Blank monitor - Computers & Internet
    Scholar:
  • 89 Answers
Connect an external monitor on your computer. If you saw windows coming up on external monitor,there's a need for you to send the computer to the nearest service center to get the graphics cards and LCD checked. If it will still give you black screen upon boot up, just re-install Windows.
Posted on Mar 15, 2011
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
It switches on for just a second and then the screen stays blank
yetimonsta, Are you sure that the monitor is BLANK?? Or is it just BLACK? Or is it both BLANK and BLACK? Connect a known good monitor to your pc to prove that your pc is working correctly. What does your L90D+ do when connected to good pc. Have you done the flashlight test to evaluate the state of the "switch-mode-power-supply" when lcd panel goes black /blank?? View more of my profile on fixya and you will discover all the options you have open to you. 12fixlouie
Jan 17, 2010 | Hyundai L90D+ 19" LCD Monitor
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
My monitor went black, and the power switch just flashes.
is your CPU working properly? if that the case, your monitor is in need of a service.
reasons for why a monitor goes blank?
Reason 1: Wetness
The number one reason why computer monitors go blank is - wetness. Believe it or not, when your computer monitor is exposed to humid air, sometimes water can condense and accumulate in the monitor. This causes the monitor to malfunction and go blank. I've had this happen to my desktop PC at least three times before. What you need to do is to leave the monitor alone for some time and allow the water to evaporate. That usually solves the problem.
Reason 2: Faulty Graphics Card
The next reason why your computer monitor goes black is due to a faulty graphics card. The best way to detect this kind of problem is to connect up a new monitor to your PC, then check if you have a blank screen. If you continue to have a blank screen, then it's likely your video card is faulty.
Reason 3: Faulty RAM
This one is less obvious and less common, but it can happen. You might sometimes get bad RAM modules which prevent your PC from booting up even to the basic BIOS startup screen. To detect this kind of problem is more troublesome, you might need to remove those RAM modules and insert them into another computer.
Reason 4: Loose Connections
Another reason why your monitor goes blank is due to loose connections. The connection from the monitor to the mains is usually a culprit, as is the connection between the monitor and the video card. Check those connections before you declare your computer monitor as faulty.
Reason 5: A Short Circuit In The Motherboard
And the final reason why your computer monitor goes blank? It's possibly because of a short circuit in the motherboard. This is the most undesirable outcome of course, as you might have to replace your entire motherboard. However, it's possible that this can happen - so keep your fingers crossed and hope it doesn't happen to you.
try this.
please rate my solution.
have a nice day.
Jul 05, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor screens blanks a few seconds after I switch on computer
Took the cable connecting the monitor to the computer and reversed it, this seems to have worked!
Dec 21, 2008 | Sony SDM-S74 17" LCD Monitor
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Can not diaplay when connected to external TV tuner Box(fontech)
'The Monitor goes blank when the box is powered' what does that mean exactly? what box? What was the monitor doing before the said box was pwered?
Jun 04, 2007 | BenQ FP91G+ (Black)
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
