, the better the system will respond. Find those temps readings for me, and let me know. Also, there may be a small monotoring program in your mobo set up disc to help monitor the temp while windows is running. And also, double check to make sure your processor fan is plugged into the correct spot on the mobo, mine is mislabeled, another issue I had found and corrected.
Mar 17, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
